Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-10-2012, 01:28 PM   #1
dwlee6
Junior Member
Default Clark forklift ID and questions
Took the plunge and bought an old Clark forklift. Need help with identification and a few questions. Photos attached. Looks like a “Carloader” from comparison to photos saw posted on web.
Has 4 cylinder flathead? gas engine looks like original paint on engine is medium blue. Seems to run well. Seller said it was 3500 lb capacity, but don’t think they knew anything about forklifts beyond what who they bought it from told them. I worked as a ASE certified auto tech for a few years back in the 70’s and have pretty good mechanical knowledge overhauling engines, transmissions, machinery, electric motors etc., but this is my first forklift.
Questions:
SERIAL NUMBER LOCATION FOR ID
I read somewhere serial number was on frame, someone posted was :”under battery” which looks to be in original carrier on right side inside the access door. Took out battery and took a quick look, did not find anything under the accumulated crud in that area. Before I scrape too much, am I looking in the correct place?
BRAKES
When I got it home, the brake pedal did nothing – went to floorboard with no resistance or braking action. Looked in master cylinder and it was about ˝ full of fluid. That was yesterday. Today I went out in garage and pumped the brake pedal a bunch of times, and now it has resistance, firm not spongy near the top of it’s travel. Did not have room or time to start it up and move it, but I could hear something moving inside the right front wheel when I pressed on the brake pedal and I put the machine in neutral and rocked it fore and aft a little with a 2x4 and pressing the brake pedal stopped me being able to rock it, so maybe the brakes do work? I’m not one for fixing it if it ain’t broke so will add some brake fluid and try things out when I get some time. Any ideas on why no pedal yesterday, OK today?
HYDRAULIC OIL MILKY COLOR
The oil in the hydraulic tank which is in front of the motor, sort of under the front of the seat looks milky. Photo attached shows a bit of it running down the outside of the tank that dripped off a dipstick I stuck in to check the level. Any idea why it is this color? How high in the tank is the level supposed to be, and what oil to use? Can I get the 5 gallon pail of tractor hydraulic fluid/trans fluid and use that? How about automotive automatic transmission fluid? The lift seems to work OK and it has no major leaks, the lift cylinder area especially is dry. The little bit it does leak somewhere leaves a few drips on the floor at right front of the machine, maybe a few inches overnight. The radiator coolant looks clear light green like someone did use an antifreeze mix in it, so there does not appear to be comingling of coolant, though I don’t even think these systems are interconnected anywhere.
ENGINE OIL DIPSTICK
Where is the engine oil dipstick and any idea how much oil goes in the motor and oil filter part numbers?
STEERING
The unit has about 1/3 of a turn free play in the steering. Have not looked underneath to see where the play is – probably stack up of all linkages and box. Is this “normal” for a machine this age? Any suggestions where to look first?
dwlee6 is offline   Reply With Quote
Old 06-10-2012, 03:48 PM   #2
bgott
Senior Member
Default Re: Clark forklift ID and questions
I've never seen a forklift with really good brakes. I think they design 'em to be a little loose, if they locked up and you had a load up in the air you could flop the truck over pretty quickly. I would bleed them and fill with fresh fluid. The hydraulic fluid needs changed, it has a lot of water in it. Outside parking?
bgott is offline   Reply With Quote
Old 06-10-2012, 05:39 PM   #3
WWIIjeep
Senior Member
WWIIjeep's Avatar
I think it's a Model 20B or 25B or C. It's similar to a Clark Yardlift (Y-series), but Yardlifts had pnuematic tires as opposed to cushion tires (Carloaders or warehouse lifts). Otherwise, most of the rest of the lift should be the same as the Y20 or Y25. Probably mid-late-50s to early-60s vintage (I'm better at identifying the even older ones and the Yardlifts).
The engine should be a Continental Y-91.
3500 lbs is somewhat optimistic. It's likely 2000 lbs (on 24" center). It might be 2500 lbs, but let's be conservative for now.
There should be a nameplate on the left front of the motor housing (down and to the operator's right). I don't remember ever seeing anything on or under the battery boxes except corrosion. I vaguely remember seeing serial numbers on frames of Clarks I've had completely apart, but don't remember a particular location and might even be thinking of some other make.
