Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-13-2012, 09:50 PM   #1
Frank
Senior Member
Default Protecting untreated wood that will contact the ground?
If you are just going to tell me to use treated wood instead, save it.
I am on a tight budget and I have been collecting a ton of new scrap lumber from area house construction (I always ask before I take any of it) and about ready to start building my 12 x 14 shed. I have built 3 skids from sandwiched together 2 x 8's, 3 boards thick. The only problem is, none of this wood is treated. I will either make a bed of rock under each skid or bury some kind of stones, but this doesn't guarantee they won't sink into this black clay and make contact. What is an effective method to treat wood that may come in direct contact with the ground?
For that matter, how long has commercially treated wood been around?
Frank is offline   Reply With Quote
Old 05-13-2012, 10:05 PM   #2
Bull
Bull's Avatar
Default Re: Protecting untreated wood that will contact the ground?
If you Google, you will find home-brew ways to treat wood, but from what I recall the methods are slow, messy, and most likely toxic.
I have heard about old-timers using diesel fuel to provide moisture and insect protection. Seems risky to me, though.
Maybe soaking them in linseed oil, especially the end-grain, will help. At most, you are just going to buy yourself some time before the rot sets in.
__________________
EUDAIMONIA
"It Pays to Stay in the USA!"
Bull is offline   Reply With Quote
Old 05-13-2012, 10:07 PM   #3
Justanoldguy
Senior Member
Justanoldguy's Avatar
Justanoldguy is offline   Reply With Quote
Old 05-13-2012, 10:20 PM   #4
pattenp
Senior Member
pattenp's Avatar
Use this:
pattenp is offline   Reply With Quote
Old 05-13-2012, 10:22 PM   #5
6768rogues
Senior Member
If it is in contact with the ground, it will rot. I put some hardwood skids with blocks on them behind my barn about 5 years ago. Last week I needed to move them and the skids had sunk into the ground and were completely rotten, not much left other than scraps of wood and nails.
__________________
Why a cool garage? Chicks dig 'em. Alcohol may intensify the effect. As John Belushi said in Animal House, "I suggest you drink and drink heavily."
6768rogues is offline   Reply With Quote
Old 05-13-2012, 10:33 PM   #6
Frank
Senior Member
I was thinking of using some concrete blocks around the perimeter to help lessen any sinking. I have heard of people stapling black plastic to the underside of the wood like in garden applications. I know any of it is postponing the inevitable.
Old 05-14-2012, 12:37 AM   #7
Boomer343
Senior Member
I would coat it with a couple of coats of foundation tar, wrap it all in 10 mil poly then put another coat of foundation tar over the plastic. There is also hard plastic foundation wrap that is dimpled material...if you could scrounge up some of that it would be good under the skids.
You could also use car undercoating in spray cans or get a pail of it , body shops have a sprayer they use and just fill from the bucket, and smear it on.
Not sure if you are using the 2 x 8's on the flat or edge. If on the edge you could run a 2 x 6 treated on the bottom where it contacts the soil but I would still tar everything.
Have fun.....
Boomer343 is offline   Reply With Quote
Old 05-14-2012, 05:07 AM   #8
rasit
Senior Member
rasit's Avatar
Quote:
If you can raise the wood out of the ground by using concrete block it may not lessen any sinking but it may buy a little time before rot. Avoid any plastic on the wood.... the idea is to let it breathe..
rasit is offline   Reply With Quote
Old 05-14-2012, 05:44 AM   #9
malibu101
Senior Member
malibu101's Avatar
I read and understand the first post about not talking about treated wood, BUT I'm going to anyway.
Maybe just use (buy) some treated timbers as a foundation and set your wood floor deck on top of those. Same idea like someone above said about using concrete blocks to keep the untreated wood out of ground contact. I think that any way of allowing the untreated wood to breathe and not touch ground/stones would insure the longest lasting job.
If the above can not work for you. I'd then too say slather it with your choice of some kind of preservative and use and enjoy the shed for as long as it stands.
malibu101 is offline   Reply With Quote
Old 05-14-2012, 05:48 AM   #10
camarotoolman
Put some layers of plastic sheet on the ground or over cement blocks before starting. that will keep the moisture and bugs away from the wood.
camarotoolman is offline   Reply With Quote
Old 05-14-2012, 06:46 AM   #11
bczygan
Senior Member
bczygan's Avatar
Anything you do to protect the untreated wood will cost more time, effort and money than just buying some treated lumber for the bottom of the skids. Look for treated lumber in the scrap piles where decks are being built. Piece it together as the bottom surface of the skids.
In any case, even with treated lumber, it is good to have positive drainage down and away from your skids.
Dig a trench under where each skid will be, extend it away from the structure for drainage. Dig it down to firm earth (Sand or clay). Line it with landscape fabric to keep the stone from disappearing into the ground. Fill the trenches to above surrounding grade and tamp to compact.
