Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-15-2012, 06:55 PM   #1
hockey88fan
Senior Member
hockey88fan's Avatar
Default Metal vs drywall ceiling in garage
It's time to do the ceiling my garage. I've been set on drywall but recently saw one finished with white metal, the kind used to side pole buildings. It looked really bright and I liked the fact that when screw it up it's basically done, no finishing or painting. I'd like to hear comments from guys who have both. Also, how would you insulate with the metal ceiling? Specifically, is a vapor barrier used when insulating? The upstairs won't be heated, the downstairs will have radiant in slab as soon as the funds allow. Thanks!
hockey88fan is offline   Reply With Quote
Old 03-15-2012, 07:07 PM   #2
Motofixxer
Senior Member
Motofixxer's Avatar
Default Re: Metal vs drywall ceiling in garage
Was it mine you saw???
I like the ease of putting the steel up. It looks nice, it's different. Everyone comments positively on it. Drywall would have been so much slower and more work and hassle on my cathedral ceiling. You have a lower easier ceiling so it wouldn't be so bad. It really works out to cost, amount of work, and preference.
__________________
This is my new shop With an Atlas OH-10X Extra Wide\Tall Lift & TCML Motorcycle Lift
Click Here for INFORMATIVE Legal Info and videos
Our INALIENABLE Right to Travel Defined Legal Style
Don't Talk to Cops (PLEASE WATCH, Important for any and all Law Enforcement Encounters)
Motofixxer is offline   Reply With Quote
Old 03-15-2012, 08:32 PM   #3
John in OH
Senior Member
John in OH's Avatar
I just recently installed a steel ceiling in my 34x54 shop. I considered drywall, but for many of the same reasons you mention ... quick, one-step & it's done, no sanding, no painting, ... no muss, no fuss.
It took 3 guys two days to install the 10'-6" long J-channels and the 44, 14' x 3' panels. They pre-drilled all the panels before lifting them up ... these panels are not light and are awkward to handle. They must be aligned much more carefully than installing drywall panels. I had the J-channel set out from the wall 1/2 in. to allow future drywall on the walls to slip up behind the vertical leg of the J-channel to ease future finishing of the top edge of the drywall.
Things for you or anyone to be aware of ... check with your local inspector before selecting steel vs. drywall for the ceiling. The steel has a Class A fire spread rating, BUT it does not have a fire retardant rating. There may be concerns if you want to finish a room on second floor of your garage for habitation. Also, the electrical work for all of the ceiling mounted fixtures is a little more difficult (you want to avoid the big ridges on the panels) and you have to be careful of the sharp metal edges cutting the wiring so cutting and trimming holes for boxes takes time.
I installed regular faced insulation in the ceiling as you can see in some of the photos. Don't know if the vapor barrier is required or not, but using the staple flanges on the insulation bats makes the installation easier.
So far, I'm very pleased with the steel ceiling, but its been up for only two weeks! Lights and ceiling fans are next.
IMG_7545 (Custom).jpg IMG_7546 (Custom).jpg IMG_7550 (Custom).jpg IMG_7551 (Custom).jpg IMG_7553 (Custom).jpg IMG_7554 (Custom).jpg IMG_7556 (Custom).jpg
John in OH is offline   Reply With Quote
Old 03-15-2012, 08:51 PM   #4
hockey88fan
Senior Member
Default
Attachment 174950 Attachment 174951 Attachment 174952 Attachment 174953 Attachment 174954 Attachment 174955 Attachment 174956
Great info, and looks awesome!! Thanks!
Old 03-15-2012, 08:53 PM   #5
Mike007
Senior Member
Mike007's Avatar
I went with steel for all the reasons mentioned. One other benefit, if I recall correctly the steel was about 1/2 the weight of 1/2" sheetrock.
Mike007 is offline   Reply With Quote
Old 03-15-2012, 09:15 PM   #6
OccupantRJ
Senior Member
OccupantRJ's Avatar
What material is the J channel, and where are you guys getting it?
__________________
RJ
It's always easier to find a reason NOT to do something.....
The sum of all your choices, good and bad, become your life.....
