Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-24-2007, 10:52 PM   #1
Kusto
Junior Member
Default Most Common 3 Car Garage Size
I am in a bit of a quandary wondering what is the most common size of 3 car garage as I am going to be building in the spring and am unsure what is best size to go with. I know the old adage that you never have enough space, but I only have limited space.
__________________
Current Garage - Attached Garage 22x24' with 10' wall height.
Comming Soon - 38x32' with 12-14' wall height. Looking for ideas at this point.
Kusto is offline   Reply With Quote
Old 11-25-2007, 10:53 AM   #2
wmonroe
Senior Member
wmonroe's Avatar
Default Re: Most Common 3 Car Garage Size
My garage is 28' deep by 30' wide with 2 8'x10' doors. I consider it a two car. A buddy of mine though has a 30'x30' and has a 9'x7' and a 16'x7'(?) garage doors and he parks three cars in it. I park two 3/4 ton long bed trucks in mine and want to be able to work in there without pulling the trucks out. So putting a third vehicle in mine is not an option. My buddy though only parks cars in his and doesn't really do much other than park his cars in there so it works fine for him.
I would say depending on how many vehicles and what size you want to park inside and if you want to be able to work inside with the vehicles in there would determine your size.
That seems about as clear as mud.
Will
wmonroe is offline   Reply With Quote
Old 11-25-2007, 11:46 AM   #3
Kusto
Junior Member
Will - Is there a chance you could post some pictures of your garage. I am planning on going with 12-14' walls and will have one 10x12 (or 10x10) and one 10x16 so I'm thinking 36 wide. Is 28 feet deep plenty deep enough to accommodate your trucks, benches and still have room to work off the ends of the trucks? I am planning on putting in a two piece bath as well in the one corner.
__________________
Old 11-25-2007, 12:15 PM   #4
67 455 Bird ragtop
Senior Member
Mine is 40 across by 30 deep with 3 8x8 doors with a 10' area on one end for work space. Also 12' walls for a lift in the bay with the extra 10'. Just breaking ground. Hope to have walls and roof up by .
__________________
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman 31x18.5x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline   Reply With Quote
Old 11-25-2007, 07:11 PM   #5
flesburg
Senior Member
Most attached garages these days are too small. We had a house with a 20x22 garage called "2 car". It was a no car garage.
I suggest minimum of 24' deep, (28' better, 30' best) x 12' to 15' width for each space you want to park a car. So minimum 24' x 36' and ideal 30' x 45'. With a 30 foot depth you will have room in front of the cars for a work area or for tools, and with 15' for each car you will have room to open the doors and room between them for other stuff. If your lot space will allow it you will not be sorry you went for 30x45, and it will not cost that much more than a small 24 x 36 building.
flesburg is offline   Reply With Quote
Old 11-25-2007, 08:24 PM   #6
SteveL
Senior Member
SteveL's Avatar
Mine is 38' x 22' and I rally like having the extra width. You can park with enough space between the cars to not worry about door dings etc., plus I can have one on jack stands for a while and not interfear with normal parking. I wih it was a little deeper, but I could not go any furthur. One 16' and one 9' door. The 16' door is about 7' from the side wall and the 9' door is about 2' from the other side.
__________________
SteveL in St. Louis
'13 Mercedes SL550
'14 BMW 435i M-sport
'14 BMW 535i
SteveL is offline   Reply With Quote
Old 11-25-2007, 09:28 PM   #7
Bull
Bull's Avatar
I have a 24x32, with parking for two cars on the front gable end and a third bay on the southeast eave.
__________________
EUDAIMONIA
"It Pays to Stay in the USA!"
Bull is offline   Reply With Quote
Old 11-25-2007, 09:40 PM   #8
Falcon05Dad
Falcon05Dad's Avatar
Mine is 42'x32' with 18'x9' and 10'x10' doors in the front and an 8'x8' rollup utility door on a gable end.
Falcon05Dad is offline   Reply With Quote
Old 11-25-2007, 09:46 PM   #9
DynoDave
Senior Member
DynoDave's Avatar
Mine is 26' deep, and 36' wide.
__________________
DynoDave
WPC #12304
POCI #72200
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
1988 Pontiac Firebird TransAm
DynoDave is offline   Reply With Quote
Old 11-25-2007, 11:59 PM   #10
Thomarann
Senior Member
Thomarann's Avatar
Planning a 30 x 32 with 11' ceilings to be breaking ground in the next few weeks. It is a one car garage/shop.
