Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-12-2011, 10:18 PM   #1
thouk
Default Ridge vent for my shed???
Hey Ya'll,
I am building my new shed. It is going to be 10x12. I do not plan on insulating it. I may occasionally have a heater in it to take the edge off. So here is my question... based on that I live in Lincoln, Nebraska where the temps hits the extremes, do I need a ridge vent? I am installing the rest of the roof panels tomorrow and want to know if I should cut the slot for the vent? If I should what size does it need to be, width wise? Thanks, Tony
thouk is offline   Reply With Quote
Old 11-12-2011, 10:52 PM   #2
yucholian
Senior Member
Default Re: Ridge vent for my shed???
For my 12x20 in progress, I installed gable vents, one on each end.
yucholian is offline   Reply With Quote
Old 11-12-2011, 11:00 PM   #3
bczygan
Senior Member
bczygan's Avatar
Absolutely you need a ridge vent and eave vents. It is to remove heated air from inside the roof space.
__________________
  • You may have facts, but I have ALTERNATE facts!
  • Now you guys are going to make me do something instead of thinking about doing something. Okay...........I'll get back to you later when I figure out what I am going to do. - dlcwent
  • Perfection is NOT the standard!
  • There are no limits to what you can accomplish.....when you are supposed to be doing something else. - rshadd
  • Health thread: Begin 237 goal 220 start 12/5/2016 Age 66 6'-3" Cut down salt, pop, sugar and mayo.
bczygan is offline   Reply With Quote
Old 11-12-2011, 11:22 PM   #4
PassnThru
Senior Member
PassnThru's Avatar
You need 'a' vent. It doesn't have to be a ridge vent. Just some way for moisture to escape instead of building up and rusting everything in the shed in the winter. As mentioned before, it also keeps the temps from building up in the summer.
__________________
*** Looking to quote you here - preferably a quote you would rather we all just forgot. I'm watching......
(Excluding TampaGT - no shock value left there)
PassnThru is offline   Reply With Quote
Old 11-13-2011, 12:24 AM   #5
aar0s
Senior Member
aar0s's Avatar
stay away from the ridge vents that look like a scotch brite pad in a roll, they tend to get clogged up with dust and dirt.
I would think that a couple of these
http://www.amazon.com/Air-Vent-Slant.../dp/B000BPAW2K
with some eave vents would be fine for what your doing, but im sure that youll be told otherwise.
re-read your post, are you using metal roofing like pole barn metal? that vent wouldn't work for that, you'd need to use a ridge vent but not the mesh (cobra) vent, that stuff will clog up over time.
__________________
Our lives are determined by opportunities, even the ones we miss.
Quote:
Originally Posted by 432bullet View Post
I have never seen a Brinks truck following a hearse yet. Just a thought.:)
aar0s is offline   Reply With Quote
Old 11-13-2011, 04:11 AM   #6
g-mo
I recommend the ridge vent.
I used this from lowes....
g-mo is offline   Reply With Quote
Old 11-13-2011, 04:27 AM   #7
dadsEH
Senior Member
dadsEH's Avatar
So..... how does it vent when its covered in a foot of snow??
__________________
" send Lawyers,guns,and money......
The shit has hit the fan."
dadsEH is offline   Reply With Quote
Old 11-13-2011, 08:15 AM   #8
glider
Senior Member
glider's Avatar
Ridge vent is a good idea but you need to set your rafters 16" oc.
glider is offline   Reply With Quote
Old 11-13-2011, 08:23 AM   #9
wolflrv
Senior Member
Definitely go for the ridge vent. I only had small gable vents on my open rafter shop and the hot air just hung up there. After having the ridge vent installed, even before ceiling insulation it made a huge difference in getting the heat out of the ceiling.
__________________
My garage reorganization thread...
http://www.garagejournal.com/forum/s...d.php?t=108382
wolflrv is offline   Reply With Quote
Old 11-13-2011, 11:16 AM   #10
thouk
Thanks Ya'll,
I put the rafters on sixteen centers, well sort of. The shed is coming along fine. I need to finish up the installation of the last roof panels. I have to go buy two more sheets of plywood for that. Hopefully I can get off my rear and get it at least tar papered today. I don't like cold and anything below 60 degrees is that for me. G-mo I saw those panels at the depot by me. I was going to use those. Thanks for all the help, Tony
Old 11-13-2011, 11:21 AM   #11
IDASHO
Senior Member
Quote:
It really shouldnt NEED to vent if it is covered in snow.
That said, Ive had 3+ feet of snow on my place, and the ridge vents were still clear. Just a slights breeze across the ridge is enough to keep snow from building up. On at least 1 side.
__________________
See my garage build here:
http://www.bonnefinstudios.com/kwb/paradise/garage/
IDASHO is offline   Reply With Quote
Old 11-13-2011, 01:02 PM   #12
iagsxr
Senior Member
iagsxr's Avatar
The one and only storage shed I ever built I put ridge vent with vented soffits on it.
It's so nice on a hot summer day to have it not be 200* in there or smell like gas from the cans stored inside.
Made my roof 6/12 as well, it normally doesn't hold snow.
There was a guy that used to come in our shop that built storage sheds as a sideline. Of course everyone wanted them as cheap as possible so his normally had no venting at all. They don't last for shit. My theory is with hot and cold they condensate internally, plus typically they're sitting on skids in the dirt drawing moisture and it makes rot from the inside out.
iagsxr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
