Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-27-2011, 03:29 PM   #1
KMinAF
Senior Member
KMinAF's Avatar
Default Kerosene or diesel in my heater?
What if any are the advantages or disadvantages to the two types of fuel? I currently have been using kerosene in my torpedo style heater but diesel is cheaper. I have a 150000 BTU heater that I use in my garage (with adequate ventilation) but I was concerned that diesel might soot up the heater or have a strong smell where as if I understand correctly, kerosene burns cleaner and doesn't smell as bad.
KMinAF is offline   Reply With Quote
Old 11-27-2011, 03:31 PM   #2
ptschram
Senior Member
Location: In a Snap-On truck somewhere around Churubusco, IN
Default Re: Kerosene or diesel in my heater?
I mix used engine oil with diesel and burn it in a Salamander heater. If you adjust the fuel pressure just right, it won't smoke, won't stink and will be pretty darned efficient.
ptschram is offline   Reply With Quote
Old 11-27-2011, 03:39 PM   #3
ishiboo
Senior Member
Quote:
You're correct. Kero is a lot nicer to be around, I agree it burns cleaner, less soot and doesn't smell as bad. I have a 215k BTU forced air heater and I run both in them depending on what I'm doing. I don't hang around too much with the diesel fumes though.
You may want to price going with a ventless heater or an actual vented forced air heater... the advantage of the ventless is they're still 100% efficient like the heater you have now.
ishiboo is online now   Reply With Quote
Old 11-27-2011, 04:45 PM   #4
Senior Member
Outlawmws's Avatar
Find a place that sells kero bulk and it should be about the same $$ as diesel.
Unless your heater is designed or can be re-jetted for diesel, using the wrong fuel is a bad idea.
If this is any type of wick heater, don't do it...
__________________
NINE's (Nine4GMC) Flood recovery thread: Please help if you can; at least give him and his some moral support!
Outlaw's Camp Gear Thread
Outlaw's Shed Thread
Outlaw's Garage Sale
- For sale or trade... Last Update w/new items 8/21/2012 - P9, (More auto books)
Outlaw's Garage sale - Feedback
"It might be for sale or trade, it never hurts to ask..."
Outlawmws is offline   Reply With Quote
Old 11-27-2011, 06:01 PM   #5
jsaw
Senior Member
I burn diesel in mine, It doesn't smell amy worse than kerosene, but they both smell bad to me.
jsaw is offline   Reply With Quote
Old 11-27-2011, 06:53 PM   #6
fatfillup
Senior Member
Diesel has more BTU's per gallon then Kerosene and will burn hotter and also give better lubrication to the fuel pump. Kerosene will burn cleaner and therefore smell less. Big thing is both put off CO so ventilation is critical. If you start getting headaches after working in the shop for a while, you don't have enough ventilation.
If this is your home shop and is used part time, crack a door open for fresh air and you should be fine. If this is a full time shop, get heaters that vent the exhaust outside. Don't kill yourself to save a few dollars.
fatfillup is offline   Reply With Quote
Old 11-28-2011, 01:05 PM   #7
spongerich
Senior Member
spongerich's Avatar
I have a 150K BTU torpedo heater and found diesel to work VERY poorly in it. The smell was intolerable. Around here, kero from the gas station is about the same price as diesel.
__________________
Tool Junkie
Check out my YouTube Channel for machine shop videos.
See my eBay listings here.
spongerich is offline   Reply With Quote
Old 11-28-2011, 01:17 PM   #8
jf781
Quote:
Same here with the exception of old diesel. First got my heater it had some in it and I burnt that for awhile and couldn't stand it. Switched to Kero and it smelled better. Got sick of paying for it ($15 for 2.5 Gal at menards) so I switched back to diesel and the fresh stuff had the same smell as the kero.
I can run mine for hours without getting a headache but my garage is also made from an old barn boards that was sided over it (prev owner) so there is lots of natural vents in there. It's also pretty good sizes as well (rougly 30x40) so both of those help.
