Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-14-2012, 09:33 PM   #1
kert
Senior Member
Default Need help raising trusses
I will be setting trusses for my 30x60 in a couple weeks, and I'm looking for some suggestions.
The trusses will be 30' span room in attic with no overhang with no overhang weighing 230lbs a piece. My main level ceiling will be 10' and the trusses will be 12' tall. With about 9' from the bottom of the bottom cord to the bottom of the attic "ceiling joist." I will be building my own end-frames.
The last 16' will have a different roof system and I will leave out a section of wall, so I should have some room to maneuver a piece of equipment inside.
I'm thinking my best option is a "shooting boor fork lift." I would ue a strong-back and chain to lift each truss into place and have a person ready on each wall to position and attach each truss as it comes. Does this sound like a good plan?
The next question I have is how do I set the first truss and get it braced? I'm thinking maybe I should build and attach the end-frame so that I can set it on the end-wall and it will be relatively stable and then I can continue with diagonal bracing as I add trusses. Any other ideas? I don't think it is very reasonable to try to brace to the ground as the end where I plan to start is probably another 4' lower than the slab where I would be bracing.
kert is offline   Reply With Quote
Old 05-14-2012, 09:52 PM   #2
Full Throttle
Senior Member
Full Throttle's Avatar
Default Re: Need help raising trusses
Hire a Crane
only advice to be given
Full Throttle is offline   Reply With Quote
Old 05-14-2012, 11:07 PM   #3
Steevo
Senior Member
Steevo's Avatar
My best advice is to have something that can lift the trusses into place without having to be inside the structure. Basically, like FullThrottle said, a crane.
That, and watch weather reports for a calm day. Raising trusses in the wind can be extremely unpredictable.
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is offline   Reply With Quote
Old 05-14-2012, 11:11 PM   #4
RivennHewn
Senior Member
RivennHewn's Avatar
Doesn't your supplier have a boom truck?
RivennHewn is offline   Reply With Quote
Old 05-14-2012, 11:17 PM   #5
MP&C
Senior Member
MP&C's Avatar
When we built my house and garage, the delivery truck came with a boom. They would set the trusses off in a pile, or if you had the help ready would set the trusses in place for an hourly rate. Well worth the money.
__________________
Robert
MP&C Shop Projects-Metalshaping Tutorials
Super Street/Super Gas 65 Fairlane build
Instagram @ mccartney_paint_and_custom
MP&C is offline   Reply With Quote
Old 05-14-2012, 11:20 PM   #6
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Down here, all the trucks I've seen delivering trusses are flat beds with no booms. The trusses are tightly banded together and the trailers have a distinct downslope from front to rear, some have rollers built into the bed. They literally slide/roll them off the back of the truck or trailer and pull away, leaving the bundle laying on the ground.
Charles
Charles (in GA) is offline   Reply With Quote
Old 05-14-2012, 11:38 PM   #7
64dragnwagon
Senior Member
64dragnwagon's Avatar
Not recommending it but my builders put up my 30' scissor trusses by hand with 3 guys. They walked one side up a ladder on the 13' wall and then the other side up another ladder with the center point of the truss pointing down then a guy in the middle pushed the center point of the truss up thereby pivoting it into an upright position. Then the two guys on the ladder nailed them to the wall header. I was amazed before I saw it when they told me they always do it with no equipment.
__________________
Here is a link to my build thread
http://garagejournal.com/forum/showthread.php?t=138158
64dragnwagon is offline   Reply With Quote
Old 05-14-2012, 11:40 PM   #8
kwb
Senior Member
All of mine have been delivered to top plate of the new construction so long as the walls were up.
If the floor is in -buy a small cheap cushion tire forklift and sell it when the building is done (you might find that you never want to sell it). My shop I had the floor in and had a small scissorlift that I used to move trusses into place. Forklift would have been much better.
If not a Telehandler works great for placing trusses and can be rented for a weekend and have great manuverablity if the site is a bit tight. We used one on my brothers shop for placing trusses, lifting/tilting walls, getting sheeting up to the roof, working in a basket on the forks to do siding, lots of good stuff.
kwb is offline   Reply With Quote
Old 05-14-2012, 11:52 PM   #9
srmofo
Senior Member
I raised my trusses by hand on 10' walls 24x36. Mine were nearly as large/heavy as yours. I would not want to do those by hand.
