Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-27-2012, 08:51 AM   #1
DonIvey
Default Can You Replace 20amp Breaker with 30amp?
I have a Maxjax that requires 30amp breaker. My garage is fairly new, but has 20amp breakers for wall outlets. Can I just replace one with a 30amp breaker to use for the Maxjax? Thanks,
Don Ivey
Smithfield, NC
DonIvey is offline   Reply With Quote
Old 02-27-2012, 08:53 AM   #2
jxm7202
Junior Member
Default Re: Can You Replace 20amp Breaker with 30amp?
no you will overload the circuit.
jxm7202 is offline   Reply With Quote
Old 02-27-2012, 08:58 AM   #3
bww_mnm
Senior Member
Quote:
Don Ivey
Smithfield, NC
No. Your wiring won't handle 30a. Potential fire hazzard.
bww_mnm is offline   Reply With Quote
Old 02-27-2012, 09:03 AM   #4
djd99
Senior Member
djd99's Avatar
Everybody will say no because code says you have the have #10 wire for a 30 Amp breaker. I will say this I've been doing it for my air compressor and don't have any issues it's just not code.
I still won't recommend it for that reason but I will continue to do it as I cant rerun a #10 wire. My compressor will not run on a 20 amp circuit without tripping the breaker on startup so I threw in a 30 and haven't had a problem since. Don
__________________
Don
djd99 is offline   Reply With Quote
Old 02-27-2012, 09:08 AM   #5
raddksn
Senior Member
raddksn's Avatar
this is the drawback of romex you cant just pullout the #12,s and pullin the #10,s you need 2 #10,s and a #12 ground for 30 amp
raddksn is offline   Reply With Quote
Old 02-27-2012, 09:12 AM   #6
plinker
Senior Member
plinker's Avatar
For code, you will need to run 10ga or bigger wiring for the 30A breaker.
I would run 8ga wire myself.
I dont know how many amps a lift pull's, but your compressor wont likely overload the circut as bad, I think.
__________________
Have a Snap-on ratcheting screwdriver? check out this link...
http://www.garagejournal.com/forum/s...ng+screwdriver
plinker is offline   Reply With Quote
Old 02-27-2012, 09:17 AM   #7
dirttracker18
Senior Member
dirttracker18's Avatar
Very different for a compressor that sees a spike in amps when it turns on then likely levels out at something much lower. If your compressor is suppose to run on 20 amps (does it have a 20 amp plug on it? Rating on compressor?) and trips the breaker you have a problem and should get it fixed.
A heater on the other hand will see a continious pull of higher amps. Code is there to protect you not to be some kind of a hassel. Do it right and sleep well at night.
Simple answer is no, you are asking for a fire in your wall.
Run an external line (correctly sized and shielded if not in conduit) out of your panel to an new appropriate outlet directly below. Short and sweet and within code.
Perhaps an electrician can chime in here (or place this in electrical as well) and let us know if you can run it right next to your panel and how short it can be.
__________________
"Success is when you reach a point in your life when you don't feel the need to go back and change things."
Johnny S.
www.LauraMyersPhotography.com
dirttracker18 is offline   Reply With Quote
Old 02-27-2012, 09:36 AM   #8
DonIvey
Thanks for all the replys. I think the external line in conduit will suffice, and I'll feel safer when using it. Thanks again,
Don
Old 02-27-2012, 09:37 AM   #9
Iroc-Z
Senior Member
Iroc-Z's Avatar
I wouldn't do it. But hey its not my garage.
Iroc-Z is offline   Reply With Quote
Old 02-27-2012, 09:38 AM   #10
Iroc-Z
Senior Member
Iroc-Z's Avatar
Don
This is a great idea.
Old 02-27-2012, 09:48 AM   #11
1948
Senior Member
1948's Avatar
ever look at how a lightbulb works? imagine that as your wires in your wall....... covered with a nice melt-able plastic.....
