Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 12-17-2011, 07:08 PM   #1
ia bhtr
Junior Member
Default electric heat revisited , 1200 sq ft
Hey guys , got a 30x40x9 pole shed , finished inside , insulated walls & ceiling , just finished the insides and now looking for heat , thinking electric with the ability to get to 70 degrees , in Iowa so we do get some cold days/nites ...... mostly keep the shed above freezing but want to warm it up if I wanta work on the Chevelle or wifeys old Caprice
Thoughts ??
Thought about LP and may still go that way but a furnace , and a propane tank will be spendy and with what LP is costing these days , thinking electric very well maybe cheaper in the long run , Thanks Dan
ia bhtr is offline   Reply With Quote
Old 12-17-2011, 07:20 PM   #2
StaggeringGoat
Senior Member
StaggeringGoat's Avatar
Default Re: electric heat revisited , 1200 sq ft
You will need a BIG heater. Like 10kw at least. Electricity is the most expensive source of heat there is.
StaggeringGoat is offline   Reply With Quote
Old 12-17-2011, 07:40 PM   #3
ia bhtr
Junior Member
actually , in my part of the world , its the cheapest
Old 12-17-2011, 08:15 PM   #4
Mario
Senior Member
Quote:
Exactly! Same here in Quebec, electricity is 0.08$/kwh.
When heating oil is over .53$/l, electricity is cheaper. Natural Gaz is not available in my area.
__________________
Toys: Mitsubishi Galant VR-4 1992, Polaris RZR570
Mario is offline   Reply With Quote
Old 12-17-2011, 09:07 PM   #5
RodneyPierce
Senior Member
RodneyPierce's Avatar
ia, nice to see another iowan on here. I would look at natural gas heat if available for you. I am heating mine with natural gas, and its really not bad cost wise. I keep it at 55* all the time, all winter long. I cant imagine what it would cost to heat the garage with electric here. Unless you went with 100% radiant heat, but that would require quite the heater. I may be wrong, but would think it would get mighty pricy mighty quickly.
__________________
Quote:
Originally Posted by Eldogg View Post
Being a Hotrod Builder I see this all the time. I call it "Show it or Fake it till you make it."
RodneyPierce is offline   Reply With Quote
Old 12-17-2011, 09:36 PM   #6
Dragster Racer
Senior Member
In Illinois, I have tried the electric heat thing, and after ONE MONTH, gave up on that stuff. I used the online calculators to figure the cost, and electric should have been cheaper. NOPE. The nuke plant had to keep one reactor going just for me. I have an lp tube heater now. Not cheap, but way cheaper.
Dragster Racer is offline   Reply With Quote
Old 12-17-2011, 10:46 PM   #7
ia bhtr
Junior Member
Quote:
Thats the main problem , natural gas isnt available where I live , main reason that I was thinking electric was the local home owners who have switched from LP or fuel oil to electricity for heat , they have all significantly lowered their heating bills , guess I thought if it worked in a home it would in an insulated out building as well
Old 12-17-2011, 10:54 PM   #8
1BADLS1tuner
Senior Member
1BADLS1tuner's Avatar
Well where i live i think electric is actually the cheapest to heat with....
$0.065 per KW!!!
I have a 32x48x12 im currently building and am going to be using a goodman air handler with 15 or 20KW heat strips... this will allow me to add ac/heatpump later on
for $500-800 you can get a new goodman air handler that will be 10x the heater than any of the electric "garage" or "shop" heaters you see.
In the winter i went from a $150-200 gas bill and $60 electric bill..... to just a $100-$120 electric bill when i installed my airhandle/heatpump!!! Thats over $100 a MONTH! (this is in my house)
__________________
32x48x12 Garage Build: http://www.garagejournal.com/forum/s...d.php?t=118694
1BADLS1tuner is offline   Reply With Quote
Old 12-18-2011, 09:59 AM   #9
ia bhtr
Junior Member
Quote:
$0.065 per KW!!!
Those are the kind of #s I am hearing after converting around here also
Old 12-18-2011, 10:24 AM   #10
Voi
Senior Member
Electric is cheap in my area as well. I have heard good things about radiant cove heaters as well as the large 4 x 2 radiant heat panels. I have the cove heaters but only because they are distributed by my local energy supplier and you can get cheap factory seconds.
I haven't looked into the radiant heat panels in a while but I believe the cheapest I found were from Northern Tool. It's been a while so I don't even remember the product name.
From people who have used both it seems like the panels are preferred. The cove heaters are mounted on upper walls so wooden cabinets can't be anywhere near them. The panels are ceiling mounted so other than lights can be mounted pretty much anywhere and directed at thermal mass sources.
But I think you'd need somewhere in the area 11,000 watts of electric resistive heat so that could get expensive. Google is down at the moment so I can't look up any links for you.
Voi is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
