Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-29-2012, 03:35 PM   #1
rickcact
Senior Member
Default Snap ring removal difficulty-HELP!!!
A coworker gave me this hydraulic cylinder and was going to repack it.
I cannot get the snap ring out of the slot. I tried many many time with my snap ring pliers but every time I think I got it, the pliers slip off. Maybe I need heavier duty pliers, but was trying to get away from having to buy something I will only use once. An ideas? The slot is about 3/8 inch deep to where the snap ring is.
rickcact is offline   Reply With Quote
Old 04-29-2012, 03:47 PM   #2
Sparkfarmer
Senior Member
Sparkfarmer's Avatar
Default Re: Snap ring removal difficulty-HELP!!!
http://www.wihatools.com/300seri/346serie.htm
Sparkfarmer is offline   Reply With Quote
Old 04-29-2012, 03:59 PM   #3
metaleltr
Senior Member
Try grinding a cheap pair of needle nose to fit.
metaleltr is offline   Reply With Quote
Old 04-29-2012, 06:05 PM   #4
Steevo
Senior Member
Steevo's Avatar
The harder part is pulling on the ram while holding that snap-ring compressed.
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is offline   Reply With Quote
Old 04-29-2012, 06:18 PM   #5
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
You might be using the wrong tool . For that the prongs should be slanted towards the center so as to not slip off, Or the prongs are too small in dia.
Zeke is offline   Reply With Quote
Old 04-29-2012, 06:38 PM   #6
larry_g
Senior Member
Are you squeezing the ring into the end cap and then trying to pull ram and end cap all together? That is how I think it should come apart. Some times a three handed job. You may have to grind a bit of a notch in your tips as shown on the Whia link. If you do not have ratcheting pliers you may want to hold them closed with some visegrips.
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 04-29-2012, 07:13 PM   #7
mtnkrake
Senior Member
I did the grind the needle nose trick and that worked perfect for me.
mtnkrake is offline   Reply With Quote
Old 04-29-2012, 07:37 PM   #8
rickcact
Senior Member
I'm going to try grinding a set of needle nose pliers down to size tomorrow. Ill let you know how it goes.
Thanks,
Rick
Old 04-29-2012, 07:54 PM   #9
FriendOfYours
Senior Member
Tap on the points lightly with a hammer until the ends mushroom. This gives them a ridge that will bite into the snap ring
FriendOfYours is offline   Reply With Quote
Old 04-29-2012, 08:30 PM   #10
pstnbly
Senior Member
You may have to apply inward pressure to the cylinder end cap to free up the snap ring
pstnbly is online now   Reply With Quote
Old 04-29-2012, 09:04 PM   #11
zeebad1
Senior Member
zeebad1's Avatar
I just dismantled a cylinder like this a month ago. They are not fun!!
Make sure that you flush the groove out with brake-clean & compressed air so the snap-ring has plenty of room to collapse.
I have a pair of Hi-Tech brand locking pliers. They are the best option that I have found, if working by yourself.
I usually pull the shaft all the way out, so the piston is against the end cap, place a long pin through the clevis on the end of the shaft, and hammer on the pin while holding the pliers tightly. If the snap ring is collapsed, the end cap will pull out.
The last one was a real bear, and took another hand to get the job done.
zeebad1 is offline   Reply With Quote
Old 04-29-2012, 09:10 PM   #12
bgott
Senior Member
Sometimes you need to take an awl or a pin punch and a hammer and pop the holes the direction you want them to go. Loosen stuff up, that ring has taken a set.
bgott is offline   Reply With Quote
Old 04-29-2012, 09:15 PM   #13
Sureshot
Senior Member
Sureshot's Avatar
File the inside of the pliers a little so it stops slipping off.
Sureshot is offline   Reply With Quote
Old 05-02-2012, 07:45 PM   #14
rickcact
Senior Member
*UPDATE*
Ok I got the snap ring out. I borrowed a larger set of pliers from a friend.
I did something very very bad to get the cap to move though. I used compressed air to unseat it. I also had to tap the outside of the case to get it moving. Once it moved, the ram part flew, I mean LAUNCHED out of the case, straight into a 12 pack of Sam Adams in which about 4 of them took one for the team and saved the other 8. I was not hurt.
DO NOT EVER USE COMPRESSED AIR TO DISASSEMBLE A HYDRAULIC CYLINDER!!!!!
I was lucky the case and ram had a place to go when they separated.
Rick
Old 05-02-2012, 07:48 PM   #15
larry_g
Senior Member
Quote:
Originally Posted by rickcact View Post
*UPDATE*
Rick
Makes quite a noise doesn't it?
lg
no neat sig line
__________________
Old 05-02-2012, 07:53 PM   #16
purplezr2
Senior Member
purplezr2's Avatar
*UPDATE*
Rick
Use a non compressible fluid next time, hence the reason places do hydro testing, instead of compressed air testing.
purplezr2 is offline   Reply With Quote
Old 05-02-2012, 09:13 PM   #17
Steevo
Senior Member
Steevo's Avatar
I'm glad nobody got hurt, because you could seriously mess someone up by blowing the end off a cylinder with air pressure.
The safer option would have been a come-along pulling on the rod with the base chained to a fixed object. A lot less stored energy that way.
__________________
Old 05-02-2012, 10:14 PM   #18
jimp
Senior Member
*UPDATE*
Rick
I aways put rod end back on the machine and use cyclinder like a slide hammer. Comes off easy most times. Glad you had no major damage.
jimp is offline   Reply With Quote
Old 05-02-2012, 10:51 PM   #19
Erampu
Senior Member
Erampu's Avatar
Dammit, man! Four innocent beers paid the ultimate price for your folly. How can you live with yourself????
Erampu is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
