Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-17-2012, 04:55 PM   #21
GirlnAgarage
Senior Member
GirlnAgarage's Avatar
Default Re: 2nd layer of shingles or tear-off/re-roof
Strip the old.
__________________
Previous garage; all pics removed
My Garage: Reorganization, it's like a renovation
GirlnAgarage is offline   Reply With Quote
Old 06-17-2012, 05:10 PM   #22
oldgoat
Senior Member
For the most part I would strip it down for many of the same reasons mentioned like weight and check condition of underlay. I would also say though that if you go to a class 4 shingle with some insurance companies you can get a healthy discount on your homeowners insurance. Yes a metal roof is good, but I know on the old metal roofs that it could get noisey during heavy rain or hail. Also I saw on one policy that you would need to sign a waiver on the appearance of the metal roof for a discount.
oldgoat is offline   Reply With Quote
Old 06-17-2012, 06:08 PM   #23
ArkTinkerer
Senior Member
I've read a lot of opinions on other sites about this but very little to back it up. There are a number of caveats to doing an overlay--shingles can't be curling (mine are not), new shingles need to have the same exposure to lay correctly (can do), and the decking must be in good shape.
I read thru several warantees and there is nothing there that says overlays void the warantee. That said, the warantees on these products stink (prorated) and labor is the big thing.
The concept of inspecting the decking is the only valid issue I have seen. I have been up in the attic and seen the underside as well as walked the roof and all seems solid. I am trying to get this done before I have any issues. My existing shingles are not leaking but some spots have little to no mineral left on them. The ridges are cracking. It could last another couple years but that would risk problems. I'd rather fix it now.
Big savings for the overlay is labor if I do it myself. Also I can go slower--one section at a time--and it would be easier to follow existing courses. Current roof has no drip edges installed, I can order drip edges intended for overlays and actually have a better roof. Biggest concern for me is doing the valleys--I don't like the way the old ones were done -- they just don't look like water would flow right over them.
ArkTinkerer
ArkTinkerer is offline   Reply With Quote
Old 06-17-2012, 06:47 PM   #24
5lima30
Senior Member
5lima30's Avatar
Tear off!
__________________
Retired Police Lieutenant, Retired USAF Res, Glock Armorer
"I can do all things through Christ who strengthens me" Phil 4-13.
5lima30 is offline   Reply With Quote
Old 06-17-2012, 08:02 PM   #25
NUTTSGT
NUTTSGT's Avatar
Quote:
ArkTinkerer
If you're worried about the valleys, I believe that is more than enough reason to tear off the old. You may want to inspect to see if there is any damage under the shingles/valley material.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 06-17-2012, 08:07 PM   #26
BD1
Senior Member
BD1's Avatar
DEFINITELY tear off. That's a lot of weight. Figure how much the new shingles weigh and you will remove old. Don't know your location but if snow load is a concern, tear off.
BD1 is offline   Reply With Quote
Old 06-17-2012, 08:43 PM   #27
KnurledNut
Senior Member
KnurledNut's Avatar
1. Does the roof sag right now? (From ridge to eave?) Tear off.
2. If you can get it the attic, see how its framed...
then throw a couple numbers in this calculator:
http://www.awc.org/calculators/span/...rcalcstyle.asp
If its inadequate, tear off.
3. If its structurally sound, and you got three tab, you could overlay.
Use a 5" starter course, and a 10" first course to get you running right.
4. Ive tore off numerous roofs with 1, 2, 3 layers. Unless you got 1 million square not much difference honestly.
IMHO anyways...
KnurledNut is offline   Reply With Quote
Old 06-17-2012, 08:46 PM   #28
darkk
Senior Member
I never do 2 layers, just personal preference I guess...
__________________
My garage build: http://www.garagejournal.com/forum/s...ad.php?t=39357
darkk is offline   Reply With Quote
Old 06-17-2012, 10:03 PM   #29
signcrafter
Senior Member
ArkTinkerer
Ridges are cracking, don't like the valleys, no drip edge. Sounds like a poor roof, even though you say it is in decent shape. Do yourself a favor and tear it all of and start fresh. You can put down ice dam, drip edge, do the valleys right, etc. Why go over stuff you aren't sure about like the valleys you say you don't like the way they are done.
You can do what you want because it's your roof but any decent roofer would tear it off and start fresh for numorous reasons. I see no reason that a home owner wouldn't want to do the little bit of extra labor to do the job right themselves.
signcrafter is offline   Reply With Quote
Old 06-17-2012, 10:21 PM   #30
ArkTinkerer
Senior Member
I'm in Arkansas. Very few houses here have drip edges--they just run the shingles beyond the edge by about 1". Even fewer ice shields--we are lucky to get one snow a year and its gone in a few days. Roof has no sag and the lines are very straight.
But the roof is old. Its done its thing for at least 20-25 years and I've been here for 14 of those and I want to fix it before its a problem.
Best argument against so far is tear off allows inspection. But I can inspect from the attic for the most part.
Arguments for overlay are labor, cost, convenience.
I appreciate the advice so far but has anyone personally seen a problem on a second layer of shingles if its well installed and the deck is solid?
