Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-11-2012, 02:43 PM   #1
Buzzard217
Default coating compressor tank?
Would it be worth while to coat the inside of a compressor tank like you would a gas tank? Just thinking preventative maintenance before rust has a chance to eat a hole in whatever new to me compressor I get.
Buzzard217 is offline   Reply With Quote
Old 05-11-2012, 03:19 PM   #2
NOZZLEMAN
Senior Member
NOZZLEMAN's Avatar
Default Re: coating compressor tank?
Cheaper and less problematic to install an automatic moisture ejector. I do know the NHRA Safety Safari trucks use a common air tank and coat it with a bed liner like industrial coating on the inside and fill it with water and ColdFire (a VERY corrosive extinguishing agent) and it lasts about 3-4 seasons. They were getting 1 on bare steel.
Good Luck
NOZZLEMAN is offline   Reply With Quote
Old 05-11-2012, 03:24 PM   #3
rlitman
Senior Member
Weird. If they're filling it with liquid, I would expect that they would use an anode rod, and it should last a really long time.
With an air filled tank, that's another story. If there is a pinhole, or even a scratch in the coating that lets moisture get through, it will leave a pocket that can corrode faster underneath the coating, than if were no coating at all.
This doesn't sound like a good idea to me, with the exception of something like a zinc coating, but that has its own down sides.
rlitman is offline   Reply With Quote
Old 05-11-2012, 03:37 PM   #4
pop pop
Senior Member
Always wondered if you could coat the inside with something like the old GE Glyptol paint. Don't know if even that is still available.
pop pop is offline   Reply With Quote
Old 05-11-2012, 05:25 PM   #5
nehog
Senior Member
nehog's Avatar
Quote:
Originally Posted by rlitman View Post
Weird. If they're filling it with liquid, I would expect that they would use an anode rod, and it should last a really long time...
Anode rod work for galvanic corrosion, but would be meaningless against many other types of corrosive agents.
Quote:
Yes, Gliptol is still available... Very expensive, much more than the cost of an automatic drain!
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
Volvo S80
Holiday Rambler Ambassador 40 DFD
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 05-11-2012, 11:44 PM   #6
rlitman
Senior Member
Quote:
Please explain this. Corrosion is an oxidiation process. It is a redox reaction, and that is a galvanic process which an anode will help with.
Old 05-12-2012, 06:05 AM   #7
nehog
Senior Member
nehog's Avatar
Anode rods are sacrificial, where you have a 'battery' caused by dissimilar metals. A strong corrosive agent would just dissolve the anode rod in a few minutes (perhaps with other unintended consequences!)
__________________
Volvo S80
VW Cabriolet
Old 05-12-2012, 10:08 PM   #8
stonesfan68
Senior Member
stonesfan68's Avatar
Quote:
Coating the tank will certainly help prevent corrosion, but it is tricky for a DIYer to get a good coat on the inside of a tank once the tank is welded together. As someone else pointed out you are better off with an auto drain valve.
stonesfan68 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
