Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 12-15-2011, 08:14 PM   #1
rvr6000
Senior Member
rvr6000's Avatar
Default Air Hose: Rubber vs Polyurethane
For you folks with the 1/4" polyurethane air hoses.....how do you like them over your standard 3/8" rubber hose?
Have been thinking about picking up a couple for projects around the house (finishing the basement) and thought they might be a little lighter and easier to work with. They would pretty much only be used with the air nailers and not outside or drug across any rough cement or anything like that.
Thanks for your input.
rvr6000 is offline   Reply With Quote
Old 12-15-2011, 08:21 PM   #2
ibedayank
Senior Member
Default Re: Air Hose: Rubber vs Polyurethane
poly hose when it gets could is not fun as it gets stiff
rubber stays flexible at any temp and lasts a lot longer
ibedayank is offline   Reply With Quote
Old 12-15-2011, 08:48 PM   #3
rlitman
Senior Member
I haven't had any issues with poly in the cold. Maybe you're thinking of the nylon coil hoses.
rlitman is offline   Reply With Quote
Old 12-15-2011, 08:51 PM   #4
mauls
Senior Member
mauls's Avatar
I've had no problems with my poly hose
mauls is offline   Reply With Quote
Old 12-15-2011, 08:56 PM   #5
Dale B
Senior Member
Dale B's Avatar
I think it depends on the brand, I used orange and blue poly hoses for years and they only stffened a little in the cold . But the grey ones were useless , stiff as hell.....Red rubber is the best for flexibility , but don't drag it anywhere close to the corner of a vehicle, it reaches out and jams itself on the "V" on the bottom of the tire .!!!
Dale B is offline   Reply With Quote
Old 12-15-2011, 09:43 PM   #6
rvr6000
Senior Member
rvr6000's Avatar
Thanks everyone.....Think I'll go pick one up tomorrow. I'll just be using it in the basement so cold won't be an issue. That rubber hose is just so bulky I was looking for something a little easier to manage in a small area.
Old 12-15-2011, 09:57 PM   #7
ujmchris
ujmchris's Avatar
Not sure what these things are made of ("Premium Hybrid Polymer") but they're the only air hose I'd ever buy any more. Light, flexible, tough, rolls up nicely, no memory what so ever. Struggled for years with others in my sometimes heated shop, some were better than others, but these things are just plain awesome, even at below 0 temps.
http://www.amazon.com/Legacy-Manufac...ref=pd_cp_hi_0
ujmchris is offline   Reply With Quote
Old 12-16-2011, 12:26 AM   #8
Greatbear
Senior Member
Greatbear's Avatar
I love my Flexeel poly hoses. Very lightweight, and no effects from temperature. About the only thing I don't like about them and similar hoses is that they are so light, they tend not to lay flat on the floor if they are even slightly twisted. I've tripped and cussed them for that. But if you plan to do overhead or elevated work, or are pulling hose around in tight areas, they are da bomb. For working in the garage, I use reinforced rubber hose. That which came with my Reelcraft hose reels has been going strong for years.
Greatbear is offline   Reply With Quote
Old 12-16-2011, 12:34 AM   #9
rlitman
Senior Member
1/4" polyurethane coils are all I use with my nailers. Just stick to the 25' hoses, and forget the 50' ones. 50' is too much for a 1/4" hose. You won't get much flow out of that.
I haven't had any flexibility issues with my rubber hoses either, but they do jam under tires, and are heavy. I really like my orange Goodyear Pliovic hose. It's much lighter than rubber, and is still plenty flexible in the cold.
Old 12-16-2011, 04:24 AM   #10
sdowney717
Senior Member
I bought a cheap rubber hose made in India and got a few years out of it.
It failed in 3 ways.
The rubber started cracking all over.
The rubber started to disintegrate, so got black all over everything, especially your hands.
The cracks got big enough to leak air, and the ends swelled up as the inner cords broke.
Frankly I was very unhappy with it.
I bought a green poly 3/8 hose and it is stiffer but durable.
sdowney717 is offline   Reply With Quote
Old 12-16-2011, 04:50 AM   #11
Senior Member
theoldwizard1's Avatar
I bought poly a couple of years ago and cussed it every time I had to use it in winter.
I just bought a rubber hose. A bit heavier, but it least you can coil and uncoil it when the temp is below 50.
theoldwizard1 is offline   Reply With Quote
Old 12-16-2011, 04:59 AM   #12
geologist
Senior Member
geologist's Avatar
I'm a fan of the rubber hoses myself. They seem to hold up better for me.
geologist is offline   Reply With Quote
Old 12-16-2011, 11:42 AM   #13
rlitman
Senior Member
I think you're confusing polyurethane hoses (which I've only seen in the "coil" variety) with PVC hoses, which turn hard and brittle when cold.
Old 12-16-2011, 11:48 AM   #14
porcupine73
Senior Member
porcupine73's Avatar
I made all my air hoses from the 1/2" Goodyear hose they used to sell (maybe still do) at HF, was like $20 for 50 feet. That stuff has been great, very durable, and still flexible in the cold.
I got 100' of that 1/4 poly hose, and it does work OK, but it kinks easily, and yes in the cold, it does not want to cooperate.
porcupine73 is offline   Reply With Quote
Old 12-16-2011, 12:08 PM   #15
rwhite692
Senior Member
rwhite692's Avatar
Poly hoses coil up like crazy and are generally a huge PITA, however, when you are doing interior remodeling work inside homes, I do like them in that situation because (unlike rubber hoses) they wont leave marks on anything that they come in contact with.
In my shop and for auto service related stuff, black goodyear rubber hose, all the way.
__________________
My 24x36 detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=16310
rwhite692 is offline   Reply With Quote
Old 12-16-2011, 06:33 PM   #16
Steves32
Senior Member
Steves32's Avatar
Red rubber hoses lay flat on the floor when stretched out from retractable reel. I don't need something else to trip over.
Steves32 is offline   Reply With Quote
Old 12-16-2011, 07:21 PM   #17
MustangRick
Senior Member
I have the airflo hose from Home Depot and it worked great for roofing, it does tend to kink if you unroll it with no air. It doesn't want to coil up on itself warm or cold.
MustangRick is offline   Reply With Quote
Old 12-16-2011, 07:42 PM   #18
pacmktg
Senior Member
100% Polyurethane Reinforced Straight Hose by Coilhose is 1/3 the weight of rubber, stays flexible in cold weather (originally designed for carpenters in snow country), and is more durable than rubber. It's 2 weakness's are it is plastic so it will melt around slag from welding, and because as another poster mentioned, it is so lightweight is does not lie flat until it has been used for a few weeks.
Do not confuse cheap Chinese Polyurethane or any PVC hose with a good domestic Polyurethane from Coilhose or Contractors Choice as PVC hose does not stay flexible in cold and the cheap knock offs are typically not all Poly.
pacmktg is offline   Reply With Quote
Old 12-16-2011, 07:43 PM   #19
pacmktg
Senior Member
POlyurethane is also non-marking, so it is great for finish carpentry as is does not mess up baseboards.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
