Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 12-20-2011, 10:03 AM   #1
monkers
Senior Member
Default pigtail a 220v outlet?
I want to have a 220v outlet in 2 locations to use a saw in 2 spots,can I pigtail off the first outlet to a second one or do i need to run another line from the panel box? They will not both be used at the same time
monkers is offline   Reply With Quote
Old 12-20-2011, 10:09 AM   #2
Jagmandave
Senior Member
Jagmandave's Avatar
Default Re: pigtail a 220v outlet?
Pigtail is fine for you since you know the story, but if you sell the place I'd consider removing the second one.
Jagmandave is offline   Reply With Quote
Old 12-20-2011, 10:13 AM   #3
Steevo
Senior Member
Steevo's Avatar
I did a pair of 30A-240v receptacles on each wall of my shop, with each pair run from a single breaker, using 10/2 Romex. I did it for the same reason as you, I might move stuff, and don't know where it will finally end up. The second receptacle is wired from the box behind the first, where the three wires for each leg are wire-nutted together and the grounds are crimped together. The inspector asked about it, looked it over, and passed it. He indicated that for convenience receptacles it could be done, but for hard-wired equipment it couldn't.
I am sure we'll hear from a bunch of electricians here that say otherwise.
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is offline   Reply With Quote
Old 12-20-2011, 10:38 AM   #4
Falcon67
Senior Member
Falcon67's Avatar
I left a spot in my box for one more 240V circuit. The thought is that if I can upgrade to a 240V welder, I would put a xxA (depends on the welder) run on my divider wall, with one outlet in the tool/work area and one in the car area. It's be a unique plug in the shop and I can only use the welder one place at a time.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 12-20-2011, 11:33 AM   #5
monkers
Senior Member
I have a separate, designated welder outlet on its own circuit. This is for a horizontal handsaw that will be in one spot 95% of the time, but if I need to cut a 20' length I can move the saw to the other area. Thanks guys
Old 12-20-2011, 04:50 PM   #6
nehog
Senior Member
nehog's Avatar
Quote:
If the breaker is sized for the wire, then it should not be a problem. Virtually all circuits have more amperage in outlets than the circuit can provide. So if you are wiring with 10 AWG, for example, then a 30 Amp breaker.
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
Volvo S80
Holiday Rambler Ambassador 40 DFD
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 12-20-2011, 06:07 PM   #7
Aceman
Senior Member
I didn't look through the code book on this one, but I'll say most of the time I run dedicated circuits for welders, 240 volt equipment, etc when I'm doing commercial shops/garages/warehouses/etc. But for a home shop, I wouldn't have a problem daisy chaining a few of them together for a guy working alone wanting a little more portability. Just watch your box fill.
Aceman is offline   Reply With Quote
Old 12-22-2011, 10:23 AM   #8
sberry
Senior Member
sberry's Avatar
Woodworking shops often have several outlets on one circuit. It may be possible to run more than one machine at a time.
sberry is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