BRAKES
Air in the brake lines. There's not much brake line and a small master cylinder, so a little pumping usually gives you brake pedal as long as there's fluid in the system.
Forklift brakes are generally poorly maintained, especially on old lifts. You really should flush the master cylinder and the lines, check/rebuild the wheel cylinders, and check and adjust the shoes, but I also agree with the "if it works, don't fix it rule" so, assuming your parking brake works (in case of emergency) if you want to just run it for a while and see how the brakes act, that's probably OK, but I wouldn't try driving down a hill with a heavy load until you're sure of the brakes.
Probably some water or condensation in the hydraulics. Did you check it after it had been running? Sometimes hydraulic oil foams and looks milky and therefore contaminated, but isn't. DO NOT use automatic transmission fluid. Tractor hydraulic fluid is OK if you drain the contaminated stuff out first.
ENGINE OIL DIPSTICK
Y-91 engine takes 4 quarts. Oil filter number depends on which type you have. Assuming it's a cartridge type and not a screw-on, just open the top of the filter canister and see which filter is inside, because more than one size has been used on those engines.
STEERING
1/3 turn isn't bad at all for an old forklift, although you can probably get it tighter than that. I've managed to get really loose ones down to less than 1/4 turn of free play pretty easily usually. One common place where steering slop can develop is where the linkage pivots on the frame, and that's where I'd look first.
Welcome to the forklift club. Try not to let your friends, relatives and neighbors see it, or all your free time will be taken up with low-pay or no-pay lifting and moving jobs.
WWIIjeep is offline   Reply With Quote
Old 06-10-2012, 06:01 PM   #4
Milton Shaw
Senior Member
The one I had the model number plate was on the left front of forklift between the tower and the cab. Those will take a special jack to pick it up. Northern tool has one its a very low profile strong jack for forklifts. I bought a lift not running and when I got into it, found enough stuff that I ended up selling the lift instead of fixing it. Had cracked block plus cylinder leak plus brake and clutch problems. Dip stick after I got it running and looked at it was four inches up from full and looked like a milk shake. Water went straight into oil pan from radiator, not worth a rebuild. The brakes are a little funky but you should be able to figure them out. Bleeders are a little hard to get too and are in an elbow from wheel cylinder at least they were on mine.
Milton Shaw is offline   Reply With Quote
Old 06-10-2012, 06:06 PM   #5
dwlee6
Junior Member
Thanks for info WWIIjeep. What part of Arizona? My sister in law lives in Scottsdale, used to go out there regularly. Ben Avery is one of the best (and certainly biggest) ranges I've been to.
I'll flush the lines and add new fluid and see what happens. There is no parking brake, at least that I have seen so far. I've seen pictures of some units that have a handle on the right with a grip release looking thing, but there is no such handle on mine, nor a hole in the floor board where it would have been that I remember seeing.
Regarding the hydraulic fluid, checked it after it sat for a day. Any idea how much fluid to change it all out, and any opinions on the completely flushing out process, or just drain tank and refill and live with what is left in lines, cylinders, and pump?
I bought this intending on using it to load all my shop tools on the ABF "you load we move" truck then selling or scrapping it. Looking around inside the engine bay and seeing how solid it is and the apparently good shape, I am tempted to keep it. Prior owner just put on a new starter, battery, coil and looks like voltage regulator. Now I have to buy a trailer to move it to Texas with, then sell the trailer . . .
Old 06-10-2012, 06:59 PM   #6
Steevo
Senior Member
Steevo's Avatar
Rent U-haul flatbed car trailer to transport it on.
That is a sweet forklift. As long as the engine is sound, the rest is easy.
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is online now   Reply With Quote
Old 06-10-2012, 07:45 PM   #7
WWIIjeep
Senior Member
WWIIjeep's Avatar
...I'll flush the lines and add new fluid and see what happens. There is no parking brake, at least that I have seen so far. I've seen pictures of some units that have a handle on the right with a grip release looking thing, but there is no such handle on mine, nor a hole in the floor board where it would have been that I remember seeing.
Some units have an electro-hydraulic parking brake mounted below the master cylinder. There will be a button on the instrument cluster to control it. If yours has that, press and hold the button on the instrument cluster, then press the brake pedal and release. To release the brake, press and hold the brake pedal, then press the button on the IC and release. Don't be surprised if you have that type and it doesn't work.