ArkTinkerer
Old 06-17-2012, 10:32 PM   #31
RECox286
Senior Member
RECox286's Avatar
We never layered any roof we ever did. Sometimes the deck was in OK
shape, sometimes there were surprises that reared their ugly heads when
the felt was peeled off. Since we live and worked at the shore, we found
a lot of bad flashings, steel, copper and aluminium alike due to the salt,
humidity, and aging of the materials. If the roof shingles are wood to
begin with, normally they as well as the lathe needs to be stripped off
so a proper deck can be applied. Too many factors to consider b/c
the underside of the roof hasn't been looked at in how many years, and
won't be for another how many. While you are at it, consider a 40yr
architect overlay shingle so, like me, you will never have to fool with it
again in your lifetime. Some last thoughts: don't rely on the cheapie stack
pipe flashings. Have a tinknocker make up a proper flashing that folds
over and into the stack. We have seen too many cheapies fail long
before they should. Also, Ice and Fire applied around the whole perimeter
of the roof is an excellent idea, as well as using 30# felt (minimum). I know
that it ups the cost somewhat, but there is nothing like buying a good
insurance policy for the stuff that lives under the roof.
Uncle Bob
RECox286 is offline   Reply With Quote
Old 06-17-2012, 11:12 PM   #32
rburke65
Senior Member
rburke65's Avatar
You are adding a lot of weight to that roof system......strip it!
rburke65 is offline   Reply With Quote
Old 06-18-2012, 12:41 AM   #33
bczygan
Senior Member
bczygan's Avatar
ArkTinkerer
Shingling over is plain and simple a cheaper, crappier way to do it. But go ahead and find reasons to talk yourself into doing that if you like. You may end up convincing yourself that you're happy, but people who know what's what will know you took the shortcut. I'm a builder and would never even remotely consider doing that to anyone, friend or enemy. Anything worth doing is worth doing right, or not at all.
__________________
  • You may have facts, but I have ALTERNATE facts!
  • Now you guys are going to make me do something instead of thinking about doing something. Okay...........I'll get back to you later when I figure out what I am going to do. - dlcwent
  • Perfection is NOT the standard!
  • There are no limits to what you can accomplish.....when you are supposed to be doing something else. - rshadd
  • Health thread: Begin 237 goal 220 start 12/5/2016 Age 66 6'-3" Cut down salt, pop, sugar and mayo.
bczygan is offline   Reply With Quote
Old 06-18-2012, 08:11 AM   #34
Rust
Tear it off..and ridge vent is practicly useless without venting at the soffits.
Rust is offline   Reply With Quote
Old 06-18-2012, 09:16 AM   #35
GirlnAgarage
Senior Member
ArkTinkerer, you've been given reasons to strip it. If they aren't strong enough for you, it's your roof, by all means do it how you want. But seems like you want a blessing before you go ahead. Here you go - good luck!
If the amount of work/work speed is what's making the layer look like an acceptable compromise (you did say "Also I can go slower--one section at a time--and it would be easier to follow existing courses."), then paying for roofers to get it done at a good working speed would be a plus.
Anyway, do it how you want. It's your house.
__________________
Old 06-18-2012, 11:42 AM   #36
dirttracker18
Senior Member
dirttracker18's Avatar
You seem to be looking for someone to give you the OK that you can do it.
It's your roof so you do not need anyones blessing. The overwhelming majority on here are saying to do it right and strip it. However you continue to come back and lean towards another layer.
Plain and simple it is the cheap and wrong way to do it. When you have a problem in a 5 years the only way to fix it will be to strip. Do one layer now and you can make small repairs if needed. BTW, drip edge is not just for snow, but any water coming off your roof.
Your roof, your time, make a choice and run with it. You know what most of us would do.
__________________
"Success is when you reach a point in your life when you don't feel the need to go back and change things."
Johnny S.
www.LauraMyersPhotography.com
dirttracker18 is offline   Reply With Quote
Old 06-18-2012, 11:48 AM   #37
CodyY
Senior Member
CodyY's Avatar
Default
I'm a roofer in DFW, with an architecture degree.
Strip it. Leave old felt. New 15lb felt over that then Gaf timberline
The insurance companies don't like the additional weight on the rafters. Tear-off costs me a whopping $10 per square. It's worth it.
CodyY is offline   Reply With Quote
Old 06-18-2012, 11:51 AM   #38
CodyY
Senior Member
CodyY's Avatar
Default
Quote:
Best deal in class4 is Owens Corning Weatherguard HP. about $30/sq over a 30yr shingle
Old 06-18-2012, 12:03 PM   #39
signcrafter
Senior Member
It sounds like you already have your mind made up and it is your house so do what you want and best of luck to you.
What I don't understand is you ask a question looking for advice and almost everyone advises you to tear it off for various reasons. Yet you seem to keep trying to justify not tearing it off, or at least that is what I get out of your posts. So why ask if you don't want to hear what others are telling you?
Old 06-18-2012, 12:09 PM   #40
ra42mario
I Just redid half the roof on my shop (hip roof). We stripped it, you would be surprised by the amount of bad wood that you could never see.
ra42mario is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
