Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 01-12-2012, 08:14 PM   #1
zruvalcaba
Senior Member
zruvalcaba's Avatar
Default Thinning oil-based paint before painting metal
I'm about ready to begin painting all of the parts on my Clausing DP resto. I properly stripped all of the parts of their original paint, blasted them in my cabinet, and have applied Rust'O'Leum white primer to all of the parts. Here's where I'm at so far:
https://dl-web.dropbox.com/get/Publi...jpg?w=68e70994
https://dl-web.dropbox.com/get/Publi...jpg?w=598e6a6a
The primer went on super smooth...no problems. However, I used the same brand paint to paint my new workbench frame and I was less than impressed with the results of either the paint or the spray gun. I tried adding a bit of mineral spirits to the paint but it didn't seem to help. My question is, how much (if any) mineral spirits should I be adding to thin the paint?
I paint my guns using KG GunKote 2401 Black and the consistency of this stuff is like water. I use a HVLP detail gun and it works amazing. Using a more industrial HVLP spray gun for the DP but I want to make sure the paint goes on nice and smooth with no globs or spatter on the parts....this is what i got on some parts of my workbench frame. Really would like to avoid that on my Clausing DP. Thanks for any advice.
zruvalcaba is offline   Reply With Quote
Old 01-12-2012, 09:05 PM   #2
FrankieD
Default Re: Thinning oil-based paint before painting metal
I believe the Rust'O'Leum label says to use xylol or xylene to thin their paints for spraying.Hope this helps.
FrankieD is offline   Reply With Quote
Old 01-12-2012, 09:37 PM   #3
e-tek
Senior Member
e-tek's Avatar
READ THE DIRECTIONS!
For most of thuse tpes of paints, Minimum thin is 10%, upt to 50%.
Before you paint your parts, paint something else to check everything.
Never practice on your final piece!
e-tek is offline   Reply With Quote
Old 01-12-2012, 09:37 PM   #4
rlitman
Senior Member
They often now say to thin with acetone if spraying. That's because of VOC regulations.
Acetone will "flash" faster than xylene, and can be more difficult, so xylene may be your best bet (even if it doesn't explicitly say that in the instructions).
A little mineral spirits (emphasis on little) is ok for a brush finish with most rustoleum paints (just not the hammertone or metalic ones, don't mess with those).
rlitman is offline   Reply With Quote
Old 01-12-2012, 09:46 PM   #5
slip knot
Senior Member
slip knot's Avatar
Been a few years since I painted anything with a paint gun but we always used "enamel reducer". You could get it in different speeds for hot or cold temps. Don't know if this stuff is still pertinant with the hvlp paint sysytems. Acetone always flashed too fast for me the surface never would flow togther.
slip knot is offline   Reply With Quote
Old 01-12-2012, 11:09 PM   #6
mike13u
Senior Member
mike13u's Avatar
Should say exactly what to do on the can. Dont worry, its not like asking for directions, reading a paint can is not against Man Laws.
mike13u is offline   Reply With Quote
Old 01-13-2012, 12:03 AM   #7
zruvalcaba
Senior Member
zruvalcaba's Avatar
Quote:
Guys, I DID read the label. It specifically states to use Mineral Spirits or Acetone to thin the paint. My question is how much? I used Mineral Spirits on my last job and it didn't exactly turn out smooth. I had spatter....
Old 01-13-2012, 07:28 AM   #8
mike13u
Senior Member
mike13u's Avatar
I would start at about 30% mineral spirits and move up if necessary. I dont have any experience with that particular paint though. Is it an enamel? Thats what I have used for machines like my mill. If its an enamel, will you be useing a hardner? As others have said, its sometimes trial and error. Test on soem other items first. I would start in the 20-30% and work up if necessary .
Good luck and post pics of the finished drill press.
Old 01-13-2012, 09:50 AM   #9
sberry
Senior Member
sberry's Avatar
Just enough to make it spray well, usually around 10%, if it wont go thru gun obviously its too thick.
sberry is offline   Reply With Quote
Old 01-13-2012, 09:59 AM   #10
uhohjim
Senior Member
I thinned out my Rustoleum about 10% with mineral spirits to spray my garage door.........Came out awesome nice gloss and no problems..........also read on here somewhere that a guy was using enamel hardener in his Rustoleum and he ended up with a super hard super glossy finish.......I'll be trying that on my bandsaw rebuild........Jim
uhohjim is offline   Reply With Quote
Old 01-13-2012, 10:10 AM   #11
MoonRise
Senior Member
MoonRise's Avatar
RTFM for the product and RTFM for the tool.
