Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-16-2005, 11:34 PM   #1
Cebby
Senior Member
Cebby's Avatar
Send a message via AIM to Cebby
Default "Cinder" block garage - encapsulate somehow?
My garage is pretty old. We estimate that is was initially built in the 30's or 40's.
It is a detached 2 car 2 story building. My question is what can I apply to the block to keep it from deteriorating - currently, if I rub my hands over the block, it feels like sand falling off of the block (not sure if that makes sense). These are not like normal present day concrete blocks. It is currently untreated and not top coated in anyway.
One side of the building will need something extra durable applied since I'm adding a parking pad and the wall will likely get balls bounced off of it by my kids.
Cebby is offline   Reply With Quote
Old 09-16-2005, 11:52 PM   #2
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Default
That's a good question. I would think any kind of coating would not stick since the surface is already deteriorating. Removing part of the surface that is deteriorated and then coating the good, lower layer may be something you can do... but that will depend on how thick the "bad" layer is.
bmwpower is offline   Reply With Quote
Old 09-17-2005, 05:56 AM   #3
danski0224
Senior Member
Default
might want to consider getting a mason to look at the blocks and make sure they are sound.
danski0224 is offline   Reply With Quote
Old 09-17-2005, 06:37 AM   #4
imported_banzaitoyota
Senior Member
Default
Quikrete makes a product called Surface Bonding Cement, applies with a trowel and gives a stucco like appearance
http://www.quikrete.com/catalog/QUIK...ingCement.html
imported_banzaitoyota is offline   Reply With Quote
Old 09-17-2005, 12:17 PM   #5
Ken Greene
Senior Member
Default
if the surface is unstable... (sanding) then the quickcrete material will fail also. You need a solid stable surface first.
you may need to try a sealer first to "glue" the sand in place first then any type stucco type finish should be fine. if a sealer will not stablize the surface and the blocks are still sounf all i could think of would be side it. then at least the weather will not advance the sanding of the surface
Ken Greene is offline   Reply With Quote
Old 09-18-2005, 08:26 AM   #6
plepper
Certified Garage Junkie
Default
I've been a Bricklayer for 30 yrs. If you want you can send me some pics and I'll try to give some advice. You might try sandblasting to get to stable surface and then try a coating to prevent futher damage. What is the climate like where you live? Freeze thaw cycle?
plepper is offline   Reply With Quote
Old 09-19-2005, 03:29 PM   #7
camarojim
Junior Member
Default
you could do what I did to my block bld..it was made of ''hadite'' block, suppose to be lighter and more thermal inulating..ha , NOT..they are softer and started to crumble from the heat/cold cycle and water vapor coming thru...
we stripped the bld with 2x4's by using tapcon screws..put some styrofoam insulation between the strips and then covered it with steel roof siding..
made it look nicer, and helped become warmer too.
Jim
camarojim is offline   Reply With Quote
Old 09-19-2005, 05:03 PM   #8
Cebby
Senior Member
Cebby's Avatar
Default
OK, here's some pics. First two pics are the exterior, last two are the interior. I went out and rubbed my hands all over the outside - it isn't as bad as I thought. After the initial loose material comes off, they are pretty solid. It is a pretty dramatic difference in appearance from the exterior to the interior though...
Exterior:
Interior:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Living area in a Garage? MAK General Garage Discussion 7 11-23-2011 09:28 AM
New Guys garage DaveL. Garage Gallery 26 06-06-2008 10:33 AM
options for concrete block walls?? slapshot General Garage Discussion 23 08-09-2005 02:01 PM
Garage remodel update... SANDOVAL Garage Gallery 5 07-21-2005 08:32 PM
My Garage plans... SANDOVAL General Garage Discussion 2 03-21-2005 08:44 AM
