Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 02-13-2012, 08:25 PM   #1
kyrbz
Senior Member
kyrbz's Avatar
Default Turning Corian on the lathe
Awhile back I made a set of replacement knobs for my BMW Isetta. The original ivory knobs were cracked and falling apart. I chose a bone colored Corian (acrylic solid surface material) to make the new knobs out of. Corian turns and taps great. Fun little project.
http://bzisettas.blogspot.com/2010/08/isetta-knobs.html
http://bzisettas.blogspot.com/2010/0...ater-knob.html
kyrbz is offline   Reply With Quote
Old 02-13-2012, 10:25 PM   #2
rlitman
Senior Member
Default Re: Turning Corian on the lathe
It sure does. That stuff is a dream to machine, and there's no wonder it's a favorite of many pen turners.
rlitman is online now   Reply With Quote
Old 02-15-2012, 03:23 PM   #3
smschriefer
Senior Member
smschriefer's Avatar
Great work on the knobs and even better work on the Isetta! I just read every post on the car restoration that is in progress. Your attention to detail is insane - in a good way. I can't wait to see the body mated to that impeccably restored frame!
__________________
Steve
smschriefer is offline   Reply With Quote
Old 02-15-2012, 10:00 PM   #4
kyrbz
Senior Member
kyrbz's Avatar
Quote:
Thanks for the compliment!
Old 02-15-2012, 10:28 PM   #5
Trucky
Senior Member
Trucky's Avatar
Is the tool just brazed carbide or is a PCD tip on there as well? They look rather good by the way.
Trucky is offline   Reply With Quote
Old 02-15-2012, 11:13 PM   #6
kyrbz
Senior Member
kyrbz's Avatar
Quote:
It's a carbide insert that is mounted upside down in the tool holder of the lathe duplicator. I have the duplicator installed on the backside of my wood lathe so that I can turn freehand normally from the front.
The carbide insert leaves a little bit of a grooved surface in the Corian, so after the using the duplicator I would go back and do a little final shaping and smoothing with a skew chisel by hand before sanding and polishing.
Old 02-15-2012, 11:52 PM   #7
mtnkrake
Senior Member
The restoration of the chassis looks real good. I can't wait to see it with the body on it.
mtnkrake is offline   Reply With Quote
Old 02-16-2012, 12:31 AM   #8
Beaumont67
Senior Member
Beaumont67's Avatar
kyrbz - great job on the Corian turnings and nice web site, as well.
I would like to see an overall photo of your lathe, if possible.
- looks like you have a nice setup
- is it a wood lathe with a 3 jaw chuck & variable speed DC motor, or a metal lathe ?
Beaumont67 is offline   Reply With Quote
Old 02-16-2012, 11:58 AM   #9
smschriefer
Senior Member
Quote:
I've provided a link to your Isetta blog on Red Leader's, 1950 Craftsman Garage page regarding electroless nickel plating. Your work is truly impressive.
__________________
Steve
Old 02-16-2012, 02:22 PM   #10
bimmer1980
Senior Member
bimmer1980's Avatar
that was quite interesting and entertaining to read through your whole blog. I didn't have time to read all of the BMW literature you had posted, but I may have to when I have more time.
My twin brother wants to find an Isetta to restore some day.
Nice work!
__________________
-- Brad --
Currently working on a new garage....Exterior is finally done...working on electrical, etc inside.
28x44 with attached workshop area of 16x28. 1600 sq total.
bimmer1980 is offline   Reply With Quote
Old 02-16-2012, 04:07 PM   #11
willymakeit
Senior Member
Thats what I need to do to my 56 F100. Those corian knobs are sweet.
willymakeit is offline   Reply With Quote
Old 02-16-2012, 07:58 PM   #12
kyrbz
Senior Member
kyrbz's Avatar
My wood lathe is a Vega 1446 with a Vega lathe duplicator that I purchased around 14 years ago. It has a variable speed Reeves pulley mounted on a Baldor motor. I have a Oneway Stronghold 4-jaw chuck and Oneway live center mounted on it. One of the things I didn't like about it was there was no spindle lock or indexing. The close up photo I attached is of a spindle lock and indexing modification I made for it. The tail stock was also a little chintzy so I did some improvements like adding bronze bushings on the locking mechanism and machining a few pieces that are a little more robust with tighter tolerances than what came on the lathe.
Old 02-16-2012, 08:13 PM   #13
NASTYZEN
Senior Member
NASTYZEN's Avatar
Nice setup and work kyrbz!
What do you use the idexing for, may I ask?
BTW, you may get even better results on plastic using tool steel. You can get a sharper edge than on carbide and you can even shape it to your liking.
__________________
"Engineering is the art of modelling materials we do not wholly understand, into shapes we cannot precisely analyse so as to withstand forces we cannot properly assess, in such a way that the public has no reason to suspect the extent of our ignorance."
- Dr AR Dykes
You can get your Dimple Dies here: http://www.r-fabriplus.com/
NASTYZEN is offline   Reply With Quote
Old 02-17-2012, 07:38 AM   #14
kyrbz
Senior Member
kyrbz's Avatar
Fluting or making cuts along the length of a turned piece.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
