Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-07-2012, 04:12 PM   #1
milesvdustin
Senior Member
Default lincoln air compressor
So the compressor i have been asking about is in fact a Lincoln pump with a Ge motor. It's a two stage pump I believe, and it runs quiet as all heck. I will be posting pictures and numbers and all. I am looking for a manual or a source for parts to rebuild if needed. Stay tuned!
milesvdustin is offline   Reply With Quote
Old 01-07-2012, 04:25 PM   #2
PT Doc
Senior Member
PT Doc's Avatar
Default Re: lincoln air compressor
Great.
PT Doc is offline   Reply With Quote
Old 01-07-2012, 04:27 PM   #3
930dreamer
930dreamer's Avatar
Waiting for the pics.
__________________
I can take it apart.
http://stores.ebay.com/930dreamer?_rdc=1
930dreamer is offline   Reply With Quote
Old 01-07-2012, 05:57 PM   #4
milesvdustin
Senior Member
Ok here are the pictures I promised earlier. Some ID on the model of the pump would be nice, I think it is a Quincy 325, but I am not sure. The valve thing at the top of the pump leaks air when the compressor is not running. Is that the unloader valve? I am new to compressors.
Here are a few shots of the pump
Untitled by milesvdustin, on Flickr
Here is the ID plate on the side of the pump, It says Lincoln on it.
And the data plate on the tank
And here is one of the whole shootin match
Anything anyone can tell me about getting parts to rebuild in the future or at least to fix that leak would be greatly appreciated. I plan on stripping this thing down and doing a restoration on it. I paid 300 bucks for it, was that good?
Old 01-08-2012, 12:16 AM   #5
milesvdustin
Senior Member
Ok so the model on the data plate of the pump says 9201, and on the side of the pump case is has the number 5515. From looking at other stuff online I think this is a quincy 310 pump, is that correct? It has a leak from the seal where the crankshaft comes out, Looks like a very slow, years to build up kind of leak. Am I correct on the model of this pump? I am wanting to just go ahead and rebuild it real fast while I take it apart to give it a sweet paint job. I also need a new gasket for the valve on top.
The serial number says 310-21, I am beginning to think that means its a 310 pump, ROC (record of change) 21.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
