Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-18-2011, 07:20 PM   #1
Lewisthepilgrim
Default Generator runs but no power!
Hey guys hows it goin. I have a 6k constant run(7200max) Campbel Hausfield Generator. Its powered by a 11hp Brigs and stratton.
The generator starts up RIGHT away and runs perfectly. BUT there is no power being produced. I have pulled the cover off the generator and checked for power, 1.4v is the most power being produced from any of the wires.
Where should I start looking? I'm assuming it could be brushes? Is there another place I should start? Are there any good links to generator repair ?
Thanks guys!
Lewisthepilgrim is offline   Reply With Quote
Old 12-18-2011, 07:39 PM   #2
rct
Default Re: Generator runs but no power!
I forget the exact way to do it (google it) but if it hasn't been run in a while try "flashing" the generator with a battery. A component may have lost magnetism. A bad diode is another possibility but try the flash first.
http://www.endtimesreport.com/dead_gen.html
rct is offline   Reply With Quote
Old 12-18-2011, 07:42 PM   #3
box
box's Avatar
i assume you checked the basic's like fuses and breakers?
The brushes dont go bad until many many hours of use, i how old is it?
box is offline   Reply With Quote
Old 12-18-2011, 07:51 PM   #4
85camaro
I had a Honda that would do that and it was because something got too much dirt/dust on it. I can't remember what exactly. minor problem though.
85camaro is offline   Reply With Quote
Old 12-18-2011, 08:05 PM   #5
TxPowderCoater
flash it with a drill motor
TxPowderCoater is offline   Reply With Quote
Old 12-18-2011, 08:41 PM   #6
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Here 'ya go.....................
Thread about flashing generator
Charles (in GA) is offline   Reply With Quote
Old 12-18-2011, 10:07 PM   #7
GeorgiaHybrid
Senior Member
GeorgiaHybrid's Avatar
Sounds like you blew the voltage regulator. Have you ever started the generator with something plugged in and turned on? if yes, you will need to replace it. The typical voltage is from 1.4 to 2.5 volts at teh plug when they are blown.
GeorgiaHybrid is offline   Reply With Quote
Old 12-21-2011, 06:44 PM   #8
Lewisthepilgrim
I tried re-magnetizing it with a drill, no dice.
Voltage regulator eh? Where is that located?
Old 12-21-2011, 06:54 PM   #9
GeorgiaHybrid
Senior Member
It should be a small circuit board on the end of the generator under the cover. Go buy a new one (they run about $50 to $75) and you should be able to see where it goes. You can also look at a parts breakdown of your generator to see where it goes.
What happens when you start a generator with a load attached, it will try to make 115 volts AC with the generator just barely turning over as you pull start or use the starter to crank it. It will blow trying to do that by over amping the regulator.
Always crank the generator, then apply the load. I try to do the same when stopping it, take off the load and shut it down.
Old 12-24-2011, 08:30 PM   #10
Lewisthepilgrim
I will check it out thanks. I'm not sure mine has any boards, it seems like a rather simple generator.
Old 12-24-2011, 09:03 PM   #11
GeorgiaHybrid
Senior Member
It will have a regulator that is replaceable. I had to replace mine earlier this year after the tornado's hit due to the neighbor cranking mine while it was plugged in.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
