Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
I have a 30' x 30' garage -- i applied epoxy coating with a quikrete kit from Lowes (2 part) --- problem came because i etched 1/3 of the floor with a different etching compound than was in the quikrete kit ---- now i have a 10' x 30' section of the floor that is peeling and flaking all over the place. The rest of the floor is alright and the sections are divided by expansion cuts.
Some of the floor is flaking, but some is still stuck tight --- is there an easy way to remove this mess. or am i stuck with a long weekend and a belt sander ? I would like to re-do the affected section with the quikrete kit that seemed to work alright Thx in advance ![]() Doug |
#2 |
you can try renting a buffer and some sandpaper. It might save your knees oryou can also try a long handled 4" razor scraper.
#3 |
Senior Member
Sherwin Williams application bulletin for their Armorseal 1000HS and other high VOC solvent epoxy (not water based) recommends either shot blasting or acid etching. And goes into detail with both methods. However their Industrial Marine Representative highly recommended using shot blast for best results. I have acid etched in the past, and after mt present experience I feel that shot blasting is a better route to follow.
This is the organization that I rented the equipment and purchased the supplies from. http://www.jordanpower.com/ourManufa...rface_prep.htm
__________________
Read About: My "Class Act" Car Hauler's===> Structural Failure OldCarGuy's New Toy Shop Complex |
#4 |
Senior Member
I think you are in for a long weekend - and don't think a belt sander is going to do the job properly. You are probably going to need a grinder or shot blaster to get the job done properly. I would acid etch after doing the grinding or blasting. Succesful epoxy applications are done only with proper preparation.
#5 | |
Senior Member
Quote:
__________________
#6 |
Senior Member
One more thing to try? Get some Rock Miracle, lay a small portion down and cover with plastic. Do a test area and see what happens? I had to remove a layered up concrete stain that I tried this on. Still you may need to grind or sand but may take some of the pain out of the long day ahead of you. Oh the longer the Rock miracle sits under plastic the better.
#7 |
Senior Member
Dimond grind. Or if you have a good 7" angle grinder you can do it that way. A 7" dimond grinding wheel will run you $80-$110 and will save you a ton of work....you will also need a decent dry/wet vac with a drywall/cement dust filter bag on it.
Grinding it away will be your best bet. Good luck. JD |
#8 |
Senior Member
IMHO-
If possible, rent an EDCO floor grinder. They are usually available at larger tool cribs and well stocked Lowes, Home Depot, Menards, etc. This machine has carbide tipped (or optional diamond tipped) blades that should remove the coating well. Google it to get the info on the machine. They can take a little finess to work it, but the results are worth it. |
#9 |
Junior Member
If the material is already flaking off, it shouldn't take much more than an 8 inch flat razor blade fitted to a pole to get the flaking epoxy off. Well, plus some elbow grease. If that proves to be too difficult, you'll need to grind it off or beadblast the concrete. You can get a beadblaster at home depot or at any other comparable store. Since the section of the floor that is flaking is only 1/3 of 900 square feet, you'll probably not want to spend alot of money on renting this type of equipment. If you get a 7 inch grinder with a diamond pad, it might just spin in the epoxy and not want to remove it easily. Beadblasting should go easier, however, if you are not careful while beadblasting you can etch the concrete deeper in rows creating a "corn row" effect that is still visible after epoxy application.
My main concern is that you etched the concrete with a different compound and it caused this reaction with the epoxy the first time. I hope that even after you remove the flaking epoxy... that it won't reoccur with your new coat the second time. If this happens, it might mean that whatever was used to etch the concrete has either left a residual on the concrete or has seeped into the pores of the concrete, and, is wanting to come up through the top (and pop off your epoxy floor in the process). This happens sometimes when epoxy is rolled over, say, a heavy oil spill. Over time the oil comes up through the surface of the concrete and de-laminates your epoxy floor. |
#10 | |
Senior Member
Quote:
#11 | |
Senior Member
Quote:
I have 2 gallons of it in clear I was given to test and see if I liked it. |
#12 |
Streetstar,
You need to sand the surface anyway to recoat so don't beat yourself up. Epoxy is very hard so sanding will create a new profile on the surface. What will come loose at this time will come loose. Than whatever brand name you like, use a 2 part system of 100% solids. You'll like the result! Whatever you do, always get a spec on the product and read! HD or Lowe's will not have ready a spec sheet. Spec Sheet tells you everything about he product to reduce problems during application. Read, Read than coat!!!!! My 2 cents Goood lucK, You can do it! Glenn Last edited by connorB; 03-14-2008 at 11:06 PM. |
#13 |
thanks for the input everyone --- just waiting for a long weekend where a project truck or motorcycle is not parked in the way to start in on this. I almost feel like Race-decking the section now and just calling it my "motorcycle shop"--- but i will see how it goes
Can VCT tile be glued down over this mess? or would it be too unstable for it Last edited by streetstar; 03-19-2008 at 02:41 PM. |
#14 |
Senior Member
I can't find a shot blaster ANYHERE to rent. I've called 10 places. Now what?
