Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-08-2007, 03:26 PM   #1
PoorOwner
Senior Member
Default DIY socket organizer
I looked at a few options like hanson and ernst but they cost a bit much and I still have some bits and pieces or holes to fill.
I am thinking of getting some 1/4" 3/8" and 1/2" round or square clear plexiglass rods (around $6 buys 20 ft of each size) and some aryclic solvent glue on a thick piece of plexiglass, That way I make my own socket holder set with the rods cut to correct length or all the same length and spacing to my own preference. Would a square or round rod be better?
The glue is very strong it is used to make aquariums.
PoorOwner is offline   Reply With Quote
Old 11-08-2007, 03:29 PM   #2
wilbilt
wilbilt's Avatar
Default Re: DIY socket organizer
That sounds like a good idea. I would bore some holes for the rods, though. You could build your own tray and design it so that it doesn't waste space like all the commercial offerings do.
wilbilt is offline   Reply With Quote
Old 11-09-2007, 12:40 PM   #3
NOMAD
Senior Member
If you use square rods you can custom position them so the size # is always readable.
Go for it.
NOMAD is offline   Reply With Quote
Old 11-09-2007, 12:43 PM   #4
Franz©
I just welded rods to the bottom of my socket drawer. It's worked for 20+ years.
Acrylics become very brittle when cold.
Franz© is offline   Reply With Quote
Old 11-09-2007, 05:25 PM   #5
grillmasterp
Senior Member
I would suggest getting your standard metal socket racks/rails and and mount them to a flat plate.
I have been very pleased with this rack
http://www.hechinger.com/web/catalog...spx?pid=179787
grillmasterp is offline   Reply With Quote
Old 11-09-2007, 06:20 PM   #6
Tiny Jackson
Senior Member
I did your idea of the homemade socket trays a couple weeks ago. However rather than using acrylic rod I used Delrin rod and UHMW Polyethlene for the base. Those should hold up better in a cold climate. I bought black for SAE and used white for metric.
Tiny Jackson is offline   Reply With Quote
Old 11-09-2007, 06:35 PM   #7
PoorOwner
Senior Member
Quote:
Where did you get these materials and what glue did you use?
Considering doing it in wood as well.. drill out a 3/4" plywood and press fit and glue some wood rods into it.
But I also like the socket ogranizer posted above, that seems to have the cheapest price per socket out of all the holders I have seen.
Old 11-09-2007, 08:33 PM   #8
Tiny Jackson
Senior Member
Wood would probably not hold up as well over time.
I got my material from McMaster-Carr. I live 1 1/2 miles from their warehouse so I just pick it up at will-call, however you can order it off their website and have it drop shipped to your location.
I drilled holes in the polyethlene 1/64" bigger than the rod and used Loctite Cyanoacyrolate(industrial superglue).
One cool thing is you can buy only the amount of material you need as the rod prices are by the foot and the flat stock is sold in a multitude of sizes.
I used 1/4" thick flat stock for the base and 1/8", 1/4" and 5/16" rod for the different socket drive sizes.
Old 11-09-2007, 08:56 PM   #9
SteveL
Senior Member
SteveL's Avatar
You can get the Harbor Freight version of the Hansons now for $6.99 for all three. Saw this in the flyer that I got two days ago. How bad can this be and for $6.99 you are way ahead of making your own. Part # is 99595
__________________
SteveL in St. Louis
'13 Mercedes SL550
'14 BMW 435i M-sport
'14 BMW 535i
SteveL is offline   Reply With Quote
Old 11-09-2007, 10:58 PM   #10
-lecroix-
I was thinking the same thing Steve ...
-lecroix- is offline   Reply With Quote
Old 11-10-2007, 11:56 AM   #11
wilbilt
wilbilt's Avatar
Quote:
They still waste way too much space.
How would I improve them?
1) Remove the silly hanger/handle thing.
2) Remove the useless divider thing.
3) run the deeps and shallows in opposite directions and move them closer together, making the whole thing about 2" narrower.
Old 11-10-2007, 01:10 PM   #12
PoorOwner
Senior Member
Hey guys I just ordered 3 of the VIM Tools one as listed above..
about $50 should 240 sockets. After some thinking I like it because you can arrange them freely and as tightely as you need, and you can bring the whole tray up to 80 sockets to your work area.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
