Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-20-2011, 08:01 PM   #1
Steevo
Senior Member
Steevo's Avatar
Default HF Toolboxes Workbench - Phase 3
Continued from this thread:
http://www.garagejournal.com/forum/s...d.php?t=120386
Well, I got started on the next phase of the HF tool cabinet workbenches today.
First I finished uncrating the tool boxes.
All were in good shape and no missing or damaged parts found.
I ended up with a huge pile of packing materials that I need to get rid of.
I cleaned out the corner where the workbench will go, and started arranging things.
I installed the foot inserts in the legs.
These are rated for 3500lbs. apiece, as are the feet.
I started welding up the cross-pieces and surface supports onto the legs I had previously built.
Note the missing gas bottle in that last picture. I ran out of 75/25 and had to call it quits for today.
Tomorrow, instead of getting an early start on the project, I’ll have to go to the welding supply for a tank exchange.
Anyone have a good method for removing the US general badges from the boxes?
They will cause a fit issue when the boxes are placed in the frames.
Stay tuned for more progress.
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is offline   Reply With Quote
Old 11-20-2011, 08:34 PM   #2
rburke65
Senior Member
rburke65's Avatar
Default Re: HF Toolboxes Workbench - Phase 3
Where did you buy the inserts? Did you "scratch build" the bases or buy? Thanks
rburke65 is offline   Reply With Quote
Old 11-20-2011, 08:38 PM   #3
wfochris
Senior Member
Nice. I have the same HF welder cart, but it doesn't like my ~110cf cylinder so well lol.
wfochris is offline   Reply With Quote
Old 11-20-2011, 08:38 PM   #4
twincam00
Senior Member
twincam00's Avatar
lookin great so far steevo!
twincam00 is offline   Reply With Quote
Old 11-20-2011, 08:41 PM   #5
Steevo
Senior Member
Steevo's Avatar
Quote:
The inserts and feet came from JW Winco (http://www.jwwinco.com)
All of the frame and legs is scratch built from standard steel tubing and angle.
__________________
Old 11-20-2011, 08:44 PM   #6
rburke65
Senior Member
rburke65's Avatar
Thanks for the reply.
Old 11-20-2011, 08:51 PM   #7
BigAl62
Senior Member
BigAl62's Avatar
To remove the emblems use nylon fishing line. Hold it tight and go behind the emblem using a sawing motion. Then use adhesive remover or WD40 to remove any remaining adhesive. Or you can try a heat gun or hair drier, I've used both methods with good results.
__________________
Stress: that confusion created when one's mind overrides the body's basic desire to choke the living crap out of some a**hole who desperately deserves it!
BigAl62 is offline   Reply With Quote
Old 11-20-2011, 09:09 PM   #8
TurboBlog
Senior Member
TurboBlog's Avatar
Looks great! Thanks for the threaded foot insert info too.
TurboBlog is offline   Reply With Quote
Old 11-20-2011, 09:47 PM   #9
fitz11
Senior Member
fitz11's Avatar
Looking good, look forward to seeing more progress! BTW that is the neatest pile of packaging materials I have ever seen! Lol
fitz11 is offline   Reply With Quote
Old 11-20-2011, 09:55 PM   #10
e30bradley
Senior Member
e30bradley's Avatar
your going to have the nicest work bench I'll probably ever see.. and to get rid of the packing materials make a nice big fire.
e30bradley is offline   Reply With Quote
Old 11-20-2011, 10:09 PM   #11
Steevo
Senior Member
Steevo's Avatar
Quote:
Thanks BigAl, I'll try that.
__________________
Old 11-20-2011, 10:13 PM   #12
Ray-CA
Senior Member
Ray-CA's Avatar
Send a message via Yahoo to Ray-CA
Dental floss works extremely well also.
Ray
__________________
Knowledge is knowing that F=ma. Wisdom is knowing why that is important.
Ray-CA is online now   Reply With Quote
Old 11-20-2011, 10:29 PM   #13
mixxmstrmike
Senior Member
Send a message via Yahoo to mixxmstrmike
Subscribed.
Great pictures and thanks for sharing your process!
Can't wait to see the finished product.
-Mike
mixxmstrmike is offline   Reply With Quote
Old 11-20-2011, 11:42 PM   #14
Kent Skinner
Wow - that's a huge amount of storage.
I'm following the progress.
Kent Skinner is offline   Reply With Quote
Old 11-21-2011, 07:36 AM   #15
Kevin54
Senior Member
Kevin54's Avatar
If you use fishing line to remove the badges, make sure you wrap the ends of the line around a wood dowel or something similar. Don't pull it with your hands for the fact is that it will cut you right now before you know it.
__________________
THE ADDITION
Kevin54 is offline   Reply With Quote
Old 11-21-2011, 07:53 AM   #16
buening
Senior Member
Nice job Steevo. I just finished the paint on my 2" square tubing workbench that is similar to yours. I'm only using 26" base cabinets on each side though.
__________________
1970 Mach 1
1970 Mustang Fastback
2003 Mustang
2005 F150 FX4
Licensed Professional Engineer, PE (Civil)
Licensed Structural Engineer, SE
buening is offline   Reply With Quote
Old 11-21-2011, 08:12 AM   #17
brucer
Senior Member
brucer's Avatar
I'm liking the tractor myself.
brucer is offline   Reply With Quote
Old 11-21-2011, 08:19 AM   #18
NUTTSGT
NUTTSGT's Avatar
We need more pics Steevo ! lol That's going to be a killer workbench when you get it finished.
BTW, do you know anybody with a woodburmer, that packing material would make great kindling and then recycle the c-board.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 11-21-2011, 09:09 AM   #19
purpony
Senior Member
purpony's Avatar
looking good!
__________________
26x26 attached with 13.5' ceiling and Lift
20x16 detactched with 11.5' ceiling for tractor/lawn eqip
-1989 Mustang Coupe- Twin Turbo, T56/RXT, DFI, Griggs/MM 563rwhp/610rwtq
-1998 Lincoln Mark VIII LCS - 18" mustang wheels, T-bird suspension, 3.73s, Jmod, Xcal3, Magnaflow
-2004 F-150 SuperCrew - 6" Lift, 35" M/Ts on 20x9s, Xcal, Magnaflow
-1998 Explorer Limited V8 AWD
-1988 F-250 Dually ATS Turbo 7.3
-1999 Buell X1 Lightning - Painted, Tuned, XB updates
-2007 JD 2320 CUT
purpony is offline   Reply With Quote
Old 11-21-2011, 09:18 AM   #20
csp
Senior Member
Kinda tough to get fishing line, dental floss, etc past the two little studs that stick out of the back of the emblem.
I just pried mine off carefully with a putty knife.
Cool IH Cub Cadet there! Wish I had a loader for mine, though I have no need for one with two real tractors with loaders.
csp is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
