Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-28-2012, 09:51 PM   #1
quick60
Senior Member
quick60's Avatar
Default Galvanized duct for dryer vent?
Not really garage related but can galvanized duct be used for a dryer vent?
I have a 12 foot run to cover in my crawl space and did not want to use the flex hose if I did not have to. However the more I think about the moisture issue and even though it is galvanized it may still rust out.
Any thoughts?
Thanks
quick60 is offline   Reply With Quote
Old 01-28-2012, 09:57 PM   #2
FrankieD
Default Re: Galvanized duct for dryer vent?
Have you considered PVC?
FrankieD is offline   Reply With Quote
Old 01-28-2012, 10:10 PM   #3
quick60
Senior Member
quick60's Avatar
No I have not. That could work I guess. Fire hazard would be my only concern.
Old 01-28-2012, 10:22 PM   #4
DoyleDee
Senior Member
I have seen it used . If it is behind a wall- it is used. It has been a few years since I was installing hvac, but it is what I remember.
I have also seen a telescoping style made out of sheetmetal (rectangular with couplings on the ends).
DoyleDee is offline   Reply With Quote
Old 01-28-2012, 10:25 PM   #5
MN BIANCHI
Senior Member
MN BIANCHI's Avatar
Galvinized is OK, it will take a long time to rust if ever.
PVC is NOT approved for dryer venting unless it is buried in concrete.
MN BIANCHI is offline   Reply With Quote
Old 01-28-2012, 11:12 PM   #6
JimVonBaden
Senior Member
JimVonBaden's Avatar
Quote:
My new house uses it. Make sure it is insulated so it doesn't sweat into your attic.
Jim
JimVonBaden is offline   Reply With Quote
Old 01-28-2012, 11:44 PM   #7
RHD 4 LIFE
Senior Member
RHD 4 LIFE's Avatar
Use 4" white 636 Ipex piping for gas furnace venting!
RHD 4 LIFE is offline   Reply With Quote
Old 01-29-2012, 12:02 AM   #8
napaAl
Absolutely. Here in Nor Cal we use galvanized pipe (duct). No screws to catch lint. Tape only at joints. Runs over 13' in length need boosters.
napaAl is offline   Reply With Quote
Old 01-29-2012, 01:43 AM   #9
Cougar67
Senior Member
Cougar67's Avatar
Ha! Like OP I live in VA too! My house was built 15 years ago and I have a 12 foot run in the upstairs crawl space. The laundry room is upstairs. Originally the duct was flexible plastic I had the good sense to replace it with the flexible metal. I clean it out about twice a year. I had thought about replacing it with the sheet metal piping they sell for gas water heater venting. The obvious option of venting straight from the back of the dryer would put a hole in my roof on the downward side of a steep slope. I can't imagine what the original designer of this house was thinking. I'm the original owner and although it's a builder home I pored over the plans while it was being built and did catch a few "mistakes." I didn't catch this! What is this "booster" NapaAl speaks of?
Cougar67 is offline   Reply With Quote
Old 01-29-2012, 01:47 AM   #10
rockchucker
Senior Member
Quote:
100% agreed. ^
__________________
Sig by FairladyZ90
"It took you longer to explain why you were doing it wrong than it would have to do it right in the first place." -Some Old Dude
"All it takes is Time and Pressure..." -Some Old Dude
rockchucker is offline   Reply With Quote
Old 01-29-2012, 01:51 AM   #11
Torque1st
Senior Member
Torque1st's Avatar
I prefer aluminum over galvanized for dryer vents. The galvanized pipe surface roughness seems to catch lint fibers easier than aluminum so clogs build up faster.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 01-29-2012, 03:36 AM   #12
Norcal
Senior Member
AL flex duct is not a good choice for dryer venting it will catch lint & build up debris inside. Galvy duct is used around here.
Norcal is offline   Reply With Quote
Old 01-29-2012, 06:55 AM   #13
djjsr
Senior Member
djjsr's Avatar
I own a laundromat with dozens of large dryers. All have galvanized ductwork and most of it has been there for over 40 years.
If your crawlspace is cold, you may get some condensation. Just pitch the duct so the water can run out.
djjsr is offline   Reply With Quote
Old 01-29-2012, 08:36 AM   #14
quick60
Senior Member
quick60's Avatar
Thanks for all of the responses. Guess I will stick with the galvanized.
I could not find aluminum rigid duct. That is what I wanted to use but Lowes only carried the galvanized rigid, the alumunium flex duct, or the plastic wire reinforced stuff that I had no intention of using for this.
THANKS AGAIN!!
Old 01-29-2012, 08:40 AM   #15
steve911
What do you use as a booster for the longer runs?
__________________
Steve A.
Cottage Grove, WI
Your Mileage May Vary
steve911 is offline   Reply With Quote
Old 01-29-2012, 01:58 PM   #16
Torque1st
Senior Member
Torque1st's Avatar
Quote:
I don't use Aluminum flex duct, I use smooth Aluminum ductwork. It looks just like the standard galvanized stuff just a lot smoother. Aluminum costs a bit more and is harder to find but well worth the effort and cost. The way steel products are going it might even cost less nowadays...
__________________
The FairTax
Old 01-29-2012, 03:00 PM   #17
nehog
Senior Member
nehog's Avatar
Quote:
Do not use anything that will burn. That leaves out plastics.
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
Volvo S80
Holiday Rambler Ambassador 40 DFD
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 01-29-2012, 06:20 PM   #18
sabercatt
Senior Member
install a lint trap as well to help keep it clean
sabercatt is offline   Reply With Quote
Old 01-29-2012, 06:39 PM   #19
quick60
Senior Member
quick60's Avatar
I found rigid aluminum duct in two foot sections. Pieced it all together and sealed it with aluminum tape. Worked like a champ.
Thanks again for the help.
Old 01-29-2012, 10:17 PM   #20
Torque1st
Senior Member
Torque1st's Avatar
Cool...
Where did you find it?
Sorry about the disjointed post. I am having a little diabetes problem, hypoglycemic event.
__________________
The FairTax
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
