Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 01-11-2012, 10:38 PM   #1
Tami CS
Junior Member
Default Garage interior walls ideas
We have recently built an attached garage on our home & are wondering what to do the walls in instead of sheetrock. Some use OSB (don't know if I would like that painted?) and some use metal (hard to hang things on?) Send me ideas. TCS
Tami CS is offline   Reply With Quote
Old 01-11-2012, 10:45 PM   #2
jmauld
Senior Member
Default Re: Garage interior walls ideas
I did my garage in 1/2" plywood.
So far I have no regrets. I don't intend to paint them, since I like the natural color. I hung them with screws. I have already taken advantage of that and pulled a panel off so that I could run a 240V circuit for a heater.
Also, the 1/2 plywood is plenty thick enough to just run a screw or nail into for most light loads.
jmauld is offline   Reply With Quote
Old 01-11-2012, 11:36 PM   #3
Stinger
Senior Member
Stinger's Avatar
I used OSB so I could screw to it and it would be more resilient if things crashed into it...OSB can look very nice painted if you take the time to install it smooth and then caulk the seams and use oil based paint:
Stinger is offline   Reply With Quote
Old 01-12-2012, 12:24 AM   #4
camnick
I think 1/2" plywood is the way to go. I used to have drywall at my other house and hated it. I am still putting up the plywood, but it will look great after primer and paint. It works great for electrical boxes.
camnick is offline   Reply With Quote
Old 01-12-2012, 12:27 AM   #5
camnick
Sorry for the first photo
Old 01-12-2012, 09:02 AM   #6
kngelv
Senior Member
I agree with the above posts. Plywood is the way to go, and use screws. I just did my garage this way. OSB is a b**ch when it gets wet plus the glue smell.
James
kngelv is offline   Reply With Quote
Old 01-12-2012, 09:03 AM   #7
djjsr
Senior Member
djjsr's Avatar
Are you concerned about fire resistance? I would never use osb or plywood in an attached garage.
jmo.
djjsr is offline   Reply With Quote
Old 01-12-2012, 12:04 PM   #8
regguy1
Senior Member
regguy1's Avatar
48" pegboard (HD Garage liner pre finished) in the center section. 36" paneling on bottom and 20" paneling on top. Wall height is 8' 10"
Garage Tour:
http://www.youtube.com/watch?v=cZIhuocG2ig
Garage in use:
http://www.youtube.com/watch?v=fwMg3Ai4xeQ
regguy1 is offline   Reply With Quote
Old 01-12-2012, 12:08 PM   #9
regguy1
Senior Member
regguy1's Avatar
Quote:
jmo.
True, they'll have to use sheetrock for the common house / garage wall to meet code
Old 01-12-2012, 12:31 PM   #10
tncatadjuster
Senior Member
tncatadjuster's Avatar
OSB can be coated with polyurethane, with a dash of tint to give it the flavor you like. I've done many colors.
__________________
Borrow trouble for yourself, if that's your nature, but don't lend it to your neighbours.
Rudyard Kipling
http://www.acepoxy.com/acepoxy.com/HOME.html
tncatadjuster is online now   Reply With Quote
Old 01-12-2012, 12:44 PM   #11
cderalow
Senior Member
jmo.
FYI, you can get fire rated plywood.
it is more expensive, but it is possible.
I'm thinking I might redo my garage walls in 1/2" plywood as well, avoids need for finishing, allows for access behind wall when mounted with screws, and I can just layer it over 5/8" firecode on the shared wall.
conceptually, I like that idea a lot.
cderalow is offline   Reply With Quote
Old 01-12-2012, 01:35 PM   #12
Rich H.
Senior Member
Rich H.'s Avatar
Guess I'm equal opportunity....drywall was the base for anything else I do because I wanted a fairly smooth easy to paint....clean slate to start with and appreciate the tiny bit (it really ain't much) of fire resistance and noise abatement drywall offers.
With that done I'll put whatever I want on top of it over time. I've put painted to match plywood over the top of it to hang stuff on, and am not opposed to metal, OSB, or whatever the application calls for. If sparks will be thrown, metal. If I'm constantly beating up one area, plywood. But that drywall will be there behind it doing it's thing.
http://garagejournal.com/forum/attac...5&d=1323479708
Right tool for the job, right wall material for the application....consider the shop as a tool to do whatever projects you want....make the tool work for you.
__________________
My 24x30 build: http://garagejournal.com/forum/showthread.php?t=118324
Rich H. is offline   Reply With Quote
Old 01-12-2012, 10:10 PM   #13
TigerGA
TigerGA's Avatar
I used 4x8 sheets of hardie board, painted, caulked at seams. Looks like vertical wood panels.
TigerGA is offline   Reply With Quote
Old 01-13-2012, 04:26 PM   #14
jdaallen
Senior Member
jdaallen's Avatar
Send a message via AIM to jdaallen
I used OSB, screwed. Sealed with Kilnz then a quick top coat of drywall mud and semi gloss latex. You can not tell it from drywall now. I suppose plywood would be ok, but man at today's prices -- wow!! Eventhough there is "fire rated" wood, it still burns like any other wood when ignited.
jdaallen is offline   Reply With Quote
Old 01-13-2012, 04:37 PM   #15
Kevin54
Senior Member
Kevin54's Avatar
Drywall for the win
__________________
THE ADDITION
Kevin54 is offline   Reply With Quote
Old 01-13-2012, 04:41 PM   #16
mikeyr
Senior Member
mikeyr's Avatar
I had osb in my last garage, it was painted and it looked pretty good, kind of had a texture finish. And that was the problem, dust stuck to the texture after a few years it looked dirty, it seemed I was cleaning up the walls yearly. My new garage I considered plywood but I went drywall finished smooth and I like it a lot, you have to be a little more careful but not much. With some thinking you can hang anything on drywall that you could on plywood, just have to think instead of driving in a screw. I also feel safer when welding or using my plasma cutter that a spark wont cause a fire with the OSB.
__________________
My new toy is at http://www.singercars.com :)
mikeyr is offline   Reply With Quote
Old 01-13-2012, 05:00 PM   #17
jdaallen
Senior Member
jdaallen's Avatar
Quote:
That's why I did the skim coat of mud. It smoothed out the surface and looks just like a sheet rock finished wall.
Old 01-13-2012, 05:17 PM   #18
Wastedwagesracing
Quote:
I actually like the look of that. Not necessary the color but I could live with that in a light gray. How did you apply it?
Also I ran across a guy with 100 sheets of slat wall. What are the thoughts on using that? I was thinking of doing the bottom 8 feet and then finish the top 8 feet in white tin.
Wastedwagesracing is offline   Reply With Quote
Old 01-17-2012, 08:36 PM   #19
regguy1
Senior Member
regguy1's Avatar
Here's a video of the interior , check it out:
http://www.youtube.com/watch?v=cZIhu...1&feature=plcp
Old 01-18-2012, 10:13 AM   #20
RTcat
Senior Member
RTcat's Avatar
Drywall here.
RTcat is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