Also, would the stripper work???? Looking for the easiest, least expensive way. |
#15 |
Senior Member
Dang- Makes the extra $$$ worth every penny I paid now. Sorry to hear of your troubles!
__________________
#16 |
Senior Member
I checked the Internet and was surprised that most of the recommendations involved, not grinding, but using a paint stripper. I did not know paint stripper will work on epoxy, or is there a special stripper for epoxy?
Here is one of the articles: How to Remove Epoxy Flooring At some point you may want to remove epoxy flooring from your kitchen, basement or garage, to change the color or replace it due to wear. Follow the procedure outlined below to remove epoxy flooring safely and with little difficulty from a space in your home. Tools and Materials You Will Need ■Box cutter knife ■Stiff-bristled broom and dust pan ■Vacuum cleaner, dry and shop-vac types ■Epoxy stripping solution ■String or fiber mop ■Electric fan, as needed ■Long-handled putty scraper ■Wire-bristled brush ■Pointed shovel ■Large trash bags ■Eye goggles, painter's mask ■Rubber gloves Step 1: Determine If Your Epoxy Floor is Solvent or Water-Based Take a small cutting of your epoxy floor to a building center to find out whether it is solvent or water-based. This will determine the type of stripping solution you should buy. Ads by GoogleAnti Slip Products One stop source for Anti-Slipproducts. World-wide delivery.www. noskidding. com Flooring Software Take-off & EstimationEasy, Powerfull, Free TrialFloorEstimator. com Step 2: Purchase the Stripping Solution You can use either water-based epoxy stripper on water-based epoxy, or if you are highly sensitive to volatile compounds, choose a soy-based, environmentally friendly epoxy stripper that emits low levels of fumes. Step 3: Prepare the Floor for Stripping Remove all furnishings, wall hangings and window coverings from the room to prevent them being splashed with stripper or absorbing chemical fumes. Sweep the floor surface thoroughly and then vacuum to remove any dust, dirt or flakes from the topcoat of the epoxy floor. Have the windows and doors into the area open to ventilate the room. Put on rubber gloves, eye goggles and a painter's mask. Step 4: Apply the Stripper Pour on or spray on the epoxy floor stripping solution, starting in the farthest corner from the exit doorway. Cover a measured area at a time of about 4 by 4 feet. Use a string or fiber mop, not a sponge rubber type, to spread the stripping solution over the floor. Distribute the stripping solution all over the floor evenly. Step 5: Seal the Room to Let Stripper Soak Close the doors and windows tightly, and seal off the room so that the stripping solution can soak into and dissolve the old epoxy for at least 24 hours, or as recommended on the container of stripping solution. Step 6: Peel off the Old Epoxy Layer Open up the doorways and windows again, and put an electric fan in the room pointed toward a window to vent off the fumes. Put on your protective eye and hand coverings and a fresh painter's mask. Using the long-handled metal scraper, push off the layer of epoxy flooring starting at one edge of the room and moving toward the door. Clear off a row at a time, twice the width of the scraper blade. Using the shovel, scoop the waste epoxy into trash bags and discard it safely. Step 7: Re-soak Stubborn Epoxy If sections of epoxy will not come off the floor, soak these parts again overnight with stripping solution, and scrub them the next morning with a brush with stiff wire bristles. Step 8: Rinse and Vacuum the Floor When all the epoxy has been removed rinse the floor with cool water and vacuum it up with a shop-vac. Then allow the floor surface to dry completely. Read more: http://www.doityourself.com/stry/how...#ixzz0vQlJCJXe |
#17 |
Senior Member
Or, rent an Edco with Dyma-Serts and a vacuum. Strip 600 square feet in an hour or two and be done with it.
#18 |
Senior Member
#19 | |
Senior Member
Quote:
The floor contractor will start remedial work tomorrow, pouring a new epoxy coat over the work gone wrong (they used a roller to spread the epoxy which led to predictable major orange-peel). If that fails, we will have to strip the epoxy by some means if I can't find an Edco or similar. There are some advantages to living in Manila (househelp, for one), but also disadvantages. Thanks again. Andres |
#20 |
Senior Member
If you do end up having to strip it off and you find a machine, call the machine's manufacturer and ask what would be the best grinding product. Many manufacturers offer multiple grinding products for their machines.
Good Luck! |
| Thread Tools | |
| Display Modes | |
