Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 11-08-2011, 08:51 PM   #1
Gravedigger
Junior Member
Default Pole barn radiant Heat insulation?
How should the concrete floor in a pole barn be insulated for radiant floor heating? Does just the slab need to be insulated on the sides and underneath w/2"board and vapor barrier?
Gravedigger is offline   Reply With Quote
Old 11-08-2011, 11:31 PM   #2
Sureshot
Senior Member
Sureshot's Avatar
Default Re: Pole barn radiant Heat insulation?
I only did the sides but wish I had shelled out the cash to do underneath but at the time no one seemed to think it was needed.
Sureshot is offline   Reply With Quote
Old 11-09-2011, 09:46 AM   #3
KELLHAMMER
Senior Member
KELLHAMMER's Avatar
I did a barn floor with radiant We had the building analyzed by Radiantec they recommended 2" under the slab for the first few feet around the perimeter. We did the whole slab. And we used 1 inch rigid on the edges. Having the insulation definitely makes the slab quicker to respond to temperature demands. And theoretically stays warmer longer after it's switched off.
KELLHAMMER is offline   Reply With Quote
Old 11-09-2011, 07:17 PM   #4
pstnbly
Senior Member
You need to thermally isolate the slab, this means insulation under and around the slab. You must de-couple the slab from conductive loads or you are paying to heat the ground which is thermally very stable and will take virtually any and all BTU's it's given. I've even heard of peoples driveways and nearby ponds staying thawed in high degree day climates.
pstnbly is online now   Reply With Quote
Old 11-10-2011, 10:37 AM   #5
Highbeam
Senior Member
I just built my 30x60 pole barn floor this way. VB, then 2" of 25 psi foam, then mesh, then pex, then 6" of concrete. The perimeter was also covered with 2" foam all around that extends below the bottom 2" of foam. The sides are the most important but the bottom needs insulation too.
The wire mesh made a fantastic grid to measure and attach the pex tubes. I used plastic zip ties.
Highbeam is offline   Reply With Quote
Old 11-15-2011, 07:16 PM   #6
Gravedigger
Junior Member
Thanks for the info. Will isolate with insulation
Old 11-15-2011, 07:46 PM   #7
dejar59
Junior Member
If you use the zip tie method, make sure you trim off the excess. Don't ask how I know but I do.
dejar59 is offline   Reply With Quote
Old 11-15-2011, 10:47 PM   #8
BadgerBoilerMN
Senior Member
BadgerBoilerMN's Avatar
Naturally [I]all[I] insulation is specified according to the application and location. I would not use Radiantec as the standard.
The PEX is stapled to the XPS in most applications. there is no merit in wire unless the tube needs to be suspended -rare-.
BadgerBoilerMN is offline   Reply With Quote
Old 11-20-2011, 03:57 PM   #9
Highbeam
Senior Member
Quote:
Yes, the wife got zip tie tail duty while my bleeding fingers recovered from zip tie installation duty. Worked great.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