You say the paint can says to thin with mineral spirits or acetone. But it didn't say how much to thin by if spraying? Most of the paint cans I've seen/used list not only the thinner to use but also the rough amounts (such as: thin no more than 10%, etc, etc).
If you don't understand the label, you can almost always check the maker's website or <gasp!> call their Tech line. Most makers want to help make sure you get 'good' results with their products.
And related to RTFM for the product, you also have to RTFM for the tool/device you are using with the product.
Saying 'spray gun' isn't quite enough if you want a detailed answer as to thinning amounts.
Tiny little 'artist' type airbrush with the smallest needle and tip? Honking mondo-sized HVLP 'production' spray gun? An airless 'spray gun' with a small diameter tip or a large diameter tip?
All can be used to 'spray paint', but not all can be used to spray all paint.
That's why you have to read the tool manual, and see what it says/recommends as far as sprayable viscosity for the paints that it says that sprayer can spray.
MoonRise is offline   Reply With Quote
Old 01-13-2012, 12:36 PM   #12
rlitman
Senior Member
Quote:
Indeed it does, but only on NEW cans. Oh, and did you notice that the can doesn't have the word "paint"?
Cans I have had sitting around for years say to thin with xylene.
It's all about government regulations. Seriously!
Oil based "paints" are no longer legal in the US, because of their VOC content. Now, they're a "rust preventative finish", or "wood finish", or "stain", or something else along those lines.
Old cans said to thin with xylene, not any more. The paint formulation has not changed, BUT the VOC regulations have. Nowadays, the government is more strict about "aromatic" VOCs than "aliphatic" VOCs. Xylene is aromatic. Acetone and mineral spirits are not (ok, enough with the chemistry lesson).
If the manufacturer recommended to thin with xylene, the thinned product would not be legal to sell, so they were forced to change their recommendations to a less suitable alternative.
Old 01-13-2012, 04:54 PM   #13
zruvalcaba
Senior Member
zruvalcaba's Avatar
Gotcha, thanks for the detailed information. So where can Xylene be found? How much should I add...10%? As for a hardener...should I add this as well?
Old 01-13-2012, 06:02 PM   #14
sberry
Senior Member
sberry's Avatar
Hardener can make it shine and dry quickly but,,,also makes it more toxic. This is a piece of equipment, stored inside, doesn't need the durability of a truck or airplane. Won't even fade in the sunlight. I sometimes paint some pieces with common spray cans, looks good for a long time indoors.
Old 01-13-2012, 06:02 PM   #15
uhohjim
Senior Member
I didn't use a hardener and got a nice shiny finish that is still in good shape after a couple years out in the elements. That said I'll be trying some enamel hardener with the Rustoleum on my bandsaw project when I paint it.You don't need the hardener the rustoleum will dry pretty quick when sprayed...............I did use a cheapo Harbor Freight gun when I shot mine rather than taking a chance with fisheyes later on down the road from using oil based paint in the gun....But again the finish came out awesome.........Jim
Old 01-13-2012, 06:46 PM   #16
zruvalcaba
Senior Member
zruvalcaba's Avatar
I'm using a HF spray gun as well. I suppose I'll just give it a shot and see how it turns out.
Old 01-13-2012, 10:51 PM   #17
rlitman
Senior Member
Right next to the acetone, denatured alcohol and mineral spirits in the aisle of most places that sell paint. At least, that's where it always is in the orange or blue box stores.
Old 01-14-2012, 12:11 AM   #18
trbomax
Senior Member
trbomax's Avatar
I always used lacquer thinner, dtl10 ditzler to be exact. Its a med speed thinner for color,not clear. For rustoleum and similar alkid enamels about 10% to start with,the keep adding it a little at a time untill your spray outs are what you want. The dtl10 will allow good flow out along with a medium flash speed,thus eliminateing runs if you paint "wet" These paints flow much better and develop better gloss if "smoothie" is added at 150% recomended dose. I have been useing an accuspray hvlp gun for about 20 yrs doing this.
__________________
"If I live the life I'm given,I wont be scared to die." Seth & Scott Avett.
trbomax is offline   Reply With Quote
Old 01-14-2012, 08:30 AM   #19
NUTTSGT
NUTTSGT's Avatar
I used mineral spirits to thin Rustoleum when I painted my walk in garage door this fall. I've used it before this project.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 01-16-2012, 06:17 PM   #20
uhcrandy
Senior Member
uhcrandy's Avatar
I used my devilbliss primer gum to spray my outdoor metal furniture. I used rust-olium, in the gallon. I used acitone to thin it. I used more acitone than I thought i should. In hind-sight I may use even more next time. I seem to have got a better job with more thinning.
uhcrandy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
