Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Search this Thread Display Modes
Old 05-21-2012, 09:37 AM   #1
judgethis
Senior Member
Default 2000 Ford F250 steering wander.
My friend has a 2000 Ford F250 he just recently purchased. He was told it needed gear box for steering wander/play. Truck has 350,000 and looks like new. very well maintaned. over $100,000 worth of maintenance including the price of the truck. Has all reciept. Anyway we replaced the steering gear box and he said it's 60 to 70% better but still has play/wander. I drove it and at high way speeds it feel like there is some play. It feels like if you hold the wheel when driving you can turn the wheel left or right about an inch before the truck starts to turn then you tend to over compensate for it and it starts to wander in the other direction so you constantly working the wheel. All the steering linkage seems tight-didnt feel any play. Is this a normal feeling or something else I could look at? I Googled it and some say its normal, others replaced every other part to fix it. If it were mine Id be fine with it. Thanks
judgethis is offline   Reply With Quote
Old 05-21-2012, 09:53 AM   #2
checkthisout
Senior Member
Default Re: 2000 Ford F250 steering wander.
Quote:
Lower Ball Joints.
There used to be a service bulletin for it?
There is a diagnostic procedure but I am not sure if you would have the right equipment to do it. You could wing it by jacking the front end up, disconnecting the tie-rods from the knuckles and seeing how hard the knuckles are to rotate by hand.
Use your best judgement as to whether they feel stiff or not.
And the that track bar bushings....but that usually usually results in clunking and all sorts of noise.
checkthisout is offline   Reply With Quote
Old 05-21-2012, 09:56 AM   #3
dlewis
Senior Member
dlewis's Avatar
Put it on jack stands knock the drag link loose and turn the tires side to side and see if it's bound up,if they turn free try adjusting the box if it's rebuild they might have it adjusted to tight.
dlewis is offline   Reply With Quote
Old 05-21-2012, 10:19 AM   #4
Sureshot
Alliance Member
Sureshot's Avatar
Did it get a recent wheel alignment?
I have used a ratchet strap wrapped around and tightened down to hold the "input" shaft tight so you can confirm it is not between the steering wheel and box.
The front wheel bearings are confirmed good?
Sureshot is offline   Reply With Quote
Old 05-21-2012, 10:35 AM   #5
Senior Member
4WD or 2WD ? Makes a big difference.
Take it to a shop that specializes in front ends. If all parts check out good, have them add about 1-2 degrees of positive caster above the spec. Additional caster does not cause tire wear, but will require a bit more steering effort to move from center.
If you live in an area with high center crown roads, the caster needs to be different, left to right.
A "good" front end mechanic will know all of this.
theoldwizard1 is online now   Reply With Quote
Old 05-21-2012, 10:47 AM   #6
KPSquared
Senior Member
That vintage of F250/350 has some unique issues with steering. There are several things that can make them wander all over the road. . .
Suspension bushings - If they haven't been replaced with good polyurethane bushings, I would do it immediately without hesitation. . . makes a world of difference in how these trucks handle. Anti-sway bars and leaf springs/shackles. . . they all can wear and make the truck wander like a drunken sailor.
Power steering pump - These need to run synthetic ATF and can fail prematurely if you try and run standard power steering fluid. Dad's truck wandered all over the place and we threw a new pump on and it fixed the issue.
Then you have all the standard steering stuff. . .ball joints, TRE's and wheel bearings. Those are easy to check and not rocket science to replace.
If all these things listed above are in good working order and you have a new steering box, the truck should be solid as a rock.
__________________
My Garage in the Works --> CLICK HERE
KPSquared is offline   Reply With Quote
Old 05-21-2012, 10:50 AM   #7
judgethis
Senior Member
Had a front end alignment after putting on the gear box. Wheel bearing felt tight, had no play. New traction bar installed recently as the Ford sticker still on it. Looks as if the drag link was replaced also. All linkage looks clean likes its been changed. Ball joints were replaced at one time but will check by knocking the linkage free from gear box and check them. Thanks for the input everybody.
Its a 4wd, 7.3 diesel.
Old 05-21-2012, 11:16 AM   #8
KPSquared
Senior Member
As I said, double check the PS pump. Even if you have to drain it and refill. Make sure it's strong and has the right fluid. It can really be evil in these trucks. . .
I'm a die hard Ford guy. . . mine's an '01 F350 4x4 CCSB diesel, dad's is a '99 F250 4x4 CCSB diesel, cousins is a '00 F350 4x4 SCLB diesel and an '05 F350 4x4 CCSB diesel. . . these suckers are in my blood.
__________________
Old 05-21-2012, 12:12 PM   #9
powpow
Senior Member
my truck wanders some as well, 02 f-350 crew cab long box with a 7.3. I have 285 series tires on it, not sure if that has something to with it. I just replaced all teh ball joints, front hubs, wheel bearings, seals, u-joints, etc. I will try to explain
Driving down the road, hold the wheel straight, the truck ever so slightly moves to the left, compensate with teh wheel to teh right, back and forth. The steering is tight.....all seems ok. Is it possible the ball joints need to "set in"?
powpow is offline   Reply With Quote
Old 05-21-2012, 12:17 PM   #10
speed bump
Senior Member
speed bump's Avatar
On my work truck (01 F-250) replacing the steering stabilizer cured most of my steering wheel play. Not saying that will fix your ills, but I would check it.
__________________
Its not magic its experimental, kind of like washing your hands after pooping used to be. -House
Quote:
Originally Posted by NJHandyGuy View Post
Agreed that makes about as much sense as a pimp with a health plan.
speed bump is offline   Reply With Quote
Old 05-21-2012, 01:04 PM   #11
fergus
Senior Member
fergus's Avatar
I've got a 2000 Superduty 2wd. I have the same issues. I've done ball joints twice already with 210k on it. It didn't help much. Alingments did little to fix it as well. Tightening the lash on the steering box helped some, but not enought.
From what I have read, the only way to really cure this is a steering box from these guys: http://redheadsteeringgears.com/index.html
They totally remanfacture the box by pulling the bushings and machining the box to accept needle/roller bearings. The factory specs on the boxes have too large tolerances and that's part of what causes wander. I called them up last week, they quoted me about $350. From what I have read on all the ford forums (powerstrokenation.com, ford-trucks.com) this is THE fix. All the other things could be contributing factors as well, but it seems like this is the final solution after others have been exhausted.
fergus is offline   Reply With Quote
Old 05-21-2012, 01:27 PM   #12
judgethis
Senior Member
I was wondering about a steering stabilzer. This truck doesnt have one on it but dont know if it ever had one either. I see where it has the perch for the one end so its posssible it set up for one. We did drain the fluid but we didnt fill it with synthetic fluid, we just went by the owners manual.
Old 05-21-2012, 03:31 PM   #13
KPSquared
Senior Member
Default
I've never seen an F350 without a stabilizer. That will help, but probably won't solve the problem. Get on powerstrokearmy.com and do some reading. Tons of info there. powerstrokenation.com ain't bad either but I really hate the Autoguide group that owns it. . .prefer to support the little guy rather than the big soulless corporation. . .
__________________
Old 05-21-2012, 03:36 PM   #14
DENALIAKITAS
Senior Member
Tires, there are a couple brands out there that are known to have wandering problems on diesel straight axle front suspension trucks. Falken being one of them, ask me how i know.
DENALIAKITAS is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
