Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-22-2011, 07:07 PM   #1
JMorrison4371
Senior Member
JMorrison4371's Avatar
Default How-To Paint a Snap On tool box
I have a question for you professional tool box owners. I was wondersing if you can take a Snap On tool box apart(remove drawers, slides, etc.), strip it down, and repaint it? I have experience in automotive refinishing and I know how to use a paint gun, how to sand correctly, and so on. My thoughts on this were to strip it down probably to bare metal, then coat it a couple times with epoxy primer, and follow up with a urethane base/clear coat. Epory primer, I know is the best direct-to-metal primer you can buy, and I also know that urethane paint is very durable. What you guys think?
JMorrison4371 is offline   Reply With Quote
Old 12-22-2011, 07:12 PM   #2
mad57
Senior Member
mad57's Avatar
Default Re: How-To Paint a Snap On tool box
Why not its just like a metal car, but why strip it to bare metal? it will sit in a garage and never see weather/rain sun ect. unless its a rusty mess than thats another story.
__________________
Work to live not live to work.
Iam also vice president of my car club: Wickedridesnj.com check it out!!!!
mad57 is offline   Reply With Quote
Old 12-22-2011, 07:27 PM   #3
BBBC23
I would use a single stage urethane instead of using clearcoat. Scratches tend to show up more with clear, especially with a dark colored box.
BBBC23 is offline   Reply With Quote
Old 12-22-2011, 07:30 PM   #4
wornoutoldman
Senior Member
wornoutoldman's Avatar
I believe you should dip it in molten gold
__________________
Donor Heart Recipient 3.28.10
Eat less. Walk more. 2016
Wanna keep track of all your vehicles maintenance? Click here!
wornoutoldman is offline   Reply With Quote
Old 12-22-2011, 07:37 PM   #5
rsieracki
Senior Member
I started re-doing mine in rustoleum sunrise red... i HIGHLY advise against that... those the color looks good its hard to keep the sheen even over the whole thing being a rattle can...that and it doest get nearly as hard as id think it should... and yes i sanded, wirewheeled to bare metal, primed then painted... i would deffinately advise the OP or anyone else reading this thread in the future to spend the money and have it painted in a urethane or base clear as previously suggested... or do it yourself with a spray gun if you know how like the OP says he does
__________________
Quote:
Originally Posted by Butters View Post
God uses Snap On tools to fix all the chariots in Heaven.
Quote:
Originally Posted by raccoon View Post
Sure, i'm really a 55 year old man in my basement pretending too be a hot 20 year old girl.
MY FOR SALE THREADS:
Snap On stuff
Bench & Pedestal grinders:
rsieracki is offline   Reply With Quote
Old 12-22-2011, 07:40 PM   #6
Kurn
Senior Member
Kurn's Avatar
The only problems you may have is if it's dented.The front cover(if it has one)is usually double walled,so you can't get behind it.Same with the sides,and you have the slide mounts on the inside.Bondo is your friend,in this case,unless ya want to go with the drill and slide hammer.I had a machinist friend make me a dolly for the rounded drawer pulls on my KRA59A,later ones are squared off and should be pretty straightforward.I wouldn't take it all down to bare metal unless its totally covered in rust.
__________________
If there are no dogs in heaven,then I want to go where they go.
Kurn is offline   Reply With Quote
Old 12-22-2011, 07:40 PM   #7
davidj
Senior Member
davidj's Avatar
Quote:
yes.
davidj is offline   Reply With Quote
Old 12-22-2011, 07:45 PM   #8
NY Old Guy
Senior Member
I recently bought an 80's vintage 8 drawer Made in Canada Snap On side cabinet. It needs touch up in a few places. No rust though. Is there a touch up paint for Snap On Red?
NY Old Guy is offline   Reply With Quote
Old 12-22-2011, 07:47 PM   #9
930dreamer
930dreamer's Avatar
OP, take some pics of the process.
__________________
I can take it apart.
http://stores.ebay.com/930dreamer?_rdc=1
930dreamer is offline   Reply With Quote
Old 12-22-2011, 08:15 PM   #10
Camtwo69
Senior Member
If you take it apart what about having it powder coated ?
Camtwo69 is offline   Reply With Quote
Old 12-22-2011, 08:20 PM   #11
LouG
Not sure how much it costs, but I've got this place saved in my favorites list for the future. They're not where you're located, but the process may be what you're looking for. It might be worth your while to search for someone who does similar work in your area.
__________________
1992 Mazda Miata Sunburst Yellow #1122 of #1519: 18k miles.....and counting......
LouG is offline   Reply With Quote
Old 12-22-2011, 08:53 PM   #12
wreckerman5357
Senior Member
If its in good shape and does not have rust or cracked paint, then I would not bring it down to bare metal.
