Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 05-06-2012, 05:33 PM   #1
Strouty
Senior Member
Strouty's Avatar
Default Building a hot water pressure washer, how would you do it?
I was looking at some of the prices for hot water pressure washers, ouch they are expensive. I thought about taking a small cold water unit and using a propane or electric on demand tankless water heater. If you get a pressure washer that has 3GPM flow and a tankless heater with the same, wouldn't that cover you? I did research used units, but they all seem like a problem waiting to happen.
__________________
Can't afford a signature
Strouty is offline   Reply With Quote
Old 05-06-2012, 05:50 PM   #2
chadster1
Senior Member
chadster1's Avatar
Default Re: Building a hot water pressure washer, how would you do it?
I have a tankless water heater in my house. When I had the house built, I had a hot water spigot installed on the side of the house near the driveway. I use my gas powered pressure washer hooked up to the hot water spigot all the time.
chadster1 is offline   Reply With Quote
Old 05-06-2012, 05:53 PM   #3
CoSnipe
If your using a pressure washer at your house just run it off your hot water heater. Works for me washing my dirt bikes afterv a weekend of riding.just don't get the water too hot it'll toast the seals in a pressure calving not designed for hot water. My .02
CoSnipe is offline   Reply With Quote
Old 05-06-2012, 05:56 PM   #4
Strouty
Senior Member
Strouty's Avatar
And it was not an issue? It makes sense that it would work, I guess my concern would be destruction of the cold water pressure washer. Would it hurt the seals or overheat it or something? I saw northern tools sold an add on heat unit for the larger pressure washers. I figure the cost of a cheap unit and a tankless water heater would be easier to swallow. If I set it up your way, it would also heat the water for my shop. I am only planning on washing engine bays and trucks, nothing like a full time use.
__________________
Old 05-06-2012, 05:59 PM   #5
lilredex
Senior Member
The washer I have will handle 180* water and I have used it with water directly from the hot water tank, as above.
It originally came from Princess Auto with a Hypro Twin pump, coupled directly to a 1725 RPM 1 1/2 HP motor, similar to these:
http://www.rittenhouse.ca/asp/Product.asp?PG=891
lilredex is offline   Reply With Quote
Old 05-06-2012, 06:10 PM   #6
CoSnipe
Re: it depends on the pressure washer, I don't run the water too hot. It's just a suggestion, take it at face value.
Old 05-06-2012, 06:13 PM   #7
chadster1
Senior Member
chadster1's Avatar
Quote:
No problems in 5 years. My pressure washer is from northern tools, it has a comet pump.
Old 05-06-2012, 06:32 PM   #8
Az Scooter
Senior Member
Most pressure washers will lose their seals at about 150 degrees. There some that can take up to 180 degrees. Most hot water heaters are set at 125 degrees so you can't burn yourself too much.
Az Scooter is offline   Reply With Quote
Old 05-06-2012, 07:11 PM   #9
djkeev
Senior Member
djkeev's Avatar
My John Deere 4000 PSI pressure washer is only rated for 140 degrees, above that damages seals and check valves........they say.
I'd suggest you proceed cautiously.
I've had kerosene fired pressure washers that produced some ridiculously HOT water, almost steam like! Worked but also damaged items as well.
Dave
djkeev is offline   Reply With Quote
Old 05-06-2012, 07:33 PM   #10
Full Throttle
Senior Member
Full Throttle's Avatar
been using a Northern 3500 with Cat pump for 6 yrs on 120-135* water no issues.
Full Throttle is offline   Reply With Quote
Old 05-06-2012, 07:34 PM   #11
Sureshot
Senior Member
Sureshot's Avatar
Any heater you use is going to bump the temp by x number of degrees for your flow rate. You could always run "warm" water to the pump them boost it to "hot" after the pump with a homebuilt unit or a cheaper model.
I have a shower valve to supply my pressure washer and use the electric 40 gallon water heater in the shop. I don't boost the temp just like to have somewhat warm water for washing etc.
