Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 11-07-2011, 12:44 PM   #1
Auzivision
Senior Member
Auzivision's Avatar
Default Overhead Receptacle... How to keep plugs from falling out
I have a couple overhead receptacles above my garage door openers.
Nothing but the electrical plugs and a little friction is holding them in place. Iím getting tired of getting the ladder out to plug my retractable reel trouble light.
Does anyone have any cleaver tricks on how to keep these from falling out short of replacing the receptacles and plugs with twist and lock?
Auzivision is offline   Reply With Quote
Old 11-07-2011, 01:01 PM   #2
Falcon67
Senior Member
Falcon67's Avatar
Default Re: Overhead Receptacle... How to keep plugs from falling out
I had some overhead/drop cords in previous shops - twist lock is the only good way I know.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is online now   Reply With Quote
Old 11-07-2011, 01:04 PM   #3
KyleQ
Senior Member
KyleQ's Avatar
You can bend the prongs out a little bit to get more friction - it works really good with a grounded plug too.
__________________
74' Bronco 105:1 D60/70 Atlas II
86' F350 6.9 IDI 4 Speed
95' F150 4.56 Locked D50/8.8
00' Contour SVT 24V DOHC 3.0
08' Focus 5 Speed Coupe
KyleQ is offline   Reply With Quote
Old 11-07-2011, 01:20 PM   #4
onelochevy
Senior Member
you can always swap out the outlets also. if they are old, they will lose some of their holding power.
onelochevy is offline   Reply With Quote
Old 11-07-2011, 01:34 PM   #5
bmcdowell40
You could get a Kellum grip for on the cord. Weight of the cord is taken by the kellum grip rather than on the plug.
bmcdowell40 is offline   Reply With Quote
Old 11-07-2011, 01:35 PM   #6
Stuart in MN
Senior Member
Stuart in MN's Avatar
Quote:
This may be the case. It may be old, or it simply could be a cheap one that's not built very well. I have a cord reel and the door opener plugged into a ceiling receptacle in my garage with zero problems.
Stuart in MN is offline   Reply With Quote
Old 11-07-2011, 02:13 PM   #7
Tscott
Senior Member
Tscott's Avatar
Twist lock is typically how it's done.
Tom
Tscott is offline   Reply With Quote
Old 11-07-2011, 02:15 PM   #8
rlitman
Senior Member
Twist locks are the best option, but not always feasable.
20A outlets tend to have stronger grip than 15A. If you can find an outlet by Hubbell, they have the best grip on the power prongs out there.
Hospital grade outlets have extra grip on the ground pin, and are often used for overhead outlets too.
What I'm wondering, is why your retractable reel light is pulling on the cord. If the reel is hung close enough to the outlet, there should only be the weight of maybe a foot of cord on that plug. If that's pulling out, your outlet has lost its "spring" and needs replacing.
rlitman is offline   Reply With Quote
Old 11-07-2011, 03:40 PM   #9
larry_g
Senior Member
Is your reel fixed to the ceiling or is it hanging from a hook and free to move? If it moves then you may be just wiggling it enough to cause the plug to work its way out. If it is moving then add a hook to the ceiling and afix the cord to it so the motion is nor transfered to the plug.
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 11-07-2011, 05:04 PM   #10
TWX
Senior Member
TWX's Avatar
Yeah, I've never had overhead receptacles let go of plugs either. I'd bet that something's wrong, and that it's time for new receptacles.
I'm wondering if tamper resistant units might also grip a little better...
TWX is offline   Reply With Quote
Old 11-07-2011, 05:20 PM   #11
rlitman
Senior Member
Quote:
Nah, those just have plastic shutters that don't really hold much at all.
Old 11-07-2011, 06:15 PM   #12
Aceman
Senior Member
Like said above, buy a spec grade recep.
Or I've been told, a hospital grade recep has even more holding power yet, but I can't verify it. I've installed them but never payed attention to how tight they grip cord ends...
I'm sure they aren't the cheapest though and I'll bet HD doesn't carry them.
Aceman is offline   Reply With Quote
Old 11-07-2011, 08:25 PM   #13
taumac
Senior Member
taumac's Avatar
I say new outlets and If still had a issues a idea is to get those plastic cable claps and screw it in where it outlet cover screw screws it. Those plastic wire clips look similiar to the claps that hold brake and fuel lines on the frame rails if you get my idea.
taumac is offline   Reply With Quote
Old 11-07-2011, 08:30 PM   #14
mrb
Senior Member
mrb's Avatar
Hospital grade receptacles have the most holding force. Use one and your plugs will not fall out.
mrb is offline   Reply With Quote
Old 11-07-2011, 08:32 PM   #15
BigJohn20
Senior Member
They do carry the 5362-IGS, which is the Industrial Grade Isolated Ground Receptacles.
BigJohn20 is offline   Reply With Quote
Old 11-07-2011, 10:43 PM   #16
Norcal
Senior Member
HD Supply does carry hospital grade receptacles, they have been getting into healthcare items, BTW regs require a minimum of 4 oz of blade tension on receptacles in a health care facility. (Patient care areas). Yearly testing & documentation is also required.
Another comment: Grainger also has HG receptacles & while I prefer Hubbell, Leviton does make a robust HG receptacle at a much lower price. Ebay may also be a poss. choice...
Norcal is offline   Reply With Quote
Old 11-08-2011, 02:46 AM   #17
StaggeringGoat
Senior Member
StaggeringGoat's Avatar
I agree, install new quality outlets. They should hold fine. In my old shop plugs wouldn't stay in the wall because the outlets were so worn out, but new outlets fixed it easy.
StaggeringGoat is offline   Reply With Quote
Old 11-08-2011, 05:14 AM   #18
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
As others have said, its the receptacles. I used Levition Pro Grade for my lighting and have never had any of the plugs work out of the receptacles, even slightly.
Charles
Charles (in GA) is offline   Reply With Quote
Old 11-09-2011, 03:53 PM   #19
gatchel
Senior Member
buy a quality outlet.
gatchel is offline   Reply With Quote
Old 11-10-2011, 12:23 PM   #20
Mattlt
Senior Member
Mattlt's Avatar
Quote:
This is what we've got at the fire station. Works great for us!
Mattlt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
