Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-27-2012, 09:52 PM   #1
BLACK DEATH
Senior Member
Default Snap On CT3850 18 volt 1/2" cordless impact, is it junk?
I got this tool in trade but it seems it has no balls at all. It seems to charge fine but who knows about the battery. Does anyone know what kind of torque this tool puts out? I can trade back what we traded but is this tool worth a damn? Whats it worth also? Has case, charger & one battery. Need some good input guys.
BLACK DEATH is offline   Reply With Quote
Old 01-27-2012, 10:05 PM   #2
GeorgiaHybrid
Senior Member
GeorgiaHybrid's Avatar
Default Re: Snap On CT3850 18 volt 1/2" cordless impact, is it junk?
Mine does a good enough job on lug nuts and similar torqued fasteners. It looks like yours had the original battery and that might be a little weak. You can get them rebuilt at Batteries Plus or get an adapter from Snap-on and use the newer style slide on battery.
I use mine on mowers, the tractor, changing a flat on the road or anything else away from the airtools at the shop. It is not as strong as one of the newer battery impacts from Snap-on but it is not a slug either.
GeorgiaHybrid is offline   Reply With Quote
Old 01-27-2012, 10:07 PM   #3
MD11
Senior Member
MD11's Avatar
don't know about the 3850, but my newer 6850 with 18v Nikcad can take lugs nuts off a semi without any serious effort.
__________________
DIY
My Tool Box/Garage
My Truck
MD11 is offline   Reply With Quote
Old 01-27-2012, 11:18 PM   #4
GSteg
Senior Member
GSteg's Avatar
I've used those guns before and they should have some power behind them. The batteries may be exhausted already, but note that it was only rated for 210 ft-lbs, half of what the newer stuff can do.
GSteg is offline   Reply With Quote
Old 01-27-2012, 11:20 PM   #5
BLACK DEATH
Senior Member
Whats this adapter you are talking about? What batteries & charger would i need also? Got any part numbers?
Old 01-27-2012, 11:26 PM   #6
Danglerb
Senior Member
Danglerb's Avatar
Joke around the shop is that tools have air hoses, vibrators have batteries. Its not an air tool, but it should still pop off lug nuts. Idea is that its a handy easier to use tool that works 90% of the time, but doesn't replace an air impact.
If the battery is good and it doesn't have the torque to suit you, its not the tool for you. Maybe see if you can test it with a known good battery?
Depends on what you traded too. I don't like to go back on a trade if I can avoid it though, better to find somebody else to trade it to for something else.
Danglerb is online now   Reply With Quote
Old 01-28-2012, 09:13 AM   #7
johninct
Senior Member
It is 1/2 as powerful as the newer ones but it is still pretty powerful. I use mine to take off 32 lug nuts on my F 350 that have been torqued to 140 ft lb and it does fine. The problem may not be the battery, but the gun needs to be rebuilt.
johninct is offline   Reply With Quote
Old 01-28-2012, 09:24 AM   #8
tkonetzke
Senior Member
Quote:
Really? My 6 month old well cared for mg725 has all
it can do to remove many of them.
tkonetzke is offline   Reply With Quote
Old 01-28-2012, 09:32 AM   #9
sdguy55
Senior Member
sdguy55's Avatar
The newer ones of those can do just about everything the 1/2 air guns can do. Only problem is they are pretty fricken heavy...even the Li-Ion ones.
sdguy55 is offline   Reply With Quote
Old 01-28-2012, 10:45 AM   #10
BLACK DEATH
Senior Member
Quote:
I didnt want to hear that? "It may be the gun", as it couldnt remove lug nuts from my truck that be torqed under 100#s. It didnt seem to spin fast but i cant tell rpms from my eyes only .... id rather trade back as he said we could if i didnt like it. I traded a softball bat & new softballs for it valued around $150. This tool could get very expensive to get working correctly with a rebuild or even a battery. Id rather invest in a milwaukee as i have the batteries already or other 18 volt lithium impact, even the C3 from craftsman hits harder than this one at the moment.
Im going to discharge the battery fully & then fully charge it up. Lets see what happens after that. If not it will go back. I like the case though.
Old 01-28-2012, 11:23 AM   #11
MD11
Senior Member
MD11's Avatar
you got enough air pressure behind it? IF you're using a small compressor that could be why. Break away torque on both is close to the same figure.
__________________
DIY
My Tool Box/Garage
My Truck
Old 01-28-2012, 11:37 AM   #12
tkonetzke
Senior Member
More than enough air in the shop. Air hose could be better, but im using what they give us. What are said lugnuts torqued at? When you say semi I think 475ft-lbs. Which I don't think any cordless will be able to move. I know some advertise breakaway torque higher than 475, but it takes considerably more than 475 to break a fastener loose that is torqued to 475, especially if its been out on the road a while.
Breakaway rating is 1190 for mg725. Which doesn't mean much in reality. They may have achieved it with 200psi and 1 inch airline. I think the advertise working torque around 800something. Which is still well above any cordless I've seen breakaway rating
Old 01-28-2012, 12:23 PM   #13
MD11
Senior Member
MD11's Avatar
Breakaway on the chord less is in the mid 600's... and continuous at 400.. specifically designed for "up to" Semi's .. they spec'd it for this. Maybe I shouldn't' have said "Serious Effort" in my original response, since the tool is putting in a lot of effort.... It's me that's not!
Is this better than going with a 1" air gun? no... will it "do the job" .. yes.
__________________
DIY
My Tool Box/Garage
My Truck
Old 01-29-2012, 12:02 AM   #14
GeorgiaHybrid
Senior Member
Quote:
Here is the adapter:
Slide On Adapter
To use these batteries:
Slide On Battery
Old 01-29-2012, 02:22 PM   #15
BLACK DEATH
Senior Member
Quote:
Slide On Adapter
Slide On Battery
What about the charger & no lithium battery? I think its the gunbut who knows. Its well used.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