Set the timbers on this and they will last far longer.
__________________
bczygan is online now   Reply With Quote
Old 05-14-2012, 06:53 AM   #12
darkk
Senior Member
You are only building a 12x14 structure, how much is it going to cost for two 2x6x14's and two 2x6x12 pressure treated boards? It is going to cost you as much time and money to protect untreated wood as it will to buy pressure treated for sill. But in the old days my uncle used to soak ground wood in used oil from oil changes with a little diesel mixed with it but it was temporary at best.
__________________
My garage build: http://www.garagejournal.com/forum/s...ad.php?t=39357
darkk is offline   Reply With Quote
Old 05-14-2012, 07:04 AM   #13
BD1
Senior Member
BD1's Avatar
Quote:
I built a 12x16 shed 20 years ago. Laid 6'' concrete block level on ground. Poured concrete mix in various locations for 1/2'' threaded rod to anchor sill plates. Then just stick built walls. No treated lumber at all. Building is still straight and level. The 4'x7' door openings are still square. Exterior is all 3/4 plywood.
If your building is going to stay in one location , you can pour four concrete piers. Post hole dig down say 3' and pour four columns to level height and set building on them. I did this with a corn crib, chicken coop, and grain bin. Not
too costly and effective.
BD1 is offline   Reply With Quote
Old 05-14-2012, 07:06 AM   #14
wssix99
Senior Member
wssix99's Avatar
Foundation sealer works great for this.
wssix99 is offline   Reply With Quote
Old 05-14-2012, 07:12 AM   #15
Torque1st
Senior Member
Torque1st's Avatar
What about termites???
There are different ratings for treated wood. Some types are OK for earth contact and some are not.
That Woodlife Creocoat looks worth investigating.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 05-14-2012, 07:24 AM   #16
KEH
Senior Member
I understand from your post that you have a soft type of soil that things will sink in. That bein the case, if you used treated lumber I would be afraid that it would sink into the ground enough to get the untreated wood in contact with the ground and then the rot and insects would start.
The tar and plastic mentioned above by Boomer 343 sounds good. Don't know about the cost of doing that vs. buying treated lumber, you would have to put a sharp pencil to it.
What I would do is use the un treated lumber you have and concentrate on keeping it off the ground. Buying ready mixed concrete is expensive. The cheapest way is to buy sand, gravel and concrete mix and then mix it yourself. Make a small box out of your scrap 1 x lumber to mix it in. Use a garden hoe to stir it. have a shallow trench dug and leveled, pour concrete in, smooth it some, the it dry, then stack blocks 2 runs high.
Blocks are expensive. You could save by building 2 block high pollars at the corners and half way down the side, again pouring concrete footers under each pillar and leveling same. Assuming you are going to use the ground for a floor and don't want air blowing under the wall, use pirces of tin to fill in the space and make ground contact. Yes, it will rust eventually and need replacing, but not for a long time.
I would bit the bullet and get treated lumber for most of the door or doors it there is going to be ground contact.
Put a small piece of tin(these can be purchased commercially, I think, with turned down edges to let rain run off) to keep termites from clumbing up and attacking the wood.
Good luck.
KEH is offline   Reply With Quote
Old 05-14-2012, 07:25 AM   #17
KEH
Senior Member
Signature on above post is KEH, sorry.
KEH
Old 05-14-2012, 08:58 AM   #18
Stephenw
Senior Member
Stephenw's Avatar
Castles made of sand melt into the sea, eventually.
Stephenw is offline   Reply With Quote
Old 05-14-2012, 09:09 AM   #19
RECox286
Senior Member
RECox286's Avatar
Here is a thought to ponder:
When I built my 10x12 shed 35 years ago, I got some used telephone poles
from the Elect Co. for free. Basically I used them as foundation pilings,
digging them down to below the frost line. If you have ever been to
the "shore" and I mean the ocean, you may be aware of the type of
construction to which I refer. You can not buy lumber that has the
treatment that these old poles get during manufacture. Also, the good thing
about putting your shed up in the air is it stays dry underneath, regardless
of the wx. 35 years later, no signs of rot, except around the north facing
window. Gee, I wonder why ?
Uncle Bob
RECox286 is offline   Reply With Quote
Old 05-14-2012, 10:37 AM   #20
buening
Senior Member
Quote:
Best solution I can think of as well. If you want to be super cheap, skip the poly and just coat the crap out of it with foundation tar. The tar typically keeps pests away and makes a fairly waterproof barrier.
Quote:
Quote:
Both my concerns as well. Make sure you aren't stepping on a dollar to pick up a quarter!
__________________
1970 Mach 1
1970 Mustang Fastback
2003 Mustang
2005 F150 FX4
Licensed Professional Engineer, PE (Civil)
Licensed Structural Engineer, SE
buening is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