...Regarding the hydraulic fluid, checked it after it sat for a day. Any idea how much fluid to change it all out, and any opinions on the completely flushing out process, or just drain tank and refill and live with what is left in lines, cylinders, and pump?
There's a recommended flushing procedure when draining the hydraulic reservoir. I can probably find and scan a copy of it rather than trying to explain it, especially since I'm not sure I remember it exactly.
Clark recommended SAE 10 hydraulic oil or equivalent. Modern equivalent would be ISO 32.
A flush and fill will take somewhere between 8 and 12 quarts, depending on the diameter of your lift cylinder and upright lift height. 8' lift height, about 9 quarts, 10' lift height, about 11 quarts.
...I bought this intending on using it to load all my shop tools on the ABF "you load we move" truck then selling or scrapping it. Looking around inside the engine bay and seeing how solid it is and the apparently good shape, I am tempted to keep it. Prior owner just put on a new starter, battery, coil and looks like voltage regulator. Now I have to buy a trailer to move it to Texas with, then sell the trailer . . .
Since it sounds like it's in pretty good shape, I'd recommend keeping it, but I'm a notorious forklift enabler and codependent.
Once you have one, you'll wonder how you ever got along without one, especially as you get older or develop back problems. If you do engine or body removals/installs, the forklift will pay for itself with one use. I hardly ever use the engine hoist or gantry crane anymore, just the forklift with a short fork extender and hook instead.
For moving it, assuming you can't just put it in the ABF container once you've finished loading everything else, I'd suggest finding a place where you can rent an elevating-platform or hydraulic-deck equipment trailer. You just lower it, drive on, raise it. They're made for moving forklifts and platform lifts and so on, and there are places that rent the trailers alone. You'll need a 3/4T or larger truck to tow those types of trailers.
Forklifts are generally too heavy and too concentrated of a load to be hauled on a regular car trailer. Figure yours weighs somewhere between 4000 and 5000 lbs, with the primary issue being the very small footprint for that weight.
This type of trailer is excellent (I've owned one for several years), and they can probably suggest a rental outlet to you:
http://air-tow.com/
Renting one of those will probably be an easier and cheaper option than buying a used trailer and then reselling it or whatever.
Lastly, I just noticed I forgot to answer your earlier question about where the engine oil dipstick is located. On the Y-91 engine, it should be on the driver's right side, between the starter and the hydraulic pump.
Old 06-10-2012, 09:57 PM   #8
Ancient Iron
Senior Member
You should go to a clark dealer and pick up a repair manual and a parts book, They will answer a lot of questions. Just a suggestion
Ancient Iron is offline   Reply With Quote
Old 06-10-2012, 11:15 PM   #9
Boomer343
Senior Member
I'll second the idea of once having one you'll wonder how you did without.
Brakes are easy to fix and the cylinders are probably leaking.
Just a word of caution when you go to lift it to do any work....the concentrated weight will tax even a good jack and if you are on any kind of angle things get interesting real quick.
The old Clarke I got to play with had lots of slop in the steering box so adjusting that took some of the play out of the steering.
Lastly if there is any kind of slick surface will you have no traction, I repeat no traction....if you are on a slick incline.....you will learn new ways to express yourself.
Boomer343 is offline   Reply With Quote
Old 06-11-2012, 12:28 AM   #10
dwp99
Senior Member
dwp99's Avatar
Quote:
As far as jacking up the drive wheels I use to tilt the forks all the way back then pile up blocking under the ends of the upright. Second tilt the forks forward. This will raise the drive wheels off of the ground. set more blocks under frame behind drive wheels and tilt forks back. Now the drive wheels are off the ground and the fork lift is safely supported. You will need a heavy duty low profile jack for the steer wheels.
__________________
Doug
dwp99 is offline   Reply With Quote
Old 06-12-2012, 08:59 AM   #11
dwlee6
Junior Member
Thanks to all who responded with info on my forklift. I found the serial number which was stamped on the outside of the right side “frame”” the big ˝” plate slab side of the machine near the floorboard intersection. I contacted Clark equipment and they sent me a brochure on the machine a 1955 model year Carloader 4024 it turns out to be. 4000 lift capacity with curb weight 6800 pounds. It is a 1 mb file so don’t think can attach but if anyone wants it PM me. They also sent the original build card with all the part numbers in the machine and the name of the original dealer and purchaser which was pretty neat. When I get time I am going to flush/change the brake fluid and the hydraulic oil. The Clark literature says there is an electric parking brake actuator/lock for the hydraulic brakes as one poster mentioned but that button if there was one is gone from my “instrument panel”. Will check that out someday when I get time.
