Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 05-08-2012, 08:38 PM   #1
L5wolvesf
Senior Member
Default What would cause a GFCI outlet to trip?
The area all around the outlet (wall and floor) is dry, and nothing was operating except the ON indicator for a phone which is plugged into the same outlet. No storms in the area and all the other garage outlets are working.
The outlet was installed within the last few months in an area of the garage that has a washing machine. The outlet has operated fine since I put it in as a safety upgrade. When I installed it my plug in circuit tester showed 2 green lights (“Correct”).
That outlet is on the same circuit breaker which also has a couple other non-GFCI outlets. The only thing those outlets have on them are a pair of switch operated 2 bulb florescent lights. The outlet switch does not operate the GFCI outlet. Everything (washer & lights at the same time) has worked good so far, like it has for the last 5 years.
So, yesterday when I went to turn on the lights there was a slightly audible pop (or click) and no lights came on. Today after checking things out I found that the GFCI outlet had done its thing, but the circuit breaker had not tripped, and there was no juice to the switch. I reset the GFCI and plugged in my circuit tester – it showed 2 green lights (“Correct”). All is back as it was before.
Any idea what may be going on? What else would cause a GFCI outlet to trip?
Thank you,
L
__________________
AMONSTER MOTORSPORTS
L5wolvesf is offline   Reply With Quote
Old 05-08-2012, 09:32 PM   #2
Roots
Senior Member
Default Re: What would cause a GFCI outlet to trip?
Some lighting ballasts, particularly cheap ones, play havoc with GFCI's. Generally due to poor construction methods of the ballast.
Those three light testers are not entirely accurate as well, even though a lot of people use them. They can be 'tricked' both intentionally and by accident.
Roots is offline   Reply With Quote
Old 05-08-2012, 09:54 PM   #3
spongerich
Senior Member
spongerich's Avatar
I F$#$&ing hate GFCI's sometimes (except for when they save your ass).
__________________
Tool Junkie
Check out my YouTube Channel for machine shop videos.
See my eBay listings here.
spongerich is offline   Reply With Quote
Old 05-08-2012, 10:29 PM   #4
jbberns
Senior Member
I wouldn't worry about it unless it keeps happening.
jbberns is offline   Reply With Quote
Old 05-08-2012, 10:38 PM   #5
Frank The Plumber
Senior Member
Frank The Plumber's Avatar
Lightning strike in the vacinity of your wiring.
Frank The Plumber is offline   Reply With Quote
Old 05-08-2012, 10:52 PM   #6
Jarhead0408
Senior Member
Heavy rain does it at my house for some reason. but only the gfci that connects to an outside private lightpole.
Jarhead0408 is offline   Reply With Quote
Old 05-09-2012, 12:02 AM   #7
Kevin C
Senior Member
Kevin C's Avatar
As best as I can tell, it might be something to do with the odd harmonics from EMI filters on the ballasts. While I haven't found an article analyzing the problem direcly using lights, I did find an analysis of the GFIC and the EMI filters used on a variable speed drive.
The root cause should be the same...
http://www.jonathankimball.com/pdf/gfci_ecce.pdf
Still looking...
Basically the fluorescent lights can bring the GFIC close to the tripping threshold. A bank of 6, 4' double bulb T8 lights will trip my GFIC pretty regularly.
Kevin C is offline   Reply With Quote
Old 05-09-2012, 08:20 AM   #8
matt151617
Senior Member
It could be general dampness too. I had mine trip once on a humid day. There was probably a little moisture accumulation on the plug.
matt151617 is offline   Reply With Quote
Old 05-09-2012, 10:14 AM   #9
dipper
Senior Member
dipper's Avatar
Send a message via AIM to dipper
like all consumer grade products manufactured these days (and most likely made in china) the outlet itself could be defective. replace it or swap it with one that is in known good working order.
__________________
-Dipper
20x22 Build Pics: http://s630.beta.photobucket.com/use...e/1_Demolition
dipper is offline   Reply With Quote
Old 05-09-2012, 11:59 AM   #10
Jason641
The switch and lights do not need to be wired through the GFCI, the light fixtures are probably causing your issue. To fix this you can install a separate GFCI at each outlet location and keep all the wires on the "LINE" side of the receptacle. Anything hooked to the "LOAD" side will be protected by the GFCI and potentially make it trip. If you know exactly which outlet location has the feed going to the switch/lights you could install the GFCI there and keep the lights and the line in from the panel on the LINE side of the receptacle and the additional receptacles can be hooked to the LOAD side.
Jason641 is offline   Reply With Quote
Old 05-09-2012, 04:41 PM   #11
I void warranties
Senior Member
I void warranties's Avatar
agree above^^^^^ also i agree with the ballast theory... i had to change 6 ballasts before i found the culprit. even a amp meter will just barely read the max amps on a ballast at start up.
I void warranties is offline   Reply With Quote
Old 05-09-2012, 05:52 PM   #12
jbberns
Senior Member
Quote:
After tripping one time?
Old 05-09-2012, 07:00 PM   #13
L5wolvesf
Senior Member
Quote:
Quote:
No rain and few clouds in weeks before this happened. Have had rain since GFCI was installed with no problems I’m in AZ, it’s a dry heat
The outlet was new, and only a few months since installed.
Quote:
I just have a pair of 4 ft, 2 bulb T12s on this circuit.
Quote:
Anything I can do to address this other than replace the fixtures? They will be replaced as they go bad.
Thank you,
L
__________________
Old 05-09-2012, 07:01 PM   #14
L5wolvesf
Senior Member
Quote:
Not sure I fully understand what you are saying. I only “need” (for safety around a potentially wet area) a GFCI outlet for the washing machine. The other outlets (ceiling mounted) in the circuit are used for the florescent fixtures.
I guess the switch and lights are wired through the GFCI since the whole circuit was dead when the GFCI popped. I didn’t think that when the problem first happened. The outlets the lights are plugged into are activated by the switch. The GFCI outlet is always active.
Thank you,
L
__________________
Old 05-09-2012, 07:26 PM   #15
spongerich
Senior Member
spongerich's Avatar
Quote:
You know what else is a dry heat?
Fire
(Which is only slightly cooler than Phoenix in August)
__________________
Tool Junkie
Old 05-11-2012, 03:32 AM   #16
jeff000
Senior Member
Quote:
Possibly even before the first trip.
This.
Thank you,
L
You don't actually need a GFCI for a washing machine, not in Canada anyways. And my copy of the NEC may be outdated.
jeff000 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
