Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 12-14-2011, 12:47 PM   #1
1967marti
Senior Member
Default Adding a jib crane or engine hoist to a garage with wood frame?
I have all of my drywall out in prep. for instaling OSB and external wiring run through metal electrical pipe. SO.... i was thinking of adding a jib crane or a rolling engine hoist to help me move around stuff or just to hold while i spray it. Any ideas or advice?
It only needs to hold 100-200 lbs so i'm thinking i can weld one up from sq. tubing and bolt it to a beefed up section of the wall?
1967marti is offline   Reply With Quote
Old 12-14-2011, 01:23 PM   #2
rwhite692
Senior Member
rwhite692's Avatar
Default Re: Adding a jib crane or engine hoist to a garage with wood frame?
You would be better off with something which attaches to the slab.
__________________
My 24x36 detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=16310
rwhite692 is offline   Reply With Quote
Old 12-14-2011, 01:24 PM   #3
kbs2244
Senior Member
You have to remember the levering forces at the foot of the leg.
When designed into a new building there is a foot paralleling the beam under the floor pour.
Retrofits should have nice deep hole and concrete foundation to resist the sidewise push.
I have seem cross bracing at the top of the post also.
If you can discipline your self to 200 pounds and do some good wall base anchoring you might get away with it.
If you go with a bridge crane setup, all the forces are now vertical.
kbs2244 is offline   Reply With Quote
Old 12-14-2011, 01:32 PM   #4
Jagmandave
Senior Member
Jagmandave's Avatar
One of those foldup two ton engine hoists from HF are only $200.....
I like the idea of a Jib crane, but it is limited in that you have to move the load under it, where an engine hoist can move to the load, and carry it around the shop.
Jagmandave is offline   Reply With Quote
Old 12-14-2011, 01:37 PM   #5
duggie
Senior Member
duggie's Avatar
I have a hoist in my garage that is made from (3) 2x8 and spans the 18'-0" width of my garage. The ends sits on built-up wood posts in the walls and when I go to lift something, I also have 2 wood posts that I wedge in under the hoist beam. When those posts are installed, the span between posts is 8'-0".
I have lifted V8 engine and transmission combos with this setup and I have not had any issues.
I will try and find (or take) some pics of my setup and add them to this post.
__________________
It's not easy maintaining this level of insanity !!!
duggie is offline   Reply With Quote
Old 12-14-2011, 04:00 PM   #6
Tripp P.
Senior Member
Tripp P.'s Avatar
I have a gib crane in my garage. Its bolted to the slab. Its been handy. The loads will now be limited for it. The 1st one was very taxing and scary.
Check it out at:
__________________
Check out the build at:
Tripp's Garage
Tripp P. is offline   Reply With Quote
Old 12-14-2011, 05:07 PM   #7
Lkdelta
Senior Member
Lkdelta's Avatar
I have 3 2X6's spanning the 12 foot....They are glued and nailed
I used "post-style" floor jacks to hold the ends up when the lift is loaded
Other wise the ends are just sitting on short 2X4 to stay up there when not in use
__________________
Take a look what your USA honorable military service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
Lkdelta is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
