Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-13-2012, 10:20 PM   #1
hevnbnd
Senior Member
Default How to stop cabinet door from opening too wide?
Not sure what to search for. I have a wood framed cabinet door that needs to only open like 70 degrees. If it opens more it hits on a light fixture. I called rockler and they had no idea.. I could use a chain but it looks trashy. Anyone got any ideas? Thanks
hevnbnd is offline   Reply With Quote
Old 04-13-2012, 10:27 PM   #2
sjsfire
Senior Member
sjsfire's Avatar
Default Re: How to stop cabinet door from opening to wide?
Really shouldn't matter about how it looks with the chain. Your only gonna see it when you open the door.......right?
sjsfire is offline   Reply With Quote
Old 04-13-2012, 10:33 PM   #3
hevnbnd
Senior Member
well it does to my wife. So that is not a solution.
Old 04-13-2012, 10:33 PM   #4
NUTTSGT
NUTTSGT's Avatar
How it looks, smack the light fixture one too many times and you won't even see the chain.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 04-13-2012, 10:38 PM   #5
hevnbnd
Senior Member
really how about a solution to the question...
Old 04-13-2012, 10:40 PM   #6
Rusty Musket
Senior Member
Rusty Musket's Avatar
you should be able to adapt a "Lid Stay" . Google that as an image or see if this link works. Most are designed for vertical applications like box lids but many will work for a side hinged door as well. If your door has european hinges on it, you can replace them with ones that have a limited swing.
http://www.google.com/search?q=cabin...w=1310&bih=993
Rusty Musket is offline   Reply With Quote
Old 04-13-2012, 10:41 PM   #7
hevnbnd
Senior Member
thank you rusty. That should point me in the right direction.
Old 04-13-2012, 10:44 PM   #8
NUTTSGT
NUTTSGT's Avatar
Quote:
A chain is a real solution and a simple one at that. It won't be seen unless the cabinet door is open. You can put the chain on temp until you find something else you prefer.
One of these times, you'll grab that door open it up agressively and forget about the light, then you'll wish you had the chain on the door.
__________________
ERIC
Old 04-13-2012, 10:45 PM   #9
hevnbnd
Senior Member
I have chains on the door and want something else. Therefore the reason for the post.
Old 04-13-2012, 11:11 PM   #10
RVDan
Senior Member
Cable looks nice
RVDan is offline   Reply With Quote
Old 04-13-2012, 11:22 PM   #11
larry_g
Senior Member
Grandma had some of these on her old cabinets. They looked something like the hydraulic spring on your screen door but were simply a small rod mounted on a pivot on the door and an L bracket in the cabinet with a hole the rod passed through. The rod had a ball end on it that prevented it from passing through the L bracket and providing a stop. Really simple and elegant.
functioned like the item linked below
http://www.closet-masters.net/images...tpicture_1.jpg
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 04-13-2012, 11:25 PM   #12
cnc-me
Senior Member
cnc-me's Avatar
Measure with a protractor or sliding T bevel, then take two pieces of
steel and weld at the same angle, screw or bolt it to the side of
your cabinet.
The rubber block is what is used on a Solem drum sander bed.
You could use just about any type of rubber though.
This one keeps the door from hitting the grinder.
The stopper on the other side of the cabinet keeps the door from hitting
a milling machine. Should give you some ideas.....
__________________
"It's not whatcha got, it's what ya do with it"
-E. J. Potter 1941-2012
cnc-me is offline   Reply With Quote
Old 04-13-2012, 11:32 PM   #13
WQ59B
Senior Member
I was thinking of what larry g posted, but not sure those are readily available anymore.
This should work at less than 90-degrees.
http://www.jrprvinc.com/products/71025.jpg
WQ59B is offline   Reply With Quote
Old 04-13-2012, 11:44 PM   #14
HubbaBubba
Senior Member
HubbaBubba's Avatar
Default Re: How to stop cabinet door from opening too wide?
Move the light fixture?
__________________
"My old man is a television repairman, he's got this ultimate set of tools. I can fix it" Jeff Spicoli
HubbaBubba is offline   Reply With Quote
Old 04-14-2012, 04:29 PM   #15
toolmiser
Senior Member
What kind of hinges do you have? I have "European" style, and I did get a "stop" from rockler that keeps mind from opening past about 85 degrees. I know it isn't what you asked for. The cable idea isnt too bad, or how about a wire tie between two eye screws?
toolmiser is offline   Reply With Quote
Old 04-14-2012, 04:50 PM   #16
Alchymist
Senior Member
Alchymist's Avatar
https://www.google.com/search?q=scre...w=1280&bih=655
Alchymist is offline   Reply With Quote
Old 04-14-2012, 05:06 PM   #17
BD1
Senior Member
BD1's Avatar
Can you change the door swing to the opposite side ????
BD1 is offline   Reply With Quote
Old 04-14-2012, 05:34 PM   #18
dadsEH
Senior Member
dadsEH's Avatar
Location: Tangambalanga in the Kiewa valley of North Vic.AU
Obviously , reducing the door swing arc is not addressing the root cause.... you f@#ked up, plain and simple. Either the door or the light fixture have to go.
Cut 4 inches off the top of the door and attach the offending part to the cabinet, or move the light. Either way you will have fixed the interferance and allowed the door to open completely.
__________________
" send Lawyers,guns,and money......
The shit has hit the fan."
dadsEH is offline   Reply With Quote
Old 04-14-2012, 06:13 PM   #19
Kny21
Staple a strap inside close to the hinge on both the door and cabinet. Staple points and strap length will determine door travel. Do top and bottom if needed for strength.
Done right it'll be low profile and not be unsightly like the other methods suggested.
Kny21 is offline   Reply With Quote
Old 04-14-2012, 07:08 PM   #20
Duker
Senior Member
Duker's Avatar
Most of the better ideas already listed but here are a couple of other items....
You didn't mention if these were metal doors but you could tack on a couple of gate limiters.
Or the old stand buy, swing limiters that are used if the door has a pin.
__________________
'Left over parts are just proof I made it better!"
My Welding Table Build --- Youtube Video of Welding Table
My Various Garage Projects --- My Work Bench Build
Youtube Video Channel
Duker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
