Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-28-2012, 06:08 PM   #1
reptilezs
Senior Member
Default dremel/rotary tool
looking to get a dremel rotary tool. what should i look for? i see there is proxxon, do they take dremel bits?
reptilezs is offline   Reply With Quote
Old 01-28-2012, 06:26 PM   #2
Jawn
Senior Member
Jawn's Avatar
Default Re: dremel/rotary tool
What do you plan to use it for?
I'd look for one that has variable speed (5k rpm and up). Also, I have stuck with the Dremel brand... so I can't speak for any other brands.
__________________
My garage: Jawn's drive-under
Jawn is offline   Reply With Quote
Old 01-28-2012, 06:28 PM   #3
american lockpicker
Try a Dremel first, then get a Proxxon. Without trying anything else you won't be blown away by the quality and lack of noise.
american lockpicker is offline   Reply With Quote
Old 01-28-2012, 07:05 PM   #4
MattT
Senior Member
"Dremel bits" are just 1/8" shank attachments so they'll work in anything with a 1/8" collet and a suitable speed range.
MattT is offline   Reply With Quote
Old 01-28-2012, 07:23 PM   #5
DrkMtnDew
Senior Member
DrkMtnDew's Avatar
dremel's usually can be purchase in large kits with all the attachments a guy could want.
variable speed if possible.
__________________
Nobody got anywhere in the world by simply being content. Louis L'Amour
DrkMtnDew is offline   Reply With Quote
Old 01-28-2012, 07:24 PM   #6
american lockpicker
Proxxons come with an assortment of collets.
Old 01-28-2012, 07:32 PM   #7
Monte
Senior Member
Monte's Avatar
Monte is offline   Reply With Quote
Old 01-28-2012, 07:45 PM   #8
american lockpicker
Quote:
Originally Posted by Monte View Post
I have that. ^^^^^
Old 01-28-2012, 07:52 PM   #9
GirlnAgarage
Senior Member
GirlnAgarage's Avatar
The type of work you use it for will help you determine which you need. IIRC the Dremel has a higher max rpm than the Proxxon (at least the longeck I looked at).
I use a Dremel variable speed and a Cman single speed rotary - alot. The Cman serves the role of 4" angle grinder. The Dremel is up in my other workshop.
Anyway, figure out which works for you. Also consider parts ad attachment availability.
__________________
Previous garage; all pics removed
My Garage: Reorganization, it's like a renovation
GirlnAgarage is offline   Reply With Quote
Old 01-28-2012, 08:04 PM   #10
american lockpicker
Dremel has at least twice the RPM but Proxxon does great at lower speeds.
Old 01-29-2012, 01:22 PM   #11
crewchief888
Senior Member
crewchief888's Avatar
i've had a multispeed CM for 20 years or so.
it makes a little noise, and more than once has gotten hot enough to not be able to handle without gloves.
i dont know how or why it still works.
__________________
I'm a legend in my spare time
crewchief888 is offline   Reply With Quote
Old 01-29-2012, 04:32 PM   #12
TjoFrasse
Senior Member
TjoFrasse's Avatar
When my old dremel copy died I got the proxxon IB/E. I thought about getting a somewhat cheaper dremel instead, but every time I use the proxxon I'm glad I didn't. The proxxon is great! Strong and stable speed, even with heavy load. Plus a solid quality.
__________________
Quote:
Originally Posted by Sharkin View Post
It's all Monte's fault.
My garage restoration thread
TjoFrasse is offline   Reply With Quote
Old 01-29-2012, 04:45 PM   #13
geologist
Senior Member
geologist's Avatar
I killed the Dremel I owned.
My Dad killed his Dremel.
My Grandpa killed 5 or 6 Dremels.
I bought a cheapie "Tool Shop" rotary tool from Menards. Problem solved for $9.99 (on sale). Haven't looked back since.
__________________
Quote:
Originally Posted by PugetDude View Post
Does Snap-On make a spatula? You could buy it for the dropout kid to use in his next job.
Quote:
Originally Posted by propav8r View Post
It's Harbor Frieght...I can't imagine a 20% restock fee ever costing more than $0.17.
Speak the truth, even if your voice shakes.
geologist is offline   Reply With Quote
Old 01-29-2012, 05:05 PM   #14
scott37300
Senior Member
I have been looking at dremels lately also, my last one the pin to hold the shaft lock got worn and won't hold bits anymore so it's junk. Still works good but would have to replace the whole shaft which is almost as much as a new one.
Never heard of proxxon before. Any details about them? Which model should I look at? Any reasons in particular that they are better than a dremel?
scott37300 is offline   Reply With Quote
Old 01-29-2012, 07:19 PM   #15
Monte
Senior Member
Monte's Avatar
Quote:
Steel chuck instead of a aluminium chuck, Made in EU, more ergonomic (imho), professional quality w/ metal gear housing (see pic above), some Proxxon models are used (rebadged/recolored) in the professional "Xenox" tool lineup for dentists, manicure, laboratory, technicians etc: Xenox tools
Old 01-29-2012, 08:16 PM   #16
Monte
Senior Member
Monte's Avatar
the accessories are usually of good quality too
Old 01-29-2012, 08:28 PM   #17
Monte
Senior Member
Monte's Avatar
Some pics of my Proxxon Micromot 50
Old 01-29-2012, 08:36 PM   #18
kippieland
Senior Member
kippieland's Avatar
Monte, I am requesting you start your own thread called: "Tools with Monte, a tour of excellences!" I swear you have every cool tool or any tool out there. I think it would be as popular as "so your tool box" thread. If you don't, I may have to start a thread that will try to convience you to do it!
kippieland is offline   Reply With Quote
Old 01-29-2012, 08:53 PM   #19
american lockpicker
Quote:
What if we had a thread where you show all your tools from Europe and other places.
Old 01-29-2012, 08:58 PM   #20
Monte
Senior Member
Monte's Avatar
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