Marc
__________________
1991 964 C4 Coupe - Black/Black not quite stock...
My current 30x32 shop build is here.
The reason I built this shop is here.
Thomarann is offline   Reply With Quote
Old 11-26-2007, 01:32 PM   #11
1320stang
Senior Member
1320stang's Avatar
I vote 80'x120' as a good size for a 3 car garage.....
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1973 F-100 longbed
2002 Pontiac Grand Prix
2003 Explorer SportTrac
2005 Honda Accord
2008 Mercury Mountaineer
2015 F-150 Screw 5.0 2wd
Quote:
Originally Posted by raccoon View Post
PS: I'm a girl..
1320stang is offline   Reply With Quote
Old 11-26-2007, 02:02 PM   #12
boiler7904
Senior Member
boiler7904's Avatar
Quote:
I guess it depends on what has to fit in the garage. I'd say that you want to be at least 26 or 28 feet deep to allow for a vehicle, workbench, and walking space at both ends. Width would be at least 12 feet per bay plus 2 feet on each end for storage or 40 feet total. If you'll end up with kids bikes / toys or lawn equipment, you might want to go with 4 or 6 feet on the ends for a total of 44 to 48 feet. If you want interior stairs (not a pull down) that will affect either length or depth.
The other variable is what size will physically fit on the lot. You'll have to find out what the lot setbacks, utility and other miscellaneous easements, and building seperation distance (if its detached from the house). You may also have lot coverage requirements to contend with - don't forget to factor in the coverage of the new, larger driveway as well. The other item to start thinking about now is that you will likely have a maximum building height to abide by if it is detached. The bigger you get, the taller it has to get with a pitched roof.
__________________
2004 Ford Escape XLT
2012 Ford Fusion Sport
1997 2 car garage in progress
Quote:
Originally Posted by bmwpower View Post
Oh, and it's BMWPower. I do have powerful BM's but wouldn't want everyone to know all my secrets.
boiler7904 is offline   Reply With Quote
Old 11-26-2007, 03:19 PM   #13
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
To this day I'm pissed I made my attached garage as small as I did (listened to the wife...never again). Make it big. You never know when you might buy an Expedition or a Suburban or worse.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4
my garage build | my wanted list
bmwpower is offline   Reply With Quote
Old 11-26-2007, 04:11 PM   #14
aarcuda
i made mine 30x50 but if I had to do it again, I would have made it some ultiple of 4 (ie 28x48, 32x48, 32x52). I was initially thinking of getting a steel building and picked out the size. then the size stuck as I went with the wood. duh.
oh ya, its plenty big
aarcuda is offline   Reply With Quote
Old 11-29-2007, 10:10 AM   #15
Kusto
Junior Member
Thanks for all the input so far I really do appreciate it. Boiler7904, those are all very good points and I will have a look at my lot plan to see what the maximum building width that the lot will allow. I'm thinking 38 or 48 feet for some reason.
I do want to try and keep costs down as much as possible and was wondering if there is any significant difference in costs for floating slab versus a footing as I am in an area that will require a 4' footer unless I go with the floating slab.
Oh yeah, pictures would have been nice too.....
__________________
Old 11-30-2007, 10:11 AM   #16
79schaefer
79schaefer's Avatar
28 is barely deep enough for a full size truck, and bench in front. I have 28 x 56 attached to the house, and let me tell you, putting on my plow frame on my extend cab long bed truck sucked. The rear bumper had about an inch clearance on the door, and I had about 3 feet in front of the truck. The bench in that area is only about 18" wide. Bigger is better.
Steve S.
To many to list.
79schaefer is offline   Reply With Quote
Old 11-30-2007, 07:04 PM   #17
Kusto
Junior Member
Looks like my maximum width is 38 feet. So now Im thinking I should stick with the original dimensions that I was thinking 38x32...Need some Ideas now for layout planning.
__________________
Old 08-13-2015, 12:49 AM   #18
rcatank
Junior Member
What about single 3rd car garages? It's very popular now in Georgia for new construction...
rcatank is offline   Reply With Quote
Old 08-13-2015, 03:40 AM   #19
johndeereman
Senior Member
Mine is 30' wide x 36' deep it work's for now until i put up the new shop, (45' x 66')
johndeereman is offline   Reply With Quote
Old 08-13-2015, 04:06 AM   #20
Justanoldguy
Senior Member
Justanoldguy's Avatar
Quote:
Bugger. Mines only 40 x 80.
Justanoldguy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
