Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-30-2008, 08:50 AM   #1
Rickstir
Senior Member
Rickstir's Avatar
Location: Close by the Elk Fork of the Salt River, in MO
Default Air Compressor takes a long time to fill
When I turn on my 5 gal Sears compressor, it takes about 5 minuetes for the unit to shut off. Any body know what I can check for? Its about six years old and see infrequent use.
Rickstir is offline   Reply With Quote
Old 01-30-2008, 09:16 AM   #2
SteveU
Senior Member
SteveU's Avatar
Default Re: Air Compressor takes a long time to fill
Is that while filling just the compressor or filling your airlines too? How long did it used to take? Is this an oiless or oil type compressor? Is it direct drive or does it have belts? Does it seem to hold pressure once it finally does fill up? Probably first thing I'd do is make up some soapy water in a spray bottle & spray around all fittings & connections to check for leaks. If there isn't any it is a problem with the pump or maybe a belt slipping.
SteveU is offline   Reply With Quote
Old 01-30-2008, 08:12 PM   #3
6768rogues
Senior Member
If you use it a lot, it is probably getting worn out. If you cannot find a leak or something obvious, the pump might have a lot of blow by or bad valves.
__________________
Why a cool garage? Chicks dig 'em. Alcohol may intensify the effect. As John Belushi said in Animal House, "I suggest you drink and drink heavily."
6768rogues is offline   Reply With Quote
Old 01-31-2008, 06:40 AM   #4
CraigFL
Senior Member
When I notice mine taking longer than usual I replace the valve plate and the piston ring-- both available from Sears.com for reasonably cheap. Most often the valve plate has a broken reed/flap valve when this happens.
CraigFL is offline   Reply With Quote
Old 01-31-2008, 06:43 AM   #5
mike944
Senior Member
Rickstir - is this a new problem, or has this compressor always been slow?
Piston or diaphragm compressor? (oil-lubed or oil-less)
__________________
Mike
'92 Porsche 968
'01 VW Jetta TDi
mike944 is offline   Reply With Quote
Old 01-31-2008, 07:17 AM   #6
Rickstir
Senior Member
Rickstir's Avatar
Thnaks for the great responses.
I will try to find a leak this week-end.
It has been slow about 6 -8 months now
I will try to get a diagram onilne so I can find the valve plate.
This is an oil-less compressor.
Old 02-02-2008, 11:50 AM   #7
DynoDave
Senior Member
DynoDave's Avatar
Rickstir, the oil-less compressors get away with being oil-less by using a plastic piston. The do wear out. A friend of mine had this exact same problem wit his Sears. He bought a "rebuild" kit for about $30. A very simple job, and it now builds the correct pressure, and charges the tank much more quickly.
__________________
DynoDave
WPC #12304
POCI #72200
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
1988 Pontiac Firebird TransAm
DynoDave is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
