Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 12-22-2011, 06:13 AM   #1
StaggeringGoat
Senior Member
StaggeringGoat's Avatar
Default Water heater for air tank?
I happen to have a compressor with no tank. I've been offered a free electric water heater that is only a few years old, doesn't work. What do you guys think about using a water heater tank for a compressed air system? The front of the tank says "test pressure 300 PSI, working pressure 150 PSI max".
I've seen people doing this before but always thought it was similar to PVC air lines - a bad idea. But really, if it's pressure rated, why not? An equivalent sized air tank would cost several hundred if I can find a good used one.
StaggeringGoat is offline   Reply With Quote
Old 12-22-2011, 08:44 AM   #2
blue2golf
Junior Member
Default Re: Water heater for air tank?
I'm no expert, but my instincts tell me no.
blue2golf is offline   Reply With Quote
Old 12-22-2011, 08:54 AM   #3
metaleltr
Senior Member
Chances are it's has a bunch of scale in the bottom. Additionally there is no good way to drain the tank, although it is designed to hold water your tolls weren't designed to run on it. Does anyone know at what pressure the Temperature and Pressure release valves let off at?
metaleltr is offline   Reply With Quote
Old 12-22-2011, 09:29 AM   #4
rlitman
Senior Member
NO! Pressure ratings for hydraulic use (i.e. filled with water) are typically an order of magnitude higher than pressure ratings for compressed air use.
rlitman is offline   Reply With Quote
Old 12-22-2011, 09:41 AM   #5
kv501
Senior Member
kv501's Avatar
Get your health, life and homeowner's insurance paid up.
Compressed gas tanks are designed to be used for compressed gas, and water heater tanks are designed to hold hot water. I am a firm believer in using things for hat they are intended for, especially in this case. 150psi of air is a totally different thing than 150 psi of water. Totally different design, construction, and purpose. If you have ever seen the Mythbusters episode where they blew a water heater up, it blew the entire thing out of the bottom and it went up through the floors, ceiling, and roof of a mock up house.
Stuff like this is why there are ambulances.
__________________
Please understand that a high post count means............................................. nevermind, I can't think of anything.
kv501 is offline   Reply With Quote
Old 12-22-2011, 10:57 AM   #6
ranger302
Senior Member
ranger302's Avatar
NO! Please DO NOT USE a water heater tank for air. The tank is thin metal that is most likley rusted out. Keep your eyes out for a used air tank.
ranger302 is offline   Reply With Quote
Old 12-22-2011, 06:16 PM   #7
Jim in Wis
Senior Member
Well, I suppose everyone is right and it's not a good idea...but... that's exactly what I did about 30 years ago. I built a compressor using an old (1940's) refrigeration compressor and a electric hot water tank for the resevoir. It has a pipe plug near the bottom and I use that to drain the sludge out once in a while. It's still running and hasn't ever exploded, not even once. Not even when I got the air hose tangled up in the tractor and drove out. Knocked the tank over, pulled the wires out of the box, etc. I wouldn't recommend anyone using a hot water tank, but I can tell you for sure it can be done.
Jim in Wis is offline   Reply With Quote
Old 12-22-2011, 07:12 PM   #8
ddawg16
Senior Member
ddawg16's Avatar
Well.....actually....as long as the PRV is functional.....it will work. But....good chance it's rated for 150 PSI max....a bit too close to typical air pressure for my liking....
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 12-22-2011, 08:25 PM   #9
John in OH
Senior Member
John in OH's Avatar
Do you have a wife? Do you have kids? Do you love them? Do you want to be able to provide for them for years to come? If so, why in heavens name would you take a chance by using a pressure vessel for an unintended purpose??
You don't say what size this tank is, but most electric water heaters are 60 gal. tanks. Do you have any idea how much devastation would be caused by the catastrophic failure of a 60 gal. tank bursting at 100 - 120 psig air pressure?
And, you can bet your insurance company won't give you a dime ... and then they'll cancel your policy.
John in OH is offline   Reply With Quote
Old 12-22-2011, 08:29 PM   #10
Steves32
Senior Member
Steves32's Avatar
Tank has to be ASME rated as a pressure vessel. Water heaters are not.
You can buy a cheapo 60 gallon compressor for less than a new water heater.
