Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 03-29-2012, 12:17 PM   #1
JWithers2005
Junior Member
Default What size wire needed to feed 100amp sub-panel
Im having the power company upgrade my service to a 320amp main panel so I will be able to pull 100amps from it to power all the goodies in my new garage. My question is, What size wire will be required to handle the 100amp feed to the garage sub-panel? Copper or aluminum? Im just trying to get an idea what it will cost to run the 75' or so of wire to power the new garage. Hopefully I will be able to use aluminum from the main panel to the sub. I know it's going to be costly if it requires a copper wire so hopefully aluminum is an option..Thanks for any help..
-Joey
JWithers2005 is offline   Reply With Quote
Old 03-29-2012, 12:29 PM   #2
cj7365
Senior Member
cj7365's Avatar
Default Re: What size wire needed to feed 100amp sub-panel
Not sure of the wire size, but my electric guy ran aluminum for my 100 amp panel that was about 125ft away
__________________
www.olskool4x4.com
This country, with its institutions, belongs to the people who inhabit it. Whenever they shall grow weary of the existing government, they can exercise their constitutional right of amending it or their revolutionary right to dismember it or overthrow it." -- Abraham Lincoln, 4 April 1861
cj7365 is offline   Reply With Quote
Old 03-29-2012, 12:45 PM   #3
JWithers2005
Junior Member
Quote:
That's good to know. I can only imagine what it would cost in copper. Do you remember what it cost you for the wire?
Old 03-29-2012, 01:24 PM   #4
pattenp
Senior Member
pattenp's Avatar
For 100A you need at a minimum #1 AL or #3 CU. Aluminum is a third or less than the cost of copper. Go with AL. Note: This is based on 75C temp rating, if 60C is used then the next size larger wire is needed.
pattenp is offline   Reply With Quote
Old 03-29-2012, 02:55 PM   #5
JWithers2005
Junior Member
Quote:
Ok thanks for ur reply..do u know of a website that has what you are talking about? so I can check pricing? a link would be great if it isn't too much trouble. thanks again
Old 03-29-2012, 03:21 PM   #6
Falcon67
Senior Member
Falcon67's Avatar
For those sizes, you'll probably want to call a local electrical supply. You don't usually or always find those in home stores. Especially #3 CU. Now if you scale back to 75A or 90A (ask your local inspector what's allowed), you could use 2-2-2-4 aluminum mobile home feeder, which runs about $1.6x a foot more or less.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 03-29-2012, 03:38 PM   #7
pattenp
Senior Member
pattenp's Avatar
I never have found trying to price wire on the web a worth while effort. I just go to my local Lowes or Home Depot. For the larger wire such as the mobile home feeder I go to my local electrical supply. The last 2-2-2-4 AL MHF I purchased was around $1.20US per foot.
Old 03-29-2012, 09:06 PM   #8
Aceman
Senior Member
Is this a meter base or panel or a combo of both. That'll dictate how many wires to run to the garage....
A "320" is slang for a 400 amp meterbase is why I ask.
Aceman is offline   Reply With Quote
Old 03-29-2012, 10:16 PM   #9
JWithers2005
Junior Member
just a meter socket and a service panel from what i understand..im green when it comes to electrical so I can't exactly talk intelligently about the subject..i spoke with the electrician today and he suggests a 200amp panel and a 70 or 90amp breaker to power the panel in the garage. he wants a thousands bucks just to upgrade the panel on the house!! I was blown away by that price but maybe that is the going rate??
Old 03-30-2012, 10:37 AM   #10
pattenp
Senior Member
pattenp's Avatar
$1000 sounds good to me. Parts aren't the expense, it's the labor/time.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
