Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-07-2012, 06:23 PM   #1
lowcountrygamecock
Senior Member
Default Homemade septic tank/Field lines
Wasnt sure where to ask this. Say a man was to want to build a home made septic tank and field lines for a small shop bathroom. Something that theoretically did not have to be built to code. How would he go about doing that? He wants to do it as close to code ad possible without going through dhec and without spending a fortune. Any thoughts? Theoretically of course.
lowcountrygamecock is offline   Reply With Quote
Old 02-07-2012, 06:39 PM   #2
Senior Member
theoldwizard1's Avatar
Default Re: Homemade septic tank/Field lines
If you have sandy, well draining soil and a low water table (you do know what "low country" means, don't you ?) and we are talking one toilet and sink (no tub or shower), you can do it the old fashioned way.
Dig a pit about 8-10' deep. Lay about 1' of 3/4" gravel in the bottom. Put a 55 gallon drum in the pit. In the upper half of the barrel, drill a bunch of 3/4-1" holes. Make a hole in the top to receive the waste. Back fill the pit with 3/4" gravel up to the top of the barrel. Fill the rest with the dirt you removed. You want the top of the barrel to be at least 3-4' under the ground.
If you want to install a shower, do the same on the opposite side of the building.
As long as the volume is low (no jello wrestling that will require 10-15 people to shower) you will be fine. If you are going to have a well, I would make certain that it is about 40-50' away.
This does work ! My BIL has a some property where he camps. The wife wanted a "real" bathroom, not an out house. His only problem is refilling the water tank that is used to flush the toilet.
theoldwizard1 is offline   Reply With Quote
Old 02-07-2012, 06:45 PM   #3
mad57
Senior Member
mad57's Avatar
There was a small local business were we sold stuff from and they had problems with there septic after the man who rented it turned food vendor, well after digging it up it was a 55 gallon drum with holes from half way up to top surrounded by 3/4 clean rock with a pipe coming out the 3/4 area of the top of the barrel and into a broken up cinder block drain field, whick had layers of tar paper over it than reg dirt fill, worked great for many years until the restaurant guy came and washed tons of stuff all day long. should work great for you as well, if you add the septic helper it will work real good it in a small packet to help generate bacteria.
__________________
Work to live not live to work.
Iam also vice president of my car club: Wickedridesnj.com check it out!!!!
mad57 is offline   Reply With Quote
Old 02-07-2012, 07:21 PM   #4
larry4406
Senior Member
My father in law's cottage in Canada has the system mad57 described, except that river rock was used instead of cinder block. He plumbed the toilet only to this system. The sink and the shower drain out on the ground.
larry4406 is offline   Reply With Quote
Old 02-07-2012, 07:25 PM   #5
sailcat
Junior Member
Try this site. I installed this system except I used 10 inch gravelless pipe for the drain field. I have not used it yet because the shop is not completed yet. http://www.wikihow.com/Construct-a-Small-Septic-System
sailcat is offline   Reply With Quote
Old 02-08-2012, 03:03 PM   #6
lowcountrygamecock
Senior Member
Thanks guys. That's why I love this forum.
Old 02-08-2012, 04:12 PM   #7
TommyK
Senior Member
I would recommend using at least 1 1/4" stone. The voids in the 3/4" will clog quicker. Line the hole with filter fabric and top the stone with it as well before backfilling. Theoretically.
TommyK is offline   Reply With Quote
Old 02-08-2012, 07:00 PM   #8
lowcountrygamecock
Senior Member
Does it have to be rock? They used chopped up rubber tires in my house system. Definitely easier for me to haul if that would work.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
