Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-19-2008, 11:38 AM   #1
bigblk66_coronet
Junior Member
Angry Garage door will not open when cold?
Hey guys i have a problem. When it gets around say 10 degrees or colder my electric garage door opener will not work right. And since today its -20 with the windchill its really acting up. When i hit the button the door will go up about 8 inches and then go back down.I have to sit there and hit the button 15+ times before it will open. It only does this when its really cold.I dont get it. Has anyone run into this before and have any ideas what the problem is?...........Thanks guys...Joe
bigblk66_coronet is offline   Reply With Quote
Old 01-19-2008, 12:11 PM   #2
rsanter
Senior Member
rsanter's Avatar
Default Re: Garage door will not open when cold?
is there ice on the door that is causing additional weight that is tripping a safety feature of the opener
what about the lube in the door and opener getting stiff and causting resistance and tripping a safety feature of the opener.
your house knows how cold it is outside and is trying to protect you from the weather
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 01-19-2008, 12:26 PM   #3
Stuart in MN
Senior Member
Stuart in MN's Avatar
Quote:
I think this is your problem. You may be able to adjust the trip level on the opener. Otherwise, use some lighter lubricant on the door tracks, and/or get out of the car and help the door go up with your hands.
Stuart in MN is offline   Reply With Quote
Old 01-19-2008, 12:34 PM   #4
Mr. Welsh
Senior Member
Sounds like it's a safety switch, as mentioned. Might also be something out of alignment due to the cold weather/frozen ground.
Mr. Welsh is offline   Reply With Quote
Old 01-20-2008, 08:22 AM   #5
72VETTE454
WingNut
Coronet,
I have had the exact same problem at each house that I've owned. There is an adjustment on the opener for the amount of force that the opener applies. There is an adjustment for open and for close. Simply rotate the adjustment knob to increase the open force. Mine are located behind the panel for the opener light bulb.
PS - I tried to attach a picture of the adjustment knobs, but the file size was too large. I've never done this before, any help available? Thanks
72VETTE454 is offline   Reply With Quote
Old 01-20-2008, 08:44 AM   #6
72VETTE454
WingNut
OK, went to Photobucket. Here goes.
Old 01-20-2008, 09:09 AM   #7
stangkid14
Senior Member
used to happen to our old door. only it would go all the way donw then bounce right back up. very frustrating!
stangkid14 is offline   Reply With Quote
Old 01-20-2008, 11:30 AM   #8
rsanter
Senior Member
rsanter's Avatar
Quote:
your problem is the travel limit switch. your opener thinks its hitting something before it reaches its stop point and its reversing for safety
bob
__________________
Old 01-20-2008, 11:55 AM   #9
Steve in Mi
Senior Member
Steve in Mi's Avatar
I think it is called a SMART door. It's in the single digits here.
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 01-20-2008, 12:01 PM   #10
Vernmotor
Senior Member
Vernmotor's Avatar
Well I sure hope you get your door fixed.. I would like to see some pics of you 66 BB coronet ! being I own one...
__________________
I have been doing so much with so little for so long I can do almost anything with nothing.
Vernmotor is offline   Reply With Quote
Old 01-20-2008, 12:47 PM   #11
Junkman
Senior Member
Junkman's Avatar
Quote:
Looking at your picture, I am wondering why you don't have the bare twisted wires taped or wire nutted?
__________________
Philosopher Emeritus Of Garage Journal
Men wake up as good-looking as they went to bed.
Women somehow deteriorate during the night.
Never argue with an idiot. He'll drag you down to his level, then beat you with experience.
Junkman is offline   Reply With Quote
Old 01-20-2008, 03:50 PM   #12
bigblk66_coronet
Junior Member
Hey guys thanks for the help. I did try to push it up as it was going up and it did work doing that. Ill have to get up there and adjust the force. And if i can find a pic of my coronet on this puter ill gladly post it! Ill go look!.Thanks.joe!
Old 01-20-2008, 04:00 PM   #13
bigblk66_coronet
Junior Member
Well hopefully this works. Heres the only pic i can find of my Coronet. this was at one of our big Mopar shows in our area
Old 01-20-2008, 09:34 PM   #14
72VETTE454
WingNut
Good point Junkman. My only defense is that I didn't install it, pretty weak, I know. The wires are behind the light bulb cover and I never see them, except to take a picture and put on the WWW for the entire world to see.
Old 01-21-2008, 10:50 PM   #15
ovilla
Senior Member
ovilla's Avatar
Adjust the force for both the up and down motion. Also, grease all door hinges, the trolley and rails and make sure that the torsion springs are in good operating condition. The door should open and close very smoothly with the use of one hand, with little effort.
ovilla is offline   Reply With Quote
Old 01-21-2008, 11:10 PM   #16
nissan_crawler
Senior Member
nissan_crawler's Avatar
when the door closes, a 2x4 under the door should make it go back up.
when it opens, pulling on it half decently should make it stop.
Before you mess with that, your springs should be set for a relatively neutral door. I like mine a little heavy, so it still seals well on the bottom if the opener is disconnected.
nissan_crawler is offline   Reply With Quote
Old 01-22-2008, 11:45 AM   #17
Vernmotor
Senior Member
Vernmotor's Avatar
Nice car..I am from ohio could I have seen that car before..I know I have seen 1-2 around that color ?here a link to some pics of mine.
http://s241.photobucket.com/albums/f...motor/coronet/
__________________
Old 01-22-2008, 12:20 PM   #18
Franz©
Absolutely amazing nobody yet has suggested pulling the release to determine if it's a door problem or an operator problem.
Hell till that is determined you might as well beat on the car roof with a broomstick and see if that makes the OH door work better.
Oh, please post the name of the installer, I'm sure he'd want the publicity for that wonderful wiring he did.
Franz© is offline   Reply With Quote
Old 01-22-2008, 01:52 PM   #19
Jey
Senior Member
Jey's Avatar
I am having a similar problem with my door. the first problem was it wouldn't open at all. I detached it, and tried to lift it.. finally it lifted. The Rubber was frozen to the concrete.
Secondly, it closes about 2/3 of the way and bounces back in this cold weather.
Some douche bag that owned the house before me, apparently hit the track on the one side.
I have yet to track down a replacement out of shear laziness. but i did rebend it a little with my pry-bar .
I did notice, that the bent track has a lot more effect on the door bind in the cold months. In summer it works perfectly. This winter, it's been pretty sticky.
Unless the wife hit it and forgot to mention it? huh...
Jey is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
