Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-21-2012, 03:54 PM   #1
Cinneagh
Cinneagh's Avatar
Default Ice removal: De-Icer, Ice Melt, or Torch?
Our new house has concrete steps and sidewalk and an asphalt driveway. The concrete has spalling from previous applications of ice melt. The asphalt has northeastern exposure and stays iced up for a while. What would be a good way to take care of this? Liquid de-icer, gourmet ice melt like Magic Salt (if I can get it), or a high-BTU torch?
I'm thinking a torch for the concrete and an ice-melt or de-icer for the asphalt since I think the torch would not work for the asphalt.
Some ideas from Northern Tool:
http://www.northerntool.com/shop/too...ry_bare-ground
Any other tips or hints would be a great help.
Thanks!
Jeremy
Cinneagh is offline   Reply With Quote
Old 01-21-2012, 04:10 PM   #2
1948
Senior Member
1948's Avatar
Default Re: Ice removal: De-Icer, Ice Melt, or Torch?
just a bag of rock salt usually works good. but if its something you have to deal with most of the year i would consider redoing the steps to be heated.
wait..... youre in virginia... you guys get ice down there???
1948 is offline   Reply With Quote
Old 01-21-2012, 04:13 PM   #3
e30bradley
Senior Member
e30bradley's Avatar
natural salt. Not chemicals, salt works great. But if you need instant melting use a torch, then put salt down so it doesn't refreeze.
e30bradley is offline   Reply With Quote
Old 01-21-2012, 04:53 PM   #4
Richard Cranium
Senior Member
Richard Cranium's Avatar
be careful with the torch that it doesn't cause the concrete to chip from air pockets heating up and exploding.
Richard Cranium is offline   Reply With Quote
Old 01-21-2012, 09:42 PM   #5
p_mori7
Senior Member
p_mori7's Avatar
Put rubber pads/mats on the concrete steps. When they ice up, just peel them off, flex them to break the ice off, then lay them back down. Use nice thick rubber.
__________________
My build thread here: http://www.garagejournal.com/forum/s...ad.php?t=63078
p_mori7 is offline   Reply With Quote
Old 01-21-2012, 10:05 PM   #6
jam92102
Senior Member
jam92102's Avatar
I have one of those 80,000 btu tourches I use and it does really well on my concrete driveway and steps. I don't hold it in one spot very long but I haven't had any problems. If the ice is 1 inch to 2 inch it's easier to heat it up and then break it up with a shovel. Otherwise you'll be there all day.
__________________
Good Garage Journal Sellers I've Bought Tools From:
Hiball, Justinmc, Hank McMauser, franksinatra, V70R, latebreak, Lost Road,kc-steve, Rickster
jam92102 is offline   Reply With Quote
Old 01-21-2012, 11:05 PM   #7
Mr.N
Senior Member
Does Sun hit the steps?
If Yes, shovel before a single foot step lands on them every snow. Sun will do the rest if they are clean of as much snow as you can remove.
If No, Make sure you've a down hill spot for the water to run. Hate to see the water freeze and make some very slick ice.
Or, Shovel like above and lay a little sand if you want to stop using salt.
Mr.N is offline   Reply With Quote
Old 01-22-2012, 07:59 AM   #8
bad_idea
Senior Member
What part of VA are you in? I've lived here in Va Bch for 20 years and we only get ice on the sidewalk a couple times a year when it snows (very rare).
bad_idea is offline   Reply With Quote
Old 01-22-2012, 08:56 AM   #9
rwreuter
Senior Member
i use salt (ice melt) on my driveway and sidewalk.
i built a new house and after 2 months or so i applied a sealing compound to my concrete so it wouldn't spall when applying ice melt....worked great.
i have seen so many driveways and sidewalks tore up after the application of salt....i wasn't going to have that happen to me......
rwreuter is offline   Reply With Quote
Old 01-22-2012, 09:53 AM   #10
jhelrey
Senior Member
Use sidewalk safe salt... not road salt.
jhelrey is offline   Reply With Quote
Old 01-22-2012, 01:24 PM   #11
5lima30
Senior Member
5lima30's Avatar
I use the turbo torch for the gravel areas and my wooden steps get ice-melt. The bigger areas (driveway) get plowed with my tractor with a rear blade...although this year I have not had to plow yet!
5lima30 is offline   Reply With Quote
Old 01-22-2012, 04:13 PM   #12
GirlnAgarage
Senior Member
GirlnAgarage's Avatar
Salt.
__________________
Previous garage; all pics removed
My Garage: Reorganization, it's like a renovation
GirlnAgarage is offline   Reply With Quote
Old 01-22-2012, 04:54 PM   #13
Jackfre
Senior Member
Last year I had enormous ice build up on my roof and gutters. Only time in 18 yrs of ownership of that house that I had to deal with it. I took 100' of hose connected to my Rinnai tankless water heater and ran hot water for three hours straight and eliminated all the ice and snow on the roof and gutters. The run off melted the build up on the driveway. The neighbors thought I was nuts, but upon seeing how well it worked they all wanted to know how I did it.
Jackfre is offline   Reply With Quote
Old 01-22-2012, 04:57 PM   #14
premierplayer
Senior Member
premierplayer's Avatar
http://www.scotwoodindustries.com/brands/6/products/18
__________________
Quote:
Re: Missing SnapOn man
Don't worry. It takes a while to drive over to China and pick up a new load. Give him time.
"Show us your PVC air lines"
premierplayer is offline   Reply With Quote
Old 01-22-2012, 08:53 PM   #15
Cinneagh
Cinneagh's Avatar
Thanks for your input, guys. I have a lot of great options to consider.
Old 01-22-2012, 08:57 PM   #16
Unearthed
Senior Member
Unearthed's Avatar
Calcium chloride. Works at lower temps better than salt. Easier on concrete than salt.
Unearthed is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
