Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
There may come a time when you have an assembled engine ready, but the car may not be ready to accept the engine. You could leave the assembled engine on an engine stand, but if you are like me there are other engines waiting to be assembled. You need an engine storage stand that will allow you to bolt a complete assembled engine to it and be rolled somewhere for storage.
The engine storage stand I will be building is for a SBF (289,302,351W,351C,5.0) but the same principles apply to any engine. You will need an engine, or preferably a bare engine block to use as a jig to build the stand. The first step is to cut and drill some 1" x 1" x .125" angle iron to bolt to the motor mount bosses on the block. The bosses are 7/16", but I drilled them to 1/2". You can now bolt the pieces of angle iron to the block: ![]() ![]() The next are the rear uprights. They are made from 3/4" x 16 gauge square tubing. They will bolt to the outer most bellhousing bolts. They are also drilled with 1/2" holes. One of the uprights is 7/8" longer that the other. If building a stand for a different engine, the height of the upright will need to be determined so the oil pan will clear the ground, and the stand: ![]() The main framework is next. I used 14 gauge x 1" square tubing. The main rails are 22" long, the front cross piece is 11 3/4" long, and the back piece is 18" long. I used some scrap pieces that were not long enough, so I welded a few pieces together to get the lengths I needed. Square it all up and weld it up: ![]() The frame work is centered on the two rear uprights, and two front uprights made from 3/4" square are cut to 10 1/4" long. Everything is now tack welded on: ![]() I made a diagonal brace from 1/2" square tubing to keep everything square: ![]() Weld everything you can with the stand still bolted to the block so nothing will move around. You can now weld on some 2" steel casters to the bottom of the stand. Stay away from the rubber casters because the rubber will fail under the weight of the engine. I got these at Home Depot: ![]() ![]() A little paint, and it is ready for service:
#2 |
Senior Member
Nice tutorial...thanks for taking the time to share. Any pics of a complete engine mounted on it?
M_P
__________________
Rivets are the New Duct Tape. Very close to finishing up the first Fantastic Light Bracket in The Aerodrome Studio--my metalworking studio in a 2-car, attached garage, where I build artistic projects, inspired by aeroplanes - The Aerodrome Studio: http://www.garagejournal.com/forum/s...d.php?t=122188 - Solid Rivets 101: http://www.garagejournal.com/forum/s...d.php?t=172474 - Blog: http://TheAerodromeStudio.com/wordpress -Twitter @Machine_Punk |
#3 |
Senior Member
Very Cool!
Nice Job on the design and build! |
#4 |
Senior Member
is that ford blue LOL, some of the most usefull tools are the most simple nice work.
#5 |
Senior Member
Yes, 2 more pieces and some wheels needed.
__________________
www.urkafarms.com |
#6 |
Senior Member
#7 |
Senior Member
Shopping carts are only free when stolen....
I have a stand just like the one you built I bought from my neighbor for $10. Makes the engine short enough to slide under a bench. |
#8 |
Junior Member
Wow, great diy thread.. Im gonna build one for my many 302's i have kicking around
#9 |
Senior Member
I like your simple stand. I have all my extra blocks sitting on the cheap furniture dollies from HF.
__________________
ERIC Too much is.... Just enough. My garage refurb thread. http://www.garagejournal.com/forum/s...ad.php?t=75024 Are you military or prior military ? Please visit OUR thread and post your experience. http://www.garagejournal.com/forum/s...ad.php?t=64422 Take a look what your USA honorable service may have done for you. http://www.garagejournal.com/forum/s...d.php?t=100237 |
#10 |
Senior Member
great idea
but I can never find the casters cheaper than I can order one all done from jegs. |
#11 |
Junior Member
simple was the key for me...got the motor back from the machine shop..car not ready...very simple, rusty, but functional stand...larger stand in photo is for motor and tranny..sbc,bbc..muncie or T-350 trannys...smaller stand is just for motor..
#12 |
Senior Member
Nice info, i need to do this to my engines.
#13 |
If you have to buy new sreel and casters, its probable cheaper to buy 1. we were going to made them and sell em, but couldn't compete with emports and Harbor freight
#14 |
I have bought them from different places, and the casters are good for a one way trip, especially the rubber ones. The welding quality is also questionable as well as super thin tubing. There is a place for quality, because I sell them all the time.
#15 |
Senior Member
Does hf freight sell a stand like this? Ive never seen one unless you mean a regular engine stand?
#16 |
Senior Member
Just a heads up, not all carts are stolen. I got several when a local chain store replaced their whole fleet and posted the old ones for free on Craigslist. If you see me with one of my many things made from carts, don't assume I'm a thief.
Great job on the stand. Simple is best.
__________________
Singley Speed Shop 707-599-2315 I am a tool user, not a tool polisher |
#17 |
Senior Member
i also made one similiar to yours, except instead of putting four wheels on it, i set it on a furniture dolly from HF... works fine
__________________
Jim 2006 corvette 2011 SS camaro, synergy green 2011 chevy 4x4, 3500HD, duramax 2006 john deere rider mower 2013 harley fatboy 2014 39' 5th, Grand Design Solitude |
| Thread Tools | |
| Display Modes | |