Steves32 is offline   Reply With Quote
Old 12-22-2011, 08:30 PM   #11
22rifle
Senior Member
22rifle's Avatar
My dad had an air tank made out of a water heater tank. It was an old water heater, 3/16" thick walls.
22rifle is offline   Reply With Quote
Old 12-22-2011, 08:43 PM   #12
StaggeringGoat
Senior Member
Says who? Nothing Harbor Freight sells is ASME rated.
Show me just one 60 gallon compressor for less than a broken water heater and I'll take three.
All those saying the world is going to end, do you have any specific reasons why? Why would 120 pounds of air be worse than 150 pounds of water pressure? The tank is rated to 300 PSI/150 PSI working pressure. It's funny we were just having a discussion about PEX and everyone says that gas pressure and water pressure are the same thing.....
Please, if you're just going to sceam about safety don't bother responding. If you have a good reaosn why it's unsafe I'd love to hear it.
And yes, I saw what mythbusters did to a water heater, do you realize how much heat, pressure, and steam it took to do that?
Old 12-22-2011, 08:47 PM   #13
1BADLS1tuner
Senior Member
1BADLS1tuner's Avatar
+1
__________________
32x48x12 Garage Build: http://www.garagejournal.com/forum/s...d.php?t=118694
1BADLS1tuner is offline   Reply With Quote
Old 12-22-2011, 08:59 PM   #14
keller_S10
keller_S10's Avatar
I would use it.
Lot of kitty cats in this thread that don't know what they are talking about.
keller_S10 is offline   Reply With Quote
Old 12-22-2011, 09:12 PM   #15
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
Quote:
Originally Posted by keller_S10 View Post
I would use it.
Usually statements of that sort are followed by credentials.
Water tanks live with water and they fail because of it. I'm thinking a new water tank may be just fine. But who takes apart a new water heater to obtain the tank?
Zeke is offline   Reply With Quote
Old 12-22-2011, 09:17 PM   #16
StaggeringGoat
Senior Member
Quote:
I tend to agree with you on that but the tank I want to use is only a couple years old. The owner is getting rid of it because the element failed and he's going with gas. Most of the glass lining should still be intact. I would not use a very old one. Even air tanks get plenty of water in them.
Old 12-22-2011, 09:36 PM   #17
rlitman
Senior Member
You should read a little before you shoot your mouth off like that.
It took me but 5 seconds on google to find an ASME rated tank at HF:
http://www.harborfreight.com/5-hp-60...sor-93274.html
Old 12-22-2011, 09:38 PM   #18
StaggeringGoat
Senior Member
Excuse me, one of the 29 different compressors they sell actually is rated. The rest aren't. I own several.
Old 12-22-2011, 10:00 PM   #19
Chris Adams
Senior Member
Not taking sides in the hot water heater tank debate, however, I have seen it done years ago and is still working. Wouldn't do it my self, usable tanks just too darn cheap around here.
On the ASME HF tank, yes and no. I have a dead one in the back yard right now.
Low hours.
Was not drained enough.
Tank leaks out the weld at the bottom, making it a very heavy paperweight.
Looks like the ones in the pictures, but is an earlier model with two air outlets at the top.
HF must have been pretty unhappy with this tank (USA built, ASME certified) because they swapped to a newer tank on all their two stage units, and had to re-plump the discharge hose radically.
Different maker and different configuration, but with the same motor and compressor.
Point being, ASME can and do fail, at low hours.
Some older home made last about forever.
Do it right, I'm sure it would work, but I would keep the D-switch set down around 120. I would pressure check it (look up on line to see how to do it yourself) and be safe.
Again, though, myself, I would just snag a 50-150 buck used tank.
Chris Adams is offline   Reply With Quote
Old 12-23-2011, 08:24 AM   #20
dirttracker18
Senior Member
dirttracker18's Avatar
Obviously others have done it with success but I tend to shy away from the idea due to fatigue, even in a fairly new tank.
FWIW, if you look around you can usually find a used air tank that the compressor is gone on and pick it up cheap. Might even want to check the local metal yards.
__________________
"Success is when you reach a point in your life when you don't feel the need to go back and change things."
Johnny S.
www.LauraMyersPhotography.com
dirttracker18 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
