Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-26-2005, 02:22 PM   #1
rdnkjeeper
Garageaholic
Send a message via Yahoo to rdnkjeeper
Default Homemade tools
I have been reading this site for a few days now and was thinking about what ya got for homemade tools? Don't know if this is the right spot or not.
Right now I can't think of anything that I have made or modified. I always like getting ideas. Pics would be great.
Thanks
rdnkjeeper is offline   Reply With Quote
Old 08-26-2005, 02:53 PM   #2
kartracer55
Senior Member
kartracer55's Avatar
Default
Hmmm The only thing I have made recently was a ghetto ass wrench. I had to make it out of 1/8 steel because of clearance, and Sears doesnt have metric tappett wrenches.
I used a piece of 1/8X1 1/2 steel flatstock and cut it with a jig saw then ground a recess in it... It works.
Welcme to the sight.
Jim
kartracer55 is offline   Reply With Quote
Old 08-26-2005, 03:13 PM   #3
rjspitz
Senior Member
rjspitz's Avatar
Default
I made an expolosion proof fan.
http://garagejunkies.net/showthread.php?t=437
rjspitz is offline   Reply With Quote
Old 08-26-2005, 04:12 PM   #4
rdnkjeeper
Garageaholic
Default
After thinking about it, I have made a "drift" out of an old shock and an awl out of a broken screwdriver. Of course I have also "made" wrenches with the big blue wrench. Bent for certain applications.
What else have you'll made?
Old 08-26-2005, 04:48 PM   #5
rsitzejr
Garageaholic
Default
I made a die that goes in my 20 ton press for bending metal with.
rsitzejr is offline   Reply With Quote
Old 08-26-2005, 09:00 PM   #6
trovato
Senior Member
Default
Quote:
Originally Posted by rjspitz
I don't see the fan pictures. I get a screen asking me to log in.
trovato is offline   Reply With Quote
Old 08-27-2005, 02:03 AM   #7
Luckydevil
Senior Member
Luckydevil's Avatar
Default
Quote:
Try it again, it should work now.
__________________
- Luke
Luckydevil is offline   Reply With Quote
Old 08-29-2005, 09:07 AM   #8
rdnkjeeper
Garageaholic
Default
No one else has any homemade tools? I think it would help people out to post what you have made.
I have also made a "rack" for the long tools that don't fit into my toolbox. I took some thicker sheet metal and bent it into a U, then I wired a peg board holder to the metal. It works great for holding my long extensions and breaker bars that don't fit in my tool box.
Old 08-29-2005, 09:27 AM   #9
astroracer
Senior Member
astroracer's Avatar
Default
I made a pair of chassis jig tables last year and this year I am building a chassis for an Astro Van Project on them...
astroracer is offline   Reply With Quote
Old 08-29-2005, 10:47 AM   #10
astroracer
Senior Member
astroracer's Avatar
Default
I also built a couple of spindle fixtures to hold the brake corner/spindle at ride height while I fab the Upper & Lower Control Arms.
The fixture bolts to an angle plate and the brake hat bolts to the fixture through the 4 washers. Works real well and the height is fully adjustable so the fixture can be used for a number of different applications.
Old 08-29-2005, 12:31 PM   #11
JJP
FNG
Default
Nice work astro. Looks like that'll do the trick.
JJ
JJP is offline   Reply With Quote
Old 09-01-2005, 12:37 AM   #12
erok01
Default
Can you say, CNC
erok01 is offline   Reply With Quote
Old 09-01-2005, 01:02 AM   #13
Luckydevil
Senior Member
Luckydevil's Avatar
Default
Quote:
Originally Posted by erok01
Can you say, CNC
Is that for real?
__________________
- Luke
Old 09-01-2005, 02:16 PM   #14
kartracer55
Senior Member
Default
HAHAHA THATS AWESOME!
Jim
Old 09-01-2005, 02:44 PM   #15
bluesman2a
Senior Member
Default
I got tired of pulling the handle on my tube-bender... Home-brew hydro-bender... Built the stand out of 1/2" X cold-roll, using parts as discovered from an off-road forum. Now I can bend tube anywhere I can roll it and plug into a 110V outlet.
http://www.printroom.com/ViewAlbum.a...lbum_id=175960
bluesman2a is offline   Reply With Quote
Old 09-01-2005, 02:54 PM   #16
kartracer55
Senior Member
Default
Thats an AWESOME bender... Gotta love pirate 4x4 lol. I need to learn to lay down a strong weld so I can work on building something like that one of these days.
Jim
Old 09-01-2005, 04:38 PM   #17
muddy
Senior Member
Default
Astroracer,
Gotta love creativity and metalworking....... how well are those little caster holding up to your chassis jig? I've gotta believe they are at the extreme end of their ability to support that weight and be rolled around....... any photos of the "astro" that you race? Keith
muddy is offline   Reply With Quote
Old 09-01-2005, 04:41 PM   #18
bluesman2a
Senior Member
Default
Quote:
Yep, it's a direct rip from POR... based on Jay K's original here:
http://www.mindspring.com/~jayk5/bender/
As for my stand, I have no problems laying down a bead (Miller 251), but none of the welding on the stand was structural. Essentially, it's all just to hold the bender up. The stand itself is held together with 3/4" grade 5 bolts and 1" .120 wall tube for stand-off's. So technically speaking, if you can drill a hole straight you COULD build one of these yourself... Now coming up with something to mount it on would be another story.
Old 09-01-2005, 04:43 PM   #19
muddy
Senior Member
Default
Oh yeah,
By the way, most of you probably have never hear of Mittler Bros. Machine & Tool out of Foristell, MO......so thought I'd let you guys know about them. If you are into any serious metal fabrication at all they are THE place to buy tooling for that application. I am friends with Mike Mittler that owns the company. He's your typical, hard working racer type that started as Rusty Wallace's crew chief up through ASA racing and then as Rusty moved on up he went off with his business. He also owns a Nascar Truck Team. Anyways, has equipped alot of "Cup" raceshops......makes the ultimate tubing notcher, tubing benders, bead rollers,etc....and floater 9 inch rear ends. He also has a pretty good software program for calculating bends for those that don't like doing it the old fashioned way....... Keith
Old 09-01-2005, 11:49 PM   #20
bluesman2a
Senior Member
Default
Quote:
Originally Posted by muddy
Oh yeah,
I don't know if I would say THE place... They tend to be middle-high end professional grade. I know some SERIOUS hobbiests (myself included) who would LOVE to have one of their tubing notchers, but unless you are selling parts, it's hard to justify a $5K (yes, that's THOUSAND) notcher . I've got some of their instrumentation, and while it's pricey, its certainly top notch...
On the other front, I'll certainly agree! They have some nice parts for setting up Ford 9" rear ends!!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tool Manufacturers kartracer55 General Tool Discussion 316 11-16-2014 11:28 PM
what are differences in brands? sprackydoo General Tool Discussion 20 09-29-2014 03:49 PM
Man Finds His Stolen Tools For Sale On eBay JohnHenrys48 General Tool Discussion 19 12-03-2008 10:44 PM
Who makes different brand tools RedRacer74 General Tool Discussion 8 01-17-2006 01:39 PM
Craftsman wrenches... Bob General Tool Discussion 37 06-25-2005 11:24 PM