My buddy rented a crane for a couple hours and it was remarkably cheaper than I was expecting. It came with a operator and a spotter. we just hooked them up and fastened them down.
srmofo is offline   Reply With Quote
Old 05-15-2012, 12:22 AM   #10
Sureshot
Senior Member
Sureshot's Avatar
Location: Sold the shop in Saskatchewan and currently shopless in South Dakota
Quote:
This is how I did my 26x26 as well but it was only 3/12 pitch.
Sureshot is offline   Reply With Quote
Old 05-15-2012, 12:43 AM   #11
Justanoldguy
Senior Member
Justanoldguy's Avatar
Exactly how I did mine.
Pretty easy really.
Justanoldguy is offline   Reply With Quote
Old 05-15-2012, 01:06 AM   #12
ForceFed70
Senior Member
ForceFed70's Avatar
Hired a crane to do mine, was worth every penny.
To set the 1st truss, I screwed some vertical 2x4's to the exterior wall and affixed the gable end truss to the 2x4's.
ForceFed70 is offline   Reply With Quote
Old 05-15-2012, 01:22 AM   #13
mrobins297aaa
Senior Member
mrobins297aaa's Avatar
here's how they did mine, there 36' footers
mrobins297aaa is offline   Reply With Quote
Old 05-15-2012, 01:36 AM   #14
Steroblan
Senior Member
If you have post beam construction, and the posts have not been cut to height yet, we made a simple cable hoist for each end of the truss that fit over the top of the post. It was made with a 10ga sheet metal cap with a base for the cheap boat winch. One on each end of the truss and pulled it up to the exact height. Can be done with two guys. See the link to see the construction style. It can be adapted for single or double trusses.
http://www.maccometalbuildings.com/i...&id=6&Itemid=6
Steroblan is offline   Reply With Quote
Old 05-15-2012, 01:54 AM   #15
IndyGarage
Senior Member
I've done them like the above photos before, it's slow, hard work, but you can do it.
230 lbs is not outrageously heavy - If you really wanted to go cheap, You could probably build a tall wrecker-type A shaped boom out of wood or some 20 foot long metal tubing and mount a pulley block on the end. Then mount it in the back of a pickup truck, and put a hand winch and cable on it. You have to be able to get the peak of the trusses, so I don't know how high that is.
They make devices that fit on Bobcat buckets or front loader buckets to do that. You could also use the boom of a mini excavator, or an offroad forkilift would be ideal. I'm quite certain your local tool rental can fix you up with something pretty easily and you'd probably get a single day charge, if you take the time to lay everything out ahead of time . Never underestimate the value of heavy equipment to make a job much easier. .
Google "truss setting boom" and click on the "images" tab and you'll get 100's of ideas.
IndyGarage is offline   Reply With Quote
Old 05-15-2012, 02:19 AM   #16
ddawg16
Senior Member
ddawg16's Avatar
Material Lift....
I rented one for $50 for the weekend....good for several hundred pounds...and you can get them to lift stuff up to about 18'.
Click on the link in my signature....I lifted a couple of beams that were serveral hundred pounds....
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 05-15-2012, 06:44 AM   #17
camarotoolman
I would hire a framing crew and be done with it. Have them deck it and dry it in too.
camarotoolman is offline   Reply With Quote
Old 05-15-2012, 07:10 AM   #18
yost69
Senior Member
We set the first house by hand with 4 guys. One on each end and one in the middle. The last one got the next truss ready to be set.
Now we use an old bucket truck that used to be owned by the electric company.
I would rent a crane and operator or see if any place in your area rents bigger bucket trucks.
But I am lazy so I would not want to ever set trusses by hand again.
yost69 is offline   Reply With Quote
Old 05-15-2012, 08:22 AM   #19
NUTTSGT
NUTTSGT's Avatar
We put our trusses up by hand but they were smaller. If you can afford it, rent out a forklift (like a JLG) if you can't, man handle them.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 05-15-2012, 08:34 AM   #20
dirttracker18
Senior Member
dirttracker18's Avatar
30 foot scissor trusses here on 12' 6" walls and we did it by hand.
I will never do that again!
I had a material handler and we made an attempt but it was too unstable to be trusted. We had an end truss tip over and get damaged. Luckily it was not a scissor.
My advice, hire a crane or boom truck. If everything is read you can have them all up in an hour that way.
__________________
"Success is when you reach a point in your life when you don't feel the need to go back and change things."
Johnny S.
www.LauraMyersPhotography.com
dirttracker18 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
