Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 06-27-2012, 05:04 PM   #1
bad_idea
Senior Member
Default can atom arc 7018-m be used on ac?
title says it. I tried esab's website and can't find any info. Thanks guys.
__________________
Quote:
Originally Posted by buildmyown View Post
To keep the tools some what neat I use an old trash barrel and just throw everything in there.
bad_idea is offline   Reply With Quote
Old 06-28-2012, 09:59 AM   #2
Spectre32
Junior Member
Default Re: can atom arc 7018-m be used on ac?
why would you want to??
Spectre32 is offline   Reply With Quote
Old 06-28-2012, 12:12 PM   #3
ranger302
Senior Member
ranger302's Avatar
Quote:
x2 ^^^^^^^
It will work but it will weld like a$$. Just run it DCEN should have no problem.
__________________
Expert at precision guesswork.
ranger302 is offline   Reply With Quote
Old 06-28-2012, 03:34 PM   #4
EvilWelder
Senior Member
EvilWelder's Avatar
Yes, all 7018 can be run on AC if you know what your doing, the 7018AC just has a few more arc stabilizers added to the flux to help keep it lit.
EvilWelder is offline   Reply With Quote
Old 06-28-2012, 06:18 PM   #5
Beytill
Senior Member
Beytill's Avatar
Just like Ranger302 said. It will look like the bead I just left in the crapper!
Beytill is offline   Reply With Quote
Old 06-29-2012, 09:51 AM   #6
bad_idea
Senior Member
Why would I want to you ask? The company I work for tosses large quantities of this rod because it is no good to use anymore due to policies. Throw them in a rod oven for a few hours and their right as rain. I have an AC stick welder at home, no dc.
__________________
Old 06-29-2012, 12:59 PM   #7
ranger302
Senior Member
ranger302's Avatar
If you are using them for noncode compliant work then use them. Just practice, practice, practice.
__________________
Old 06-29-2012, 01:58 PM   #8
MoonRise
Senior Member
MoonRise's Avatar
Atom Arc 7018-M, scroll down a bit
http://products.esabna.com/EN/home/f...l_low_hydrogen
takes you to
http://products.esabna.com/EN/home/f...rc_7018m_7018m
by the AWS class definition, Exxx8 electrodes are low hydrogen, iron powder and AC or DC capable.
The Atom Arc 7018-M is a 'variant' of Atom Arc 7018 made/certified to meet additional MIL-spec requirements of MIL-E-0022200/10 for mechanical properties, coating moisture and diffusible hydrogen content.
Rebake is usually 700F for one hour, storage is 225-300F. Right from the ESAB Covered Electrodes Data Book, page 27.
http://www.esabna.com/us/en/support/...ndex.html#/26/
(AA 7018-M listed at the end of the chapter/section under "Additional Products", page 1-75)
All right from the ESAB website.
MoonRise is offline   Reply With Quote
Old 06-29-2012, 02:42 PM   #9
ranger302
Senior Member
ranger302's Avatar
Well Played Moonrise.
__________________
Old 06-29-2012, 02:51 PM   #10
bad_idea
Senior Member
I appreciate your help Moonrise. I couldn't make heads or tails of ESAB's website.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
