Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#41 |
Senior Member
Hoist to Crossmember Nuts (All Pickup Models)
25 N·m 18 lb ft Hoist to Wheel Carrier Nuts (4 Door Utility Models) 47 N·m 35 lb ft Support Bolts (Suburban Models) 5 N·m 44 lb in Support Bolts (2 Door Utility Models) 44 N·m 32 lb ft Wheel Nut Stud (C1) (5 Studs) 170 N·m 125 lb ft Wheel Nut Stud (CK1, 2) (6 Studs) 170 N·m 125 lb ft Wheel Nut Stud (CK2, 3) (Single Wheel) (8 Studs) 170 N·m 125 lb ft Wheel Nut Stud (CK3) (Dual Wheel) (8 Studs) 170 N·m 125 lb ft Wheel Nut Stud (C3500HD) (Dual Wheel) (10 Studs) 220 N·m 162 lb ft I hope this works. Scott |
#42 |
Senior Member
Hope this helps you darrin88
#43 |
Senior Member
Honestly, I've never used a torque wrench on a wheel and I have yet to have any problems. That's with 24 years of driving and at least a dozen different cars and trucks.
#44 |
Senior Member
99.9 or the mechanics in the world pay no attention to the torque specs. No matter what they say or claim. That includes folks on this forum!
Last time I had the tires changed on the old Durango I over heard the dealer tech say, "not one of these lugs were tight! I wonder why they didn't fall off?" I ALWAYS torqued my wheels to the correct setting. In the case of the Durango, it was 90 ftlbs. Once they wheels were back on I asked the manager if he used a torque wrench to put the jugs on. He called the tech over and asked him. Both said "no". I then asked if the even knew what the proper torque was. The both said "no". I then pulled my torque wrench out of the back of the truck and noted, with them watching, that they were tightened down to 160 ftlbs! I then showed them the owners manual where it showed 90 as the correct setting. I then had them put it back on the rack and use my wrench to set them correctly. I rarely have had a warped rotor and believe proper torque is the reason why.
__________________
UPDATED December 2012!!! WTB/WTT: Plomb WF :132, 122, 99 as well as line wrenches and all 3/4" drive. R.I.P. Bradley April 18, 2006 - November 27, 2012 Champion of my heart. |
#45 | |
Senior Member
Quote:
A good 3/8" gun will probably be able to handle it if you actually let it hammer for a full second or two. 2115timax - working forward torque - 230 ft/lbs. |
| Thread Tools | |
| Display Modes | |