Sureshot is offline   Reply With Quote
Old 05-06-2012, 07:47 PM   #12
JASTECH
Senior Member
JASTECH's Avatar
I like where this is going/went! I can't use my "water heater" sence it's in the basement and turned off. I was planning on the Instant Heat's for the house to cut bill cost anyways. So matching the gph will get you the 150 or ? Let use know which I.H. unit is used and results please. How hot does the output need to be for shop floor, engine bay ect.
JASTECH is offline   Reply With Quote
Old 05-06-2012, 07:52 PM   #13
pmiracing
Most heated pressure washers heat the water AFTER the pump. This way you can get the water HOT without cooking the pump. If you look at a factory made unit they use a high pressure coil that is insulated on the outside and the fire flows around the high pressure coil to heat the water. I don't think you would hurt anything running "warmed water" through the pump but hot water (180-250) will eventually cook the pump.
pmiracing is offline   Reply With Quote
Old 05-06-2012, 09:06 PM   #14
Strouty
Senior Member
Strouty's Avatar
What about hooking up the tankless heater after the pump? I can get a 3 GPM heater and if the pressure washer is only 2.5 GPM then in theory, it would be able to keep up? I don't need crazy hot water anyways, just the warm, 130 degree water. I might start searching on making a pressure washer from scratch. Someone must make high temp pumps. I can't imagine that you have to spend $1500 to make one. Anyone every built one?
__________________
Old 05-07-2012, 12:34 AM   #15
Sureshot
Senior Member
Sureshot's Avatar
Make sure you stand back when you put the 2500-3000 psi on that water heater. Also warn the FAA.
Old 05-07-2012, 12:55 AM   #16
shurik06_83
Senior Member
toss the stock exhaust on a gas washer unit and plumb something up out of copper tubing then wrap the pipe with in a tight coile with soft coper line
ur copper exhaust will have to be really long to trap the most heat
and then it wont be perfect but but u should get warm watter and really hot water for the first min or 2
shurik06_83 is offline   Reply With Quote
Old 05-07-2012, 06:33 AM   #17
Strouty
Senior Member
Strouty's Avatar
Quote:
I guess that would be an issue, I was paying attention to flow not pressure. I think it would have been obvious before I would have gone too far.
__________________
Old 05-07-2012, 12:51 PM   #18
Sureshot
Senior Member
Sureshot's Avatar
I figured it to be a temporary thought
And then the light came on
Old 05-14-2012, 01:45 PM   #19
IndyGarage
Senior Member
Find a used hot washer - I looked for about a year before I found one at a decent price - then within a week I found three of them.
First, I bought an old clapped out Electro-magic unit on CL for $200. It worked fine after I replaced the burner pump, but I was a bit disappointed with the 110V pressure pump output, and the burner is old enough I'm a bit afraid to put a bigger pump on it. It's OK as is, because you just plug it into a 110 line and hook water to it.
Shortly after that I found two Mi T M portables missing their engines and with unknown problems. One of them ran good after I put a $110 Harbor Freight 208cc engine on it. I used it for about 15 hours over the past couple weeks.
The second one didn't work because it had a bad pressure pump. I'm putting a honda GX390 and pump from my cold washer onto that one - because I just love the high pressure high flow I get from it. I just have to make a pulley and spacer that fits between the pump and the engine to run the belt for the burner generator and pump. If I can get that to work, I'll sell off the others.
IndyGarage is offline   Reply With Quote
Old 05-14-2012, 02:10 PM   #20
Busted_Knuckles
Senior Member
Id look for a nice used one at a sale, around here they are common. I got mine from a city muni sale, its a Mi-T-M, made in Iowa, the entire frame and sheet metal of the machine is stainless, its got a 180 degree burner, and a 220v electric motor. $350.
Just cant put anything together for that little amount of money, would love to know what they paid for it new.
Busted_Knuckles is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