If it were me I would do the following provided there was no rust or cracking paint:
(1) do any neccesary metal work. Straighten your metal before doing any sanding unless using a stud gun.
(2) Remove all paint in areas you are using body filler on. Keep body filler away from paint edges or halos and adhesion problems will result.
(3) Apply body filler.
(3) Rough sand body filler with either 80 or 100 grit paper on a block. Leave enough filler for finish sanding.
(4) Finish your filler with 180 grit paper on a block. Make sure all 80 grit scratches are gone, primer WILL shrink and you will see 80 grit scratches in your finished paint job.
(4) Use a DA to featheredge the paint around your filler. Use 180 grit paper.
(5) Use aerosol etch primer on all bare metal. Keep etch off filler as best you can.
(6) Spot prime all repair areas with a good primer PPG's NCP 271 would be my choice.
(7) Block primer with 320 grit paper followed by 400 grit. Finish by buzzing with 400 on the DA.
(8) Sand the rest of the box with 400 on the DA.
(9) Wipe box down with wax and grease remover. I would use PPG's DX320.
(10) Apply epoxy sealer to entire box. 1 wet coat. I would used PPG's DP50LF. I like this sealed because it can be topcoated for up to a week without scuffing or sanding.
(11) Apply basecoat. 2-3 coats should get you coverage depending on color. I would use PPG's Deltron basecoat system.
(12) Apply clear, probably 3 coats. I would use Omni MC270. It is a PPG product and is compatible with the other products listed but cheaper than Deltron clears.
Ofcourse you can use products from other companies but I am a PPG guy. I know this is probably more labor intensive and expensive than what you wanted to do, but this is what I would do if I wanted to paint myself a kickass box.
wreckerman5357 is offline   Reply With Quote
Old 12-22-2011, 09:02 PM   #13
JMorrison4371
Senior Member
awesome advice guys. I haven't decided to do it yet, but I'm thinking hard on it. My box is the Muscle Car Mopar series and it's purple now, but I want it black, black is my faveorite color(and no im not emo or whatever), it would be a bitch to tape up all the mopar prints on it, but what i want to do to it, i think it would be worth it.
Old 12-22-2011, 09:23 PM   #14
BBBC23
Step 9 should be the first thing done.
Old 12-22-2011, 09:33 PM   #15
wreckerman5357
Senior Member
Quote:
Good catch, I would wash with soap and water first, then dry, then wipe down repair areas, wipe down the bare metal before filler application, and wipe down repair areas before priming.
Also forgot to mention using a tack cloth after sealing is tack free, between coats of color, and before clear.
Old 12-22-2011, 09:42 PM   #16
DanCo
Senior Member
DanCo's Avatar
Location: In a house, on a block, somewhere in Queens New York
Send a message via AIM to DanCo Send a message via Yahoo to DanCo
Quote:
Yes, They do sell sell touch up paint.
http://bluetoad.com/publication/?i=45974&pre=1
or if you have a printed copy of catalog 1100 handy its on page 377, lower right...it aint cheap.
Dan
__________________
Quote:
Originally Posted by Muffduster View Post
Get rid of that damn signature!!!!!!!!!
Looking for Snap On Pearl Handled Screwdrivers, PM me if you want to sell
DanCo's For Sale Items
DanCo is offline   Reply With Quote
Old 12-22-2011, 09:45 PM   #17
BBBC23
No worries. We'll make a painter of you yet.
Old 12-22-2011, 11:31 PM   #18
larryq
Senior Member
Curious to know, are the PPG paints listed waterborne or urethane? I know that waterborne is being pushed hard in Cali..
larryq is offline   Reply With Quote
Old 12-23-2011, 12:27 AM   #19
wreckerman5357
Senior Member
I'm guessing you're a painter? I like seeing other collision guys on here. I learned a lot about paint working in the bodyshop before going to school for collision, enough to know I liked body better. My entire two years of school you do both. You do the body and paint work on actual customer cars. I do body work only at the shop I'm at now. But until I'm graduated in May I have to paint. I don't mind painting, but I like metal work better.
Old 12-23-2011, 12:35 AM   #20
wreckerman5357
Senior Member
Quote:
The products listed are solvent. Envirobase HP is PPG's waterborne line. One could substitute Envirobase basecoat for the Deltron basecoat I recomended. The sealer and clear mentioned are both approved for use with water.
I would not recomend waterborne for the OP unless he has used it previously. I did not use it until I went to school and hated it at first. After taking PPG's Envirobase class at one of their training centers, I quickly decided it was the way to go. Cleanup is easy, color-matching is better, it blends well, and it saves you time over solvent.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
