Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 03-18-2012, 02:51 PM   #1
DrkMtnDew
Senior Member
DrkMtnDew's Avatar
Default Question for the Cummins Guys
My dad has a 1997 Dodge 12v. Complaint is the heater won't get hot. Thermostat changed. Twice. No Heat. Engine Temp gauge climbs up to 210* and thermostat opens immediatly cooling it off to 160*. The local mechanic told Dad to keep changing the thermostat until he found a good one.
Its in another state so I can't take a look at it.
Whats your thoughts?
__________________
Nobody got anywhere in the world by simply being content. Louis L'Amour
DrkMtnDew is offline   Reply With Quote
Old 03-18-2012, 03:19 PM   #2
chris142
Senior Member
Default Re: Question for the Cummins Guys
Both heater hoses hot? Broken blend door?
chris142 is offline   Reply With Quote
Old 03-18-2012, 03:22 PM   #3
waterboy12
Senior Member
waterboy12's Avatar
what brand thermostat are you using?
waterboy12 is offline   Reply With Quote
Old 03-18-2012, 03:29 PM   #4
DrkMtnDew
Senior Member
DrkMtnDew's Avatar
Quote:
From what he's telling me the heater core was replace before he bought it (2 years) and the blend doors seem to be switching. But I will have him double check the heater hoses.
__________________
Old 03-18-2012, 03:29 PM   #5
DrkMtnDew
Senior Member
DrkMtnDew's Avatar
Quote:
Picked it up a CarQuest. not sure who actuallly makes it.
__________________
Old 03-18-2012, 03:33 PM   #6
Moose-LandTran
Senior Member
Moose-LandTran's Avatar
Send a message via AIM to Moose-LandTran Send a message via MSN to Moose-LandTran
Quote:
That sounds like an airlock, temp should reach thermostat opening point, open the stat and it should then remain level at the thermostat opening temp. It shouldn't climb higher, open the stat and then drop and stay level.
__________________
Quote:
Originally Posted by cosmik binturong
I lived in a forest, I could always go punch a Moose or something.
Moose-LandTran is offline   Reply With Quote
Old 03-18-2012, 03:42 PM   #7
Wackerjr
Senior Member
Keep swapping tstats.... thats funny... Find a better mechanic for one....
Start with the easy stuff, disconnect the heater hoses and back flush the core first.
Then top off everything and take it for a drive.... make sure it isn't air locked as stated earlier.....
Wackerjr is offline   Reply With Quote
Old 03-18-2012, 04:05 PM   #8
geologist
Senior Member
geologist's Avatar
Quote:
I agree. I had this problem as well. On a side note, I had to replace the head gasket on my car. I wasn't finding any coolant in my oil or any oil in my coolant, but I started noticing an oil leak. I tracked it down to the valve cover gasket, replaced it, still had a problem. Checked around the block for leaks, no dice. Pulled the head off and the gasket was destroyed. Did it cause the other problems? Who knows, but once I purged the cooling system and flushed it (after replacing the gasket) I had no problems whatsoever.
__________________
Quote:
Originally Posted by JimVonBaden View Post
Excellent example of Darwinism in action!
Quote:
Originally Posted by darwyn View Post
Just to be clear, I didn't do it!
Speak the truth, even if your voice shakes.
geologist is offline   Reply With Quote
Old 03-18-2012, 04:12 PM   #9
dlenkewich
Senior Member
I believe water pumps are common issues on 2nd and 3rd gen trucks not producing enough cabin heat.
Also diesels don't produce as much heat as a gasser, almost nil if they are idling.
__________________
Making a 'house' our "Home"
dlenkewich is offline   Reply With Quote
Old 03-18-2012, 04:36 PM   #10
Original Man
Senior Member
Quote:
Really?
__________________
Lamborghini dreams, Nissan nightmares.
Original Man is offline   Reply With Quote
Old 03-18-2012, 04:37 PM   #11
Moose-LandTran
Senior Member
Quote:
Originally Posted by Original Man View Post
Really?
Yep. They produce very little heat and it takes a long time for them to warm up.
__________________
Old 03-18-2012, 04:39 PM   #12
ratdoggy
Senior Member
ratdoggy's Avatar
That's why they use winterfronts in cold weather.
__________________
We aren't rich...But we do poor better than most!
ratdoggy is online now   Reply With Quote
Old 03-18-2012, 04:48 PM   #13
DrkMtnDew
Senior Member
DrkMtnDew's Avatar
This truck even August will not stay at normal temp. Even when Dad has got the horse/house/flatbed trailer on the back. talked to the original owner and he said that truck hasn't had heat or reached operating temp since it was new.
__________________
Old 03-18-2012, 10:19 PM   #14
tonycastec
Senior Member
Somebody removed the thermostat? T'stat defective and is always open ? Use a cheap I.R. gun and follow the heat along the hoses?
tonycastec is offline   Reply With Quote
Old 03-19-2012, 02:31 PM   #15
38Chevy454
Senior Member
38Chevy454's Avatar
No idea if the Dodge has one, but is there a heater valve that may be not opening fully or plugged up? I would do as some others suggested, use a IR gun and follow the hoses to see what is going on.
__________________
I used to have a handle on life........but it broke
My detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=66932
USA made high quality large bear claw latches - cheap:
http://www.jalopyjournal.com/forum/s...d.php?t=620485
38Chevy454 is online now   Reply With Quote
Old 03-19-2012, 02:58 PM   #16
theo2
Senior Member
theo2's Avatar
Test the T-stat in a pan of hot water on the stove just to see if it opens, try all the simple things first.If you have a thermometer to stick in the pan to check temp. of water when and if the T-stat opens.
theo2 is offline   Reply With Quote
Old 03-19-2012, 03:09 PM   #17
theo2
Senior Member
theo2's Avatar
I know i've tried autozone t-stat in my diesel, no luck. Went to IH and bought t-stat,,,roast you out!
Old 03-19-2012, 03:13 PM   #18
purplezr2
Senior Member
purplezr2's Avatar
Try pack flushing the heater core.
Are you getting good air flow out of the vents. I know after a bit of time, my air flow stops out of the vent creating a low heat condition.
purplezr2 is online now   Reply With Quote
Old 03-19-2012, 06:04 PM   #19
HOTFR8
Senior Member
HOTFR8's Avatar
Location: Castlemaine, Victoria. The Hot Rod Centre of Australia.
I would try a winterfront but then by what you have added it sounds like a problem the original owner should have had investigated under warranty.
__________________
1966 (Aussie) XP Falcon Sedan, 1923 T Roadster, 1948 F4 Truck, Home Built Teardrop Camper, 1969 International 4 X 4 truck (Classic),
84 x 30 Colorbond Shed with Workshop, Car storage and Office.
www.streetrod.com.au
The Beast Runs>http://www.garagejournal.com/forum/s...0871&showall=1
Sheddwellers>http://www.garagejournal.com/forum/s...0063&showall=1
"V8's are Great, But Six inlines Just Fine" - CUMMINS Advertising.
HOTFR8 is offline   Reply With Quote
Old 03-19-2012, 06:29 PM   #20
fury9
Senior Member
there MIGHT be a vacuum issue,as for the temps going UP and down all the time,perfectly normal. I had a 97 cclb 12v 4x4 for the longest. Heater always worked. Tell him to tab the Killer Dowel Pin with a fender washer (plenty of write ups on dodge diesel cummins forum) That should be his first task. If that pin falls out it could very well possibly KILL the motor
fury9 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