OccupantRJ is offline   Reply With Quote
Old 03-15-2012, 09:33 PM   #7
pinebarkauto
I used metal on my walls and ceiling in my shop. All electrical is surface mounted in conduit. My building is a pole barn and it was just easier. If it had been a stud wall construction, I would have still used metal on the ceiling but gone with a wood covering on the walls for ease of mounting cabinets and shelving. I got my metal and supplies from MetalBuildingSupplyCo.com in Piedmont, SC. 1-800-922-8039. Chip.
pinebarkauto is offline   Reply With Quote
Old 03-15-2012, 09:40 PM   #8
Jeff Ivers
Senior Member
I put in sheetrock when I built my shop 20 years ago. Last fall, I helped a friend put metal on the ceiling of his shop. We completed the job in 2 days for a 24x30 building. If I was doing my shop today, I would do metal. The only down side to the metal is it is a bit more difficult to locate/install outlets in.
Jeff Ivers is offline   Reply With Quote
Old 03-15-2012, 09:46 PM   #9
54stude
Keep posting pics guys! I am thinking about a metal ceiling in my shop this summer. Does anyone have pics of metal on a steep inside ceiling, like a 10/12 rafter garage for instance?
54stude is offline   Reply With Quote
Old 03-15-2012, 09:58 PM   #10
John in OH
Senior Member
John in OH's Avatar
Quote:
The J-channel is steel and is available from the steel panel manufacturer so wherever you buy the steel panels should be able to also provide the J-channel. Most of these panel manufactures seem to provide a fairly wide range of trim components to match the panels.
Dimensions are roughly 3" horizontal upper flange for attachment to joist (note the channel is attached to the joist, NOT to the wall), approximate 3/4" vertical leg and approximately 3/4" horizontal lower flange with folded lip. Sorry I don't have a photo or exact dimensions.
The channel is not supposed to provide any support for the panels, it's just a finish piece for the sidewalls.
Old 03-15-2012, 09:58 PM   #11
jlckmj
Senior Member
jlckmj's Avatar
My opinion? Metal for sure!
As far as insulation, I have blown some above the metal, and I have done the bats, like the picture above, both work.
Jim
jlckmj is offline   Reply With Quote
Old 03-15-2012, 11:43 PM   #12
PCO6
Senior Member
PCO6's Avatar
I used aluminum soffit - 16" W x 10' L panels. They are very light and were easy to install by myself. I used 6" insulation batts and a 6mm vapour barrier. To be honest, I didn't even consider drywall. Too much work!
__________________
PCO6 is offline   Reply With Quote
Old 03-16-2012, 12:05 AM   #13
pipsters
Senior Member
What is the price difference? Something about the metal ceilings just does not look right to me. Personally I wouldn't put them in my garage.
pipsters is offline   Reply With Quote
Old 03-16-2012, 12:15 AM   #14
gooned
Quote:
In a working shop I think it'd be great, may even do mine in tin.
In a "polish and store" garage definetly go drywall and paint.. my 0.02
gooned is offline   Reply With Quote
Old 03-16-2012, 03:00 AM   #15
Justanoldguy
Senior Member
Justanoldguy's Avatar
Good thread guys.
Love the finished look to steel.
More pics please and detail shots of j channel, fittings etc.
Justanoldguy is offline   Reply With Quote
Old 03-16-2012, 05:32 AM   #16
camarotoolman
The vinyl or aluminum soffit would be alot less work, much easier on your bod. I had drywall on my porch ceiling, had to paint it about every year to keep it looking nice. Covered it over with vinyl, just hose it down now.
camarotoolman is offline   Reply With Quote
Old 03-16-2012, 05:51 AM   #17
OccupantRJ
Senior Member
OccupantRJ's Avatar
The reason I asked, is because there may be people buying the metal sheets from a source that stocks the sheets, but not the trim. In that case, I would think that vinyl J channel could be used, or aluminum trim coil could be used to bend up some trim. In my case, there is a roll forming operation for the metal roofing just 2 miles from my house, but is wholesale only, distributed through a wholesaler next door to them, who also happens to own the place. I gotta see if I can get my friend the roofing contractor to hook me up for what I will need.
__________________
RJ
Old 03-16-2012, 06:10 AM   #18
hockey88fan
Senior Member
Default
Quote:
Looks great
Old 03-16-2012, 06:55 AM   #19
darkk
Senior Member
Wish I could have used metal. Code required 5/8" fire rated drywall.
darkk is offline   Reply With Quote
Old 03-16-2012, 08:18 AM   #20
sberry
sberry's Avatar
I like that soffit.
sberry is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
