Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 07-16-2012, 11:34 AM   #1
94legaleagle
Senior Member
Default Prevent grass sticking to Mower Deck?
What product can be sprayed onto the bottom of a lawnmower deck to prevent grass from sticking / building up on the underside of the deck when you mow grass?
Years ago, I used some Conklin stuff (maybe Rust Bomb???) and it worked great - but I can't remember what I used - and I'm wondering if there is any newer / better product
94legaleagle is offline   Reply With Quote
Old 07-16-2012, 11:49 AM   #2
JimVonBaden
Senior Member
JimVonBaden's Avatar
Default Re: Prevent grass sticking to Mower Deck?
Used motor oil!
Jim
JimVonBaden is offline   Reply With Quote
Old 07-16-2012, 11:50 AM   #3
OldMechanik
OldMechanik's Avatar
Pam Cooking spray or WD40 might work.
__________________
ASE Master Tech
Toyota Master Tech
OldMechanik is offline   Reply With Quote
Old 07-16-2012, 11:51 AM   #4
JWC07
Default
Diesel fuel in a pump up sprayer
JWC07 is offline   Reply With Quote
Old 07-16-2012, 11:52 AM   #5
mayday0017
Senior Member
Always heard when you change the oil to clean the deck and apply the used oil to under side of deck. It keeps it from rusting and keeps grass from sticking.... Never tried this though cause my decks have always been made from a material that doesn't rust.
mayday0017 is offline   Reply With Quote
Old 07-16-2012, 12:00 PM   #6
Dan in Pasadena
Senior Member
Dan in Pasadena's Avatar
Pam. Cheap, easy, not as messy as a rag full of dirty oil. Put a LOT on.
Dan in Pasadena is offline   Reply With Quote
Old 07-16-2012, 12:18 PM   #7
cashishift
Senior Member
Send a message via AIM to cashishift
http://www.amazon.com/Mo-Deck-Mower-.../dp/B000VYN71O
cashishift is offline   Reply With Quote
Old 07-16-2012, 12:27 PM   #8
GGB
Senior Member
A lot of good options out there, but my favorite is Fluid Film. It's a lanolin based lubricant that I ran across on another forum. I ordered a sample, and liked it so well that I use it here at home and at the farm. It has a pleasant smell (to me), and I even use it to clean the grease off my hands. It kind of reminds me of the old cosmoline (sp) that was used alot during WWII to protect parts being shipped from rusting. I know you can get it at some John Deere strores, but don't know where else to check.
I haven't found anything that I like better for mower decks. It really does a nice job of keeping them clean, and also works very well to prevent and keep rust from spreading, even when exposed to moisture. I just spray it on the underside of the deck when I sharpen the blades and before storing the mower deck in the winter. Also, it works well if I'm trying to unstick nuts and bolts if you can leave it overnight (I'll still vote for Pink Panther Pxss if I'm in a hurry). Wish I'd known about FF a long time ago, as the underside of my deck would now be in better shape.
GGB
GGB is offline   Reply With Quote
Old 07-16-2012, 01:18 PM   #9
superduty59
Quote:
GGB
I haven't used it on mower decks but it sounds good to me. I'm a generator tech and we use it all the time for everything. It works great on battery terminals. Big industrial units that are exposed to all kinds of weather, just spray a little on and come back in a year and it looks as good as new.
superduty59 is offline   Reply With Quote
Old 07-16-2012, 02:03 PM   #10
ms fowler
Senior Member
Location: Littlestown, PA _ 6 miles south of Gettysburg
I used POR15 to paint the underside of the deck. Its a very hard, moisture -cured paint product that has a glass-like texture. Very smooth.
ms fowler is offline   Reply With Quote
Old 07-16-2012, 02:20 PM   #11
east_tn_emc
Senior Member
I have 4 commercial mowers (three Ferris and one Scag). I cut about 30 acres a week (not commercially, but we just have a lot of yard to cut )
I completely agree and recommend the Mo-Deck product. I use it and swear by it. I did an experiment when I first started using it...left one mower alone and pressure-washed the deck of another mower and then put a good heavy coat of Mo-Deck on it.
I was AMAZED at the difference after a month or two of use. I use it on all my mowers now!
Quote:
Originally Posted by cashishift View Post
east_tn_emc is offline   Reply With Quote
Old 07-16-2012, 03:03 PM   #12
djd99
Senior Member
djd99's Avatar
Quote:
I did this as well, wire brushed the entire underside of my deck that was 2 years old, it had paint that was flaking off. I then coated it with por 15 and so far I'm not impressed the por 15 started flaking off just like the paint= Fail
__________________
Don
djd99 is offline   Reply With Quote
Old 07-16-2012, 10:22 PM   #13
c39er
Senior Member
c39er's Avatar
I Clean my decks after the end of mowing season and smear with grease or cosmoline in a can. One deck on my Massey is still rust free after 35 years of mowing.
c39er is offline   Reply With Quote
Old 07-16-2012, 10:54 PM   #14
Racecarl
Senior Member
Racecarl's Avatar
John Deere makes a slip plate spray-on graphite that several people think is awesome. I have not used it personally, so I can neither confirm or deny.
Racecarl is offline   Reply With Quote
Old 07-16-2012, 11:02 PM   #15
MScott
Senior Member
MScott's Avatar
Quote:
Did you remove all the paint? If not, the original paint may be continuing to peel and taking the POR with it. Check some of the POR flakes to see if there is original paint on it.
MScott is offline   Reply With Quote
Old 07-16-2012, 11:17 PM   #16
coby65
Senior Member
coby65's Avatar
I work for Toro mowers and I can tell you the best practice at the end or begining of the season drain the gas and oil and paint the underside with a high quality GLOSS paint. This is the best defence against rust building up and will alow grass clippings to move out of the deck more effectively.
Also check and make sure you are using the correct blade with the deck. We have found that some of the mulching blades work better on discharge decks than with standard blades and standard blades work better on mulching some types of grass.
coby65 is offline   Reply With Quote
Old 07-17-2012, 08:12 AM   #17
darkk
Senior Member
I use PAM cooking spray. I also use PAM on my snowblower in the winter. Keeps the snow from sticking and clogging everything up.
__________________
My garage build: http://www.garagejournal.com/forum/s...ad.php?t=39357
darkk is offline   Reply With Quote
Old 07-17-2012, 08:53 AM   #18
GOLF for LIFE
Senior Member
GOLF for LIFE's Avatar
I think I'll try the Pam spray. Also thought about silicone spray.
GOLF for LIFE is offline   Reply With Quote
Old 07-17-2012, 08:57 AM   #19
Cougar
Senior Member
Cougar's Avatar
Location: Wisconsin A little south of the Frozen Tundra
POR15 is pretty good stuff.
Did you use the metal ready before applying it.
Cougar is offline   Reply With Quote
Old 07-17-2012, 09:20 AM   #20
SuitorsGarage
Senior Member
SuitorsGarage's Avatar
POR15 doesn't stick to paint very good.
I would paint the deck and then spray it with fluid film.
SuitorsGarage is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
