Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-21-2005, 09:58 PM   #1
plepper
Certified Garage Junkie
Default Wiring for detached shop
I'm finishing up my shop and need to wire from my house to the shop I got two ways to go
1. House has 2 200 amp panels with a 2'' pvc duct to the shop (200' run).
2. install a new meter base and run power from that.
If I run from the house panels to a sub panel (100 amp) in the shop what size wire should I use ( only 1 240 outlet for welder 50 amp) I was thinking #1 awg with #6 ground.Cost for the wire will be about $400.00 from HD any ideas to get a better deal? Inital savings with a new service could be a lot less but the monthly rate could offset after a period of time, so how about some opions?
plepper is offline   Reply With Quote
Old 09-22-2005, 02:12 AM   #2
TOMWELDS
Garageaholic
Default
Since you already have a 200amp meter and 2" pipe, why dont you go with a 200amp service? Granted, it is more money for the wire (i'd suggest 3/0 CU) and more work pulling. If you go with 100amp, I would use 1/0 on the 2 hot legs, #4 on the neutral and #6 ground.
__________________
LICENSED ELECTRICIAN
BAKERY MECHANIC
TOMWELDS is offline   Reply With Quote
Old 09-22-2005, 04:59 PM   #3
byrdman
Senior Member
byrdman's Avatar
Default
cost-analyze it. If the separate meter will cost you say 20% more per KWH every month(plus a meter fee?), how long would it take to exceed the additional cost of running power from the house? Do you plan on using your shop that long?
I had the same basic decision to make. It will take me another 5-6 years before the higher installation cost pays for itself in KWH savings, faster if I start using more juice. I ran power from the house.
__________________
-"byrdman"
byrdman is offline   Reply With Quote
Old 09-23-2005, 06:00 AM   #4
muddy
Senior Member
Default not hijacking..........
Not hijacking thread, just adding to it.............
I'm going to be doing the same real soon........for those of you that are up on electrical..........what are the good choices on running electric cable from house to a 100 amp in shop? I'm asking about cable sizes/brand/etc.
Also for cable t.v., phone line,etc........anything new out there that should be mentioned?
What about cable size from the service panel in shop to a welder and to an air compressor? It's been awhile for me so thought the pointers would be helpful.
Thanks in advance........ Keith
muddy is offline   Reply With Quote
Old 09-23-2005, 02:37 PM   #5
Ken Greene
Default
cable TV and phone. I use only RG6 quad sheilded for cable runs in todays world of HD and Digital cable its really a must. phone i use cat5e for this it provides the ability of up to 4 lines to where ever your going with it.
i would sugest 2 runs of rg6 and three for cat5 that will give you a spare incase you want survalence cameras on the coax and on the cat5 you get one for phone/intercom one for network (think highspeed internet access) and a spare for whatever.
also when running these lines keep them at least 12" away from and power feeds and if you must cross a power line to it at 90 degrees.
I think that basiclly covers it
Ken Greene is offline   Reply With Quote
Old 09-24-2005, 08:51 AM   #6
byrdman
Senior Member
byrdman's Avatar
Default
I had a ~125 ft run from my house to the shop. I separated all my low voltage stuff from power by 2-3 feet(two trenches), and ran it through black plastic water pipe as a conduit. When I pulled my RG6, cat5e, and telephone through the water pipe, I also pulled through a pull cord in case I ever want to run another line of some sort through there.
Here's the view at the house before I pulled the cables:
__________________
-"byrdman"
Old 09-24-2005, 09:51 AM   #7
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Default
That dirt looks like cocoa powder.
bmwpower is offline   Reply With Quote
Old 09-24-2005, 11:31 PM   #8
TOMWELDS
Garageaholic
Default
Will the electric be in gray electrical PVC?
__________________
BAKERY MECHANIC
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help wiring a shop light to a plug... Luckydevil General Garage Discussion 19 05-07-2009 11:15 PM
Fab shop or Garage ? AprilzWarrior Garage Gallery 23 12-20-2007 11:33 AM
Shop addition astroracer Garage Gallery 44 05-01-2006 06:55 AM
Newbie, with a new shop BOSS351C General Garage Discussion 12 07-29-2005 08:40 AM
just throwing out ideas for future shop.....opinions please sg69 General Garage Discussion 3 07-19-2005 07:23 PM