Old 06-12-2012, 11:34 AM   #12
Thruxton
Senior Member
Thruxton's Avatar
I have no idea if it is, but if the steering is hydraulic, changing and refilling the hydraulic fluid to the right level may fix things right up.
__________________
Martin
My 19 X 19 wood-metal-car shop redo - Major Milestones Update July '12!
http://www.garagejournal.com/forum/s...ad.php?t=92642
I want what I do to look like I did it on purpose.
Thruxton is offline   Reply With Quote
Old 06-12-2012, 11:42 AM   #13
dwlee6
Junior Member
Manual steering. Probably cumulative slop in linkages and box.
Old 06-12-2012, 07:52 PM   #14
cyamaha2007
Senior Member
cyamaha2007's Avatar
id be really surprised if it picked up 3000lbs. My forklift"very similar to yours" will be very tippy at 2100 ish. A few guys on the back and you could get pickup 2400 with no steering due to rears off the ground. Ive since poured a 700lb concrete weight to sit on the counter weight. She will lift until it stalls the motor now but i still cant pick 3000lbs.
cyamaha2007 is offline   Reply With Quote
Old 06-12-2012, 08:21 PM   #15
WWIIjeep
Senior Member
WWIIjeep's Avatar
Quote:
The photos are deceptive with no familiar size reference alongside. The OP sent me a copy of the Clark specs for it based on the serial number he finally found, and it is indeed the 4000 lb capacity 4024, not the 2000 lb capacity 2024 that it appears to be in the photos.
Old 06-12-2012, 08:33 PM   #16
cyamaha2007
Senior Member
Ive been deuped... You will love having one. I wish i has more concrete now. Im leery taking mine into the gravel as its all fresh, a sharp turn and she needs a shove to get moving again..... I would love a 4x4 case like we have at work. That would be a great asset.
Old 06-13-2012, 02:21 AM   #17
454ragtop
Senior Member
454ragtop's Avatar
Careful, these forklifts are a slippery slope. Once you've used this one for a while, you'll be looking for a yard lift, to go on dirt and gravel. Heres how i know, 2000 lb yard lift. Restored it a couple years ago.
As far as the brakes, they're not bad to fix, other than the weight of the wheels and drives that have to be removed to access them. I think I bought my brake stuff from Nash Lift, both wheel cylinders and a master cyl, were dirt cheap.
Good luck, Jim
454ragtop is offline   Reply With Quote
Old 06-13-2012, 02:57 AM   #18
1948
Senior Member
1948's Avatar
ive used an old 50s one similar to that but with more chrome lol! it worked good, but sometimes it was hard to start and it felt real sketchy lifting stuff over the top of your head. because if anything fell off on you you were pretty much a goner....
1948 is offline   Reply With Quote
Old 11-25-2012, 08:47 PM   #19
dwlee6
Junior Member
Michigan, United States
New problem - the crankshaft pulley that drives the fan and generator is loose - rotates about 15 degrees to and fro. The big bolt in the center of it is hard to get to, but I managed about 1/4 turn on it, it was looser than a bolt that big should be, still probably looser than spec. Pulley still loose, rotates by hand.
I suspect is keyed and key slot in pulley worn out? Or worse crank keyway bad. Any suggestions? Looks like have to pull radiator to get to this area with any ease.
BTW it was a Clark carloader 4000 lb, 1955 model. Has a Continental F-163 motor, not the original per the spec sheet Clark sent me.
Old 06-03-2013, 12:37 PM   #20
wounded7
Junior Member
I have a Clark TM 20 3 wheeled forklift that stops moving when I turn left. the motor still runs, it just stops moving. It only dose it going forward and runs fine any other time.
Does anyone have any ideas about this? I thought it may be in the directional control but I'm not a real forklift mechanic. I'd appreciate any thoughts yall have.
wounded7 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