1948 is offline   Reply With Quote
Old 02-27-2012, 09:52 AM   #12
FreddiFiche
It's your garage.....but something to consider;
If you do have a fire (we all hope not!), whether this is the cause or not, your just setting yourself up for a fight with the insurance company. They are very good at the miss-direct, delay, 'find any reason to delay/reduce the payout.' If they bring in a fire investigator, one of the first things they do is run down the breakers, looking at sizing and wire tied to it. (And this doesn't have to be a 'total loss' fire either....)
Not trying to be preachy, just really don't want you to end up on the short end of the stick if something bad does happen. Any way to add a new run? (Even surface mount?)
Good luck.
Freddi
FreddiFiche is offline   Reply With Quote
Old 02-27-2012, 10:06 AM   #13
cw_racefan
Senior Member
Don Ivey
Smithfield, NC
On top of what everyone else has said, I questioned this when I first got my MaxJax, because they were inconsistent with what they said for ratings. Mine was an early one, so they may have changed, but the unit itself does not have a 30 amp plug on it. I called them and they said a 20 amp circuit would be fine. Been using mine for three years now and never had an issue on a 20 amp circuit (dedicated circuit).
Craig
cw_racefan is offline   Reply With Quote
Old 02-27-2012, 10:07 AM   #14
djd99
Senior Member
djd99's Avatar
[QUOTE=dirttracker18;2131628]Very different for a compressor that sees a spike in amps when it turns on then likely levels out at something much lower. If your compressor is suppose to run on 20 amps (does it have a 20 amp plug on it? Rating on compressor?) and trips the breaker you have a problem and should get it fixed.
I have a 5hp farm duty that needs around 30 amps on startup
Don
Probably they best solution is to run a new line.
Good luck.
Freddi
thanks freddi but Id be screwed anyway as my garage is not insured......
__________________
Don
Old 02-27-2012, 11:44 AM   #15
Viriiguy
Senior Member
Are you supposed to? no. However in my current rental.. The dryer was on a 20 amp breaker. It kept kicking it. two years ago I yanked it and put a 30 amp in it.
Never had an issue since.. And I have checked, the wires are not hot under load.
With that said... YMMV. Fishing a new wire is not that hard.
Viriiguy is offline   Reply With Quote
Old 02-27-2012, 11:57 AM   #16
nmk_61802
Senior Member
Quote:
Craig
I'll add this:
http://www.garagejournal.com/forum/s...maxjax+breaker
nmk_61802 is offline   Reply With Quote
Old 02-27-2012, 12:16 PM   #17
mikeyr
Senior Member
mikeyr's Avatar
I run my MaxJax on a 20amp circuit, not popped the breaker yet.
I would not change the breaker without changing the wires but I would try your MaxJax on the 20 and I bet it works, just like mine.
__________________
My new toy is at http://www.singercars.com :)
mikeyr is offline   Reply With Quote
Old 02-27-2012, 12:20 PM   #18
dirttracker18
Senior Member
Wrong thread, he is talking about a heater here.
__________________
Johnny S.
Old 02-27-2012, 12:27 PM   #19
MoonRise
Senior Member
MoonRise's Avatar
Can you? Sure.
Should you? Different question and the answer is "It depends".
But in general the answer is "No, do not go and put a 30 amp breaker in place of a 20 amp breaker because the wiring is most likely 'sized' for the 20 amp load and -may- overheat if a 30 amp load is used with wiring sized for a 20 amp load."
Some (limited) exceptions may exist for things where "duty cycle" come into play.
But in general, for some "outlets" wired up on a 20 amp circuit breaker then the answer is almost always "No, don't replace the existing 20 amp breaker with a 30 amp breaker".
MoonRise is offline   Reply With Quote
Old 02-27-2012, 12:29 PM   #20
nmk_61802
Senior Member
Quote:
Seems to me like he is asking about a Maxjax like everyone else believes
Don Ivey
Smithfield, NC
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
