Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-14-2012, 01:35 PM   #1
bw77
Senior Member
bw77's Avatar
Default Best way to attach wood board to concrete wall?
I need to attach a 3ft length of 2x4, vertically, to the outside of the poured
concrete foundation of the house. This will be to anchor a post and block
off a space.
What is the best way to do it? Thanks.
bw77 is offline   Reply With Quote
Old 03-14-2012, 01:38 PM   #2
kmccorm2000
Junior Member
Default Re: Best way to attach wood board to concrete wall?
I've used Tapcons for stuff like this. Construction adhesive would also work if properly prepared. Generally I do both, glue and screw.
kmccorm2000 is offline   Reply With Quote
Old 03-14-2012, 01:39 PM   #3
Northstar
Senior Member
Northstar's Avatar
You can use an adhesive like PL400 (or whatever the proper one would be), or use a mechanical fastener such as the .22 cal driven ones.
__________________
Criticizing a guy's garage is like criticizing his wife. They may not all be beautiful, but it's his and that's where he goes for relaxation, recreation and a place to put his junk.
Northstar is offline   Reply With Quote
Old 03-14-2012, 03:37 PM   #4
wnstwolf
Senior Member
wnstwolf's Avatar
depending on how much force will be applied the most lasting approach are the "red-head" type fasteners for me at least. It maybe user error on my part but I have issues with the tapcons, I have the drill bits and drivers for them but still get the blow outs. this is in a thread somewhere on here. If it is a low strength install the PL and a few hilti shots is a faster/easier option and you get to shoot the gun!
__________________
E-type Jag Project http://garagejournal.com/forum/showthread.php?t=313591
wnstwolf is offline   Reply With Quote
Old 03-14-2012, 03:39 PM   #5
rlitman
Senior Member
How strong does it need to be?
On the outside, huh? If you're using pressure treated, forget about tapcons, or nails (I haven't seen galvanized red-heads, maybe look into this). ACS pressure treated requires galvanized fasteners. If you can drill the concrete, I'd put in an expanding insert, and use galvanized bolts (or a lead shield, with a galvanized lag bolt, but that's something I'd reserve for a "softer" material like brick; not with poured concrete)
Adhesive underneath is a good idea in addition.
rlitman is offline   Reply With Quote
Old 03-14-2012, 04:05 PM   #6
MoonRise
Senior Member
MoonRise's Avatar
"outside" + "wood" + "concrete" = PT wood
Which means stainless fasteners or hot-dipped galvanized (or equivalent).
Use the 'appropriate' fastener.
Speaking of 'appropriate', is a 2x4 on an exterior concrete wall 'appropriate' to "anchor" your structure? Including the wall itself, and the block to the wall, and whatever is attaching the block to the post or whatever? Just more stuff to check on.
MoonRise is offline   Reply With Quote
Old 03-14-2012, 05:16 PM   #7
Nick M
Agree with all the above except with using tapcons. I never have much luck with them either, so I stopped wasting money on them. I don't think 'strong' when I think tapcon. You can get galvy red heads, I have in the past at Lowes and used them with pressure treated wood. Just make sure to get them long enough to get the minimum depth in the concrete + 2x + washer and nut.
Nick M is offline   Reply With Quote
Old 03-14-2012, 05:19 PM   #8
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
Lag screws into expanding anchors is the old tried and true way.
Zeke is offline   Reply With Quote
Old 03-14-2012, 05:48 PM   #9
Kevin54
Senior Member
Kevin54's Avatar
^^^^This^^^^
That's about the only way I would do it to be certain it stayed
__________________
THE ADDITION
Kevin54 is offline   Reply With Quote
Old 03-14-2012, 05:53 PM   #10
Nowater
Senior Member
Stainless Steel tapcons are available. Drill the holes in the 2 x 4 oversize to allow for some expansion and contraction. Adhesive helps too. Red heads, expansion shields, lead anchors and those other methods are also good. The best method may be what you have on hand and feel comfortable with! Hope this helps.
Nowater is offline   Reply With Quote
Old 03-14-2012, 06:09 PM   #11
slob
Senior Member
slob's Avatar
Powder actuated fasteners. Just used a bunch to install 2x3's for shelving in a basement room.
slob is offline   Reply With Quote
Old 03-14-2012, 06:15 PM   #12
5lima30
Senior Member
5lima30's Avatar
+1 on Tapcons!
5lima30 is offline   Reply With Quote
Old 03-14-2012, 09:49 PM   #13
tyjoja
Senior Member
what's on the other side of the wall? Is it accessible? If so, rotohammer clear through and put a galvanized bolt top and bottom. Done
tyjoja is offline   Reply With Quote
Old 03-15-2012, 06:01 AM   #14
bw77
Senior Member
bw77's Avatar
Thanks for all the suggestions.
I am leaning towards a red head or a 2 piece lag screw type anchor.
To drill the hole, do I need a hammer drill, or can I use a corded 1/2" drill
with a carbide tipped masonry bit? I need to drill only 4 holes.
Old 03-15-2012, 06:47 AM   #15
cderalow
Senior Member
hammer drill definitely makes it go faster, but a good corded drill should be able to do it as well with the appropriate concrete bit.
masonry bits are not always strong enough for use on concrete, so confirm with the bit's mfg/packaging prior.
cderalow is offline   Reply With Quote
Old 03-15-2012, 07:53 AM   #16
Krokodil
Senior Member
Krokodil's Avatar
I prefer expanding anchors for anything into bricks/mansonry. I want to try the chemical anchors that I see in stores lately.
__________________
When I'm dead I hope my wife doesn't sell my tools for what I told her I paid for it.
Krokodil is offline   Reply With Quote
Old 03-15-2012, 08:16 AM   #17
Sureshot
Senior Member
Sureshot's Avatar
Try to get a hammerdrill. You will end up with a better hole. Ihave used both the tapcons and expanding anchors and in my experience the hammerdrill helps immensely and if the concrete is of poor quality neither will hold. A good hole round hole has been the key IMHO.
Sureshot is offline   Reply With Quote
Old 03-15-2012, 08:17 AM   #18
NUTTSGT
NUTTSGT's Avatar
I've had good luck with tapcons.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 03-15-2012, 08:27 AM   #19
38Chevy454
Senior Member
38Chevy454's Avatar
A hammerdrill will make the holes super easy. A regular drill can suffice, but will take a lot longer to drill the holes. I would go with expanding anchors and hot dip galvanized log screw fasteners myself.
__________________
If one has problems with their neighbors..........they did not buy enough land
My detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=66932
USA made high quality bear claw style latches - cheap:
http://www.hotrodlatches.com
38Chevy454 is offline   Reply With Quote
Old 03-15-2012, 10:24 AM   #20
DIYKiah
Senior Member
Tapcons screws are made for screwing into concrete and brick in a masonary situation and should do the trick!
__________________
~Kiah Duncan
Appalachian State Graduate -- 2008
--Head of Marketing and Advertising at http://DIYGarageShelf.com
"Affordable DIY garage storage shelving kits that are functional and simple to install"
DIYKiah is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
