Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 11-15-2007, 07:04 PM   #1
engnerdan
Senior Member
Default Heater Size
Would a 60,000 BTU (45,000 BTU output) heater be too much for a 24X24 detached garage that has "ok" insulation (R11 foam board on the underside of the rafters (vaulted ceiling) and R13 on 3 walls and a poorly insulated garage door)?
I got a good deal on a dented Hot Dawg (half price) and I jumped on it, from the research I have done it looks like this is going to be slightly more heater then I need but not much. Anybody out there using this size heater in a simular setting.
-Dan
engnerdan is offline   Reply With Quote
Old 11-15-2007, 08:20 PM   #2
Dave Carney
Senior Member
Dave Carney's Avatar
Default Re: Heater Size
Thats not too much in Minnesota, particulary if you have it on a thermostat when its on (so you aren't having to turn it on and off manually). I run a 75k Hot Dawg in my 720 square foot attached garage in Kansas. It will just run less often, thats all.
__________________
My shop build thread:
http://www.garagejournal.com/forum/s...ead.php?t=3194
My waterless restroom thread:
http://www.garagejournal.com/forum/s...ad.php?t=30690
Dave Carney is offline   Reply With Quote
Old 11-15-2007, 10:09 PM   #3
mulepackin
Senior Member
mulepackin's Avatar
I too have a 75,000 btu Hot Dawg, in a 24x32x9 detached in Central Mont. A bit high according to Modines specs, but I haven't regretted it a bit. Mine was also a scratch and dent deal. All cosmetic damage. Just be sure there's no damage to the "working" parts of the unit. Congratualations on the good deal.
__________________
There's nothing heat and pressure can't overcome.
mulepackin is offline   Reply With Quote
Old 11-19-2007, 10:22 PM   #4
engnerdan
Senior Member
I just got my 60K scratch and dent unit today from www.greenhousemegastore.com, what a deal it looks like someone dropped another heater on the top, or maybe hit it with a fork from a froklift but minor damage, pounded 80% of the damage out in a couple minutes.
I did a test firing on the work bench, and this thing is great, I don't think it will be too much heater at all. Nice warm gentle heat compared to the roar of my old kerosene heater.
I can't wait until the end of the week when I an done installing it and can use it.
Old 11-20-2007, 07:43 AM   #5
ksp
ksp's Avatar
How di you locate the scratch and dent item? Do they advertise them? Would like another Hot Dawg as I have one in my main shop but don't want to pay full price for a haeter that will be seldom used.
ksp is offline   Reply With Quote
Old 11-20-2007, 08:33 PM   #6
RonRock
Senior Member
RonRock's Avatar
Quote:
Try this link
http://www.greenhousemegastore.com/p....asp?dept=1210
I think it will work. If not follow engnerdan's link then on the left is a Heating Solutions or something to that effect. Then on bottom is Scratch & Dent.
Cheers
Edit, The link works.
Last edited by RonRock; 11-20-2007 at 08:34 PM. Reason: Tested link after posting, it worked.
RonRock is offline   Reply With Quote
Old 11-20-2007, 09:22 PM   #7
engnerdan
Senior Member
Thanks, I didnot have time to post that when I was at work today. Yes that is where I got my heater.
Old 11-21-2007, 08:10 AM   #8
ksp
ksp's Avatar
Thanks for the link, I must be blind!!!!!!!!!!
I'll check it out.
Old 11-21-2007, 10:10 PM   #9
ksp
ksp's Avatar
I ordered a 75K propane unit from them today so we shall see how it works out. Hopefully just a little dented. Good price there. Would like to go to a 100K NG unit but shipping was much higher.
Old 11-22-2007, 01:43 AM   #10
engnerdan
Senior Member
I installed mine tonight, took about 4-5 working hours and its fricken awesome. Clean, warm heat that my wife approves of, she absolutely hated the kerosene heater and was not fond of the sunflower heater, but this has no smell after the first firing.
It also does not seem to go through the propane too quickly. The 60K unit was not too big for my poorly insulated garage, I had it running about once an hour for about 20 minutes at a time and that is with 2 cars in the garage that it has to heat.
I am looking forward to cold winter nights spent in the garage now (I know my wife is not).
Dan
Old 05-15-2008, 09:14 AM   #11
mtcone
Junior Member
-Dan
An easy way to tell what will be required to heat your garage or workshop is a heat load calculator. You just put in the space that you need to fill and some details about the insulation and how warm you want it, and the calculator will tell you which heater would be best for your particular situation. It is a great resource. You may want to check it out.
mtcone is offline   Reply With Quote
Old 11-23-2009, 01:27 AM   #12
megamon
Junior Member
you can see at searspartsdirect.com
megamon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