My heater is also a multi-fuel so it is designed for either fuel as well as a few others.
jf781 is offline   Reply With Quote
Old 11-28-2011, 02:26 PM   #9
rlitman
Senior Member
I've got two torpedo heaters (60kBTU) that I run with diesel. They foul the spark plug a lot (hot surface ignitors don't have as many issues with diesel), but I made my own ignition system with a Beckett solid state transformer that doesn't foul (and has the extra spark needed to get diesel started reliably).
My biggest problem with diesel is the smell. It's awful.
If I adjust it rich, it smokes, and makes CO. If I adjust it lean, it doesn't make CO, but makes so much NOx that it burns my eyes. I haven't been able to find that happy medium yet, but kerosene is SO darned expensive around here.
rlitman is offline   Reply With Quote
Old 11-28-2011, 05:51 PM   #10
diesel research
Senior Member
They don't sell kerosene at the pump anymore???
__________________
Quote:
Originally Posted by Chuck122 View Post
Whenever I see someone using a claw hammer for mechanical work, I assume he is a retard.
diesel research is offline   Reply With Quote
Old 11-28-2011, 06:13 PM   #11
fitz11
Senior Member
fitz11's Avatar
i use kerosene in mine. I get it from the pump at the local fleet farm and its still $4.49 a gallon right now.
fitz11 is offline   Reply With Quote
Old 11-28-2011, 06:40 PM   #12
Senior Member
Outlawmws's Avatar
Quote:
Depends on where you live, and how hard your willing to look. In big metropolitan areas it is harder, but not impossible.
The biggest cost is packaging. they charge a lot for those little one gallon cans, or even a 5 gallon can. I used to get it pumped bulk from a drum at a local hardware store, but they are gone.
Actually, its been years since I had to buy any; I can usually get it for free or close to it for the quantity I use, I still have at least 5 gallons around.
__________________
Old 11-28-2011, 07:40 PM   #13
route246
Senior Member
route246's Avatar
Anyone know in the SF Bay Area where to get kerosene in bulk besides Rotten Robbie gas stations? I can get it in 1 and 5 gallon cans at Home Depot but it's horribly expensive. Rotten Robbie charges $5.79/gal now, up $1.00 from last year even though crude is cheaper now. I'm not sure if $5.79/gal bulk is a good price or not but it sure heats nice and clean. What is everyone paying around the country this year?
route246 is offline   Reply With Quote
Old 11-28-2011, 07:56 PM   #14
bluecomputer
The lukoil I go to sells kerosene.
bluecomputer is offline   Reply With Quote
Old 11-28-2011, 08:09 PM   #15
Senior Member
Outlawmws's Avatar
Quote:
All fuels are more $$ in Kalifonia... Take a look at the gas pump prices we pay compared to ANYWHERE else. If you can, get it when you are out of the immediate bay area... (Just like gas)
__________________
Old 11-28-2011, 09:11 PM   #16
route246
Senior Member
route246's Avatar
So we're driving down from NorCal to SouCal next month down I-99 through farm country. Can I get it cheaper somewhere along the way, either on I-5 or I-99 in the central valley? It's relatively inert and safe to transport and I'm willing to pickup 20 gallons if there is somewhere that's much cheaper than $5.79/gallon. We'll be in the SUV so we have space to stow the blue 5-gal cans.
Old 11-28-2011, 09:32 PM   #17
Senior Member
Outlawmws's Avatar
Maybe in Modesto or if you go that far, Fresno?? I have no specifics, but if gas/diesel is cheaper out there it follows kero should be also... maybe someone out in the Valley will Chime in. As I mentioned I haven't had to buy it retail in a long time. It might be worth hitting a truck stop and seeing what they have.
__________________
Old 11-29-2011, 12:21 AM   #18
route246
Senior Member
route246's Avatar
Yeah, if someone can give me specific leads, I don't mind calling ahead of time. I just don't know where to start.
Old 11-29-2011, 12:38 AM   #19
chevy302dz
Senior Member
I've run diesel in mine for years since all the places selling kero stopped selling it or closed up all togeather. Never had a issue running the diesel.
chevy302dz is online now   Reply With Quote
Old 11-29-2011, 01:20 AM   #20
Senior Member
Outlawmws's Avatar
Try "modesto bulk kerosene" in Google...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
