Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 03-05-2012, 05:23 PM   #1
Primered Thunder
Default Vise stand
Wanted to ask if anyone has ever made a vise stand. I picked up an older Craftsman 4" bench vise a few months ago and after reading some of the posts here decided to dis-assemble, clean and repaint. I now want to mount this vise on it's own stand but wanted to ask what you guys have used for a base to counter the weight of the vise. I already have a 5" vise mounted on my work bench and thought this 4" unit would be the perfect size to make a "portable" work holding unit out of.
Any pics that anyone has would be awesome. thanks!
Primered Thunder is offline   Reply With Quote
Old 03-05-2012, 06:25 PM   #2
sanddan
Default Re: Vise stand
My vise has always been mounted on a simple stand made from a round drop out and square tubing. The drop out (left over when a round hole is cut in a larger plate) is heavy enough to stabilize the vise and can be easily moved. You can see it the attached pic just to the left of center.
sanddan is offline   Reply With Quote
Old 03-05-2012, 06:54 PM   #3
2mJps
Senior Member
My vice is mounted on a pipe that is welded to a truck rim. I made a little shelf on it but evey thing falls off when you use it. It is nice that can move it out side to use it when I grind,cut or weld something in it.
2mJps is offline   Reply With Quote
Old 03-05-2012, 07:25 PM   #4
CARS
Senior Member
CARS's Avatar
My air vise is mounted on a 3'x4' plate of steel. Works even better when I throw my 200lb ass on the plate!
CARS is offline   Reply With Quote
Old 03-06-2012, 08:57 AM   #5
csp
Senior Member
I used a brake drum from a cab & chassis GM 14 bolt.
csp is offline   Reply With Quote
Old 03-06-2012, 08:55 PM   #6
Displaced Hokie
Senior Member
Displaced Hokie's Avatar
I built two. The yellow one is filled with sand, and serves a double purpose of storing the wheel weights to my garden tractor. It's made from a post I found at the scrap place. It used to hold a guard rail. I just added the top plate mainly. I may bolt it to the concrete floor of my carport in the new house.
The black one uses the "my 230lbs of ass standing on it" stability trick. It was a happy accident that the diameter of the pipe on the black one exactly matched the base of my green vise, so it just had to add mounting ears versus a plate. Made for a very clean mount I thought.
__________________
Building a decent garage and toolbox...one tool at a time.
Buy the best you can and upgrade as needed. USA if possible. To heck with tool snobs!
Displaced Hokie is offline   Reply With Quote
Old 03-08-2012, 04:51 PM   #7
duke182
Junior Member
duke182's Avatar
heres mine
__________________
having fun with cars til i die!!!
duke182 is offline   Reply With Quote
Old 04-17-2012, 07:32 AM   #8
coolreed
Senior Member
coolreed's Avatar
Here is the neatest stand I ever saw.
I don't know who owns or built it. Bit IIIIIII like it.
coolreed is offline   Reply With Quote
Old 04-17-2012, 09:07 AM   #9
plinker
Senior Member
plinker's Avatar
I found a pair of wood lathe leg's at the junkyard (cast iron) and bolted a piece of 3/8 plate to it and put one of my vise's on it. Works well and is somewhat portable.
The bench in the pic is what I want to make though.
__________________
Have a Snap-on ratcheting screwdriver? check out this link...
http://www.garagejournal.com/forum/s...ng+screwdriver
For hand tool warranty info, see link
http://www.garagejournal.com/forum/s...ad.php?t=38749
plinker is offline   Reply With Quote
Old 04-17-2012, 10:31 AM   #10
gorilla
Senior Member
If you have a brake shop in your area that works on big trucks or buss's visit them and ask for a scrap brake drum. They are quite heavy and about 20" in diameter. I've used them for bases for stands for lot's of shop equipment. I got all of mine for free but considering the current prices for scrap metal you might have to pay a few $.
gorilla is offline   Reply With Quote
Old 04-17-2012, 11:04 AM   #11
ndnchf
Senior Member
I'm not sure who's this is, but I like the idea of bolting it to an old brake rotor. I'm going to do the same thing for m welding table.
ndnchf is offline   Reply With Quote
Old 04-17-2012, 11:17 AM   #12
Jamesbbh
Senior Member
Mine, the "vicenator". It's a laptop stand they were throwing away out of the ER at the hospital where I work. Rolls around and height adjustable/lockable. ** did have a vise on it for a little while but beating on anything wasn't working out so switched to a grinder.
This is my "beat the hell out of something vise
Jamesbbh is offline   Reply With Quote
Old 04-17-2012, 11:19 AM   #13
PCO6
Senior Member
PCO6's Avatar
I'll try to post a picture later but I simply used a 5 gallon metal can with concrete filled to within 4" of the top. Before pouring the concrete I installed a 4" pipe with a brake rotor welded to each end of it. The bottom rotor sits on the bottom of the can encased in the concrete and my vice is bolted to the top rotor. You could fill the concrete to the top of the can for even more weight but leaving it down by 4" or so gives you a good area for hammer, etc. storage.
__________________
PCO6 is offline   Reply With Quote
Old 04-17-2012, 11:56 AM   #14
lilredex
Senior Member
This is mine (6" Record) at my old location. These days it is in my garage, with wooden walls........not quite as stable.
lilredex is offline   Reply With Quote
Old 04-17-2012, 01:54 PM   #15
t100
Senior Member
t100's Avatar
old, not new bandsaw stand:
__________________
Quote:
Originally Posted by RbrtAWhyt View Post
Next time tell them "Yeah, well, if my aunt had a dick she would be my uncle..."
t100 is offline   Reply With Quote
Old 04-17-2012, 05:02 PM   #16
AZAV8
Mine is simple. A 2 inch receiver tube welded to a plate that bolts to a new/used Ford truck wheel. I filled the bottom side of the wheel with concrete. That gives me a weighted base. My big vise is bolted to a round plate that has a square tube welded perpendicular to it so it slips inside the 2 inch receiver tube. When I want to I roll it outside and grind, wire brush and all the crap is outside. I also have my grinder attached to a plate with a similar square tube so I can change out the vise for the grinder and voila, one base is useable for more than one tool. The future disc sander and belt sander will have similar tube/plate setups so I can use them on the receiver tube base. I'm making one for my portable band saw attached to a bench stand. I don't have pictures available for the stand.
Phil
AZAV8 is offline   Reply With Quote
Old 04-18-2012, 04:38 PM   #17
sanddan
The vise handle is pretty sweet too.
Old 04-18-2012, 07:15 PM   #18
bl00
Senior Member
Info here:
http://www.garagejournal.com/forum/s...ad.php?t=66316
It had a brief cameo in the first episode of his new show, too.
bl00 is offline   Reply With Quote
Old 05-15-2012, 08:32 AM   #19
Journaler
Senior Member
Journaler's Avatar
Quote:
Awesome!
I had been wondering what to do with the brake rotors from my pickup!
Journaler is offline   Reply With Quote
Old 05-15-2012, 11:12 AM   #20
jdcompman
Senior Member
jdcompman's Avatar
Quote:
Originally Posted by bl00 View Post
Info here:
Hmmm that's not even the same vise on there...
jdcompman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
